-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   Homebuilt Arm and Vest (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/68684-homebuilt-arm-vest.html)
Riley Harmon June 1st, 2006 05:55 PM
I am so excited! Ive been working on refining my arm for the past 3 weeks, it's finally welded and setup how i like. Tomorrow I should finish the vest and this weekend paint with auto black. I cannot wait! Stay tuned for pics and vid.
Riley Harmon June 2nd, 2006 06:27 PM
bah i give up, im just going to save for a smooth shooter
Charles King June 3rd, 2006 10:46 AM
Ha! Ha! I'm sorry, I had to laugh. This was very short lived. Not as easy as it seems uh??? It's good you're saving up for the smooth shooter. Now you know why these things don't come cheap. ;) Good luck with your purchase.
Riley Harmon June 3rd, 2006 08:58 PM
no no no that was sarcasm, i am painting it as we speak, im uploading some pics of unpainted
edit:
Its too dark to shoot footage, i will do it in the morning
www.rileyharmon.com/temp/steady-002.jpg
www.rileyharmon.com/temp/steady-004.jpg
www.rileyharmon.com/temp/steady-006.jpg
Tom Wills June 4th, 2006 08:50 AM
Ahh, good old sarcasam. It never fails to be lost on the internet.
Nice looking vest and arm. Give it a few nice coats of paint, and that thing will be looking sharp!
Riley Harmon June 4th, 2006 01:18 PM
okay heres my problem, the vest and arm are good, they take the weight, the glidecam is good and balanced, but when flying, it has a tendancy to rotates on the horizontal axis, this causes it to sway side to side, how tight a grip should i have on the post?
sorry for the crappy compression i did it quick and gritty
www.rileyharmon.com/temp/steadytest1.mov
Riley Harmon June 4th, 2006 09:41 PM
www.rileyharmon.com/temp/steadytest2.mov
Lets hear good and bad comments and how to improve. Need more practice walking.
Cole McDonald June 4th, 2006 11:27 PM
That is a nice looking rig! Now I have to look into making one of those...dang it.
Bill Slammon June 6th, 2006 10:01 AM
Very nice
Will you be sharing your design in some fashion?
Riley Harmon June 8th, 2006 12:07 PM
Yeah, I will try and get a design out sometime soon. I'm trying to practice more, because it has a tendancy to sail.
Denis Danatzko June 8th, 2006 12:09 PM
Riley, you've obviously put a lot of work into this,
and I don't mean to demean your enthusiasm. However, since you've invited comments, here's mine: from the photos, and not being able to see the back of your rig, it appears the belt is very snug and may be carrying the brunt of the weight of the unit. (Without seeing the back, it's hard to gauge weight distribution).
I've done a few week-long backpacking trips, sometimes carrying 50 lbs +/-, including tent, bag, food, water, still camera, etc. Backpacks meant to carry such serious loads use 2 padded shoulder straps, a padded belt at the waist, and often a belt around the upper torso. It's clear you've included those in some way, shape, or form. In large backpacks, those combine to spread weight between the shoulders, and the hips below the lower back, making for less overall fatigue. Something even the DVRig Pro with it's belt and single shoulder support doesn't appear to do. (Granted, I'm describing BACK packs, where yours' is more of a FRONT pack, adding difficulty to weight distribution).
It's necessary for the belt to be snug in order to properly support and spread the load. However, the photos hint that the upper portion of your rig seems to place the weight more towards the neck and/or even the collar bone rather than the shoulders. If weight is being supported by the neck rather than being spread between the shoulders and the waist, you may find fatigue - or worse, back pain - setting in after long-term wear, i.e. upwards of an hour.
Best wishes for success.
Riley Harmon June 8th, 2006 02:32 PM
yeah, the straps cross in the back so it does put weight on shoulders and collar. but the great thing is. i can also wear it on my back same as front. i'll try both ways and let you know
Bill Slammon June 9th, 2006 02:54 PM
Thank you.
Bill
Dave C. Preston June 9th, 2006 11:15 PM
Great job, Riley! I applaud your sense of engineering adventurism! I think a lot of the folks here would love to have a crack at working with your design to make a few improvements. Cheers.
Wayne Masters June 10th, 2006 12:55 AM
Stabilizer research
The research I did on stabilizers gave me an idea for a video short where the main subject is attached to the camera as well. I bought all the aluminum in a scrap yard. The bearings weigh more than the arms unless I order special, light alternatives.
For interviewing government officials etc. or a sensitive doc, I am looking for a slick, slim profile stabilizer.
I found that a "Swifer" broom only needs a bracket and a bearing to be a stabilizer.
I recommend spending time checking out home made stabilizers.
Wayne
Terry Thompson June 24th, 2006 12:33 AM
Riley,
I liked the second video best as it was more interesting to watch.
It's great that you have made a working stabilizer. It teaches you a lot about it's correct set-up when you make one.
One word of advice...Use your control hand as little as possible. If you are in constant contact with it your video will suffer. This is especially true of lighter rigs like ours.
Practice, practice, practice. One you feel like your getting good try zooming in a bit and then watch you shots. It's a whole new world.
Read all of Charles Papert, Charles King, Mikko Wilson, and the other steadicam operators posts on different subjects. They are very good at helping! (Sorry I missed a bunch of operators who regularly contribute to this and other forums.) They lead full lives but still have time to help us. We owe a lot to them!!!
Tery
Indicam
Riley Harmon June 24th, 2006 01:06 AM
first field test of my vest and arm has been this week on a ranch in the middle of no where shooting with this docu-drama and horses, has been great. the vest and arm really hold up, ive done some incredible shots from sitting on the back of a 4-wheelers with the horses behind it and in front of me, great stuff, when i capture, ill show you guys. peace.
