-   Still Crazy (https://www.dvinfo.net/forum/still-crazy/)
-   -   Video Out not working on EOS 10D (https://www.dvinfo.net/forum/still-crazy/63925-video-out-not-working-eos-10d.html)
Jeff Miller March 29th, 2006 09:12 AM
The video out port does not seem to be working on my 10D. I've tried using various 1/8" video/RCA video cords to various TVs/decks/cameras etc and it just never puts anything over the video when hitting 'Play' or 'Menu'. Unplugging the video from the 10D will then activate the LCD and the image/display will show.
To test the cabling, I've hooked up camcorders to the same 1/8" cable and they will display a picture on the TV or deck. It's been a while since I used the 10D's video out, but it was working in January.
I'm hoping I just disabled something by oops. It is set for NTSC, couldn't think of anything else to check. Thanks for any help!
Mike Tesh March 29th, 2006 03:46 PM
This might be a little off but I know with my new video ipod that in order to use one of those 1/8th to RCA video cords I have to switch the yellow with the red and plug the red into the video input and the yellow into the right audio input. It's just reversed like that. I haven't tried video output for my 300D but seeing as it's a close design to the 10D maybe I should try it and get back to you.
Then again I also know they make dedicated video out cords that only have the yellow RCA at the end. Maybe you need one of those instead.
Mike Tesh March 29th, 2006 03:50 PM
Interesting. I just tested this with my 300D and it turns out I needed to use the white connection to get the playback images to display on screen.
I guess all these devices are wired different.
Jeff Miller March 29th, 2006 04:30 PM
Hi Mike,
Well, your advice fixed it, this time I hooked it up the 'wrong' way and it worked :) Which makes no sense cuz the rig worked with a camcorder, but I won't knock it further. Thanks!
