-   Techniques for Independent Production (https://www.dvinfo.net/forum/techniques-independent-production/)
-   -   Swords: How Can I Get Realistic Swords? Please Help. (https://www.dvinfo.net/forum/techniques-independent-production/45670-swords-how-can-i-get-realistic-swords-please-help.html)
Drew Meinecke June 4th, 2005 05:50 AM
I'm in pre-production of a movie that will need many swords for battles and choreographed fights. I have been researching for months and have been experimenting with many different types of swords, and I have nothing to show for it. For my last movie we made wooden swords and painted them, and that worked for that movie but I want something that looks real for my next movie. I recently bought real, dull swords from a flea market, and after just swinging them around they fell apart. I do not know where to look, I want real swords that are dull and light and fairly cheap, does anyone know where I can find these?
Boyd Ostroff June 4th, 2005 06:21 AM
Fighting swords are very different from display swords. Be very careful, you could be injured using swords not designed for fighting, they shatter on impact. We deal with this issue all the time with our operas, and I think you best bet will be to rent real fighting swords (unless you need them a very long time and can afford to purchase).
Weapons of Choice is really the best source for this. They've always been very helpful and responsive. Here's their website:
http://www.weaponsofchoicetheatrical.com/
K. Forman June 4th, 2005 06:26 AM
You might also look around for a local SCA chapter. These are the folk who do medieval reinactments. The often have staged battles with weapons.
Richard Alvarez June 4th, 2005 06:52 AM
Drew,
First a bit of background. I'm a fencing master, fight choreographer and owned a jousting company for twelve years, before dedicating myself to my filmmaking some ten years ago.
So I know whereof I speak.
You can be SERIOUSLY injured if you are not careful. Broken blades fly off in strange directions. Untrained 'actors' can get out of controll, especially in the heat of performance.
Combat worthy stage weapons have a much wider tang than your wall hangers, and cost more too. There are a number of good sources, but they won't be cheap. Especially if you need a lot of them. You might buy several for your main characters and rely on your mock swords for big background scenes. (Wood is good, but it still breaks and splinters. Plastic is better.)
Many movies use alluminum or rubber for the big battles sequences. Some principals will have alluminum versions and steel versions for their fight scenes.
If you aren't trained in stage combat, which is NOT the same as real combat, find someone who is. The society of american fight directors is a good place to start.
"You'll poke your eye out!"
Drew Meinecke June 4th, 2005 08:01 AM
After looking through that site, I found there is a lot of stuff that I need for my movie on that site for rent. Thanks a bunch.
Drew Meinecke December 13th, 2005 04:29 PM
Is there any alternative to stage combat swords? Is there any way to obtain those rubber/plastic/aluminum swords?
Boyd Ostroff December 13th, 2005 04:34 PM
If you don't actually need to fight then there are a lot of places which sell very nice replicas. However see all the cautions above if you're doing a combat scene.
For fake swords, Google "presentation swords"
K. Forman December 13th, 2005 07:15 PM
Be very careful using decorative swords, many are good for nothing but hanging on a wall, as was intended by the manufacturer. Even if you don't plan on creating impact, the blade may fly free from the handle, which is a major hazard to anyone near by. Since they weren't intended for anything but decoration, the manufacturers might not build a decent tang, or even secure the handle to the blade.
Drew Meinecke December 13th, 2005 10:55 PM
I need swords for combat and have found the prices and info for the stage combat swords, but can't find any information on those other types of swords: rubber/plastic/etc. Are they just made specially for movies? Is there anyplace that sells them?
Richard Alvarez December 13th, 2005 11:00 PM
Drew,
The rubber and plastic swords are available only through prop houses. They are specialty items, and will also be pricey.
How many swords do you need? How many fights are going on at one time? What is the era you are trying to create?
YOu can always try http://www.latex-weaponry.com/index....FQo6GAodDE6nOw My son uses these for his LARP games. They look real enough for long shots, but again, at a hundred a pop or so, not especially cheap. MUCH safer than steel or alluminum however, especially if you are putting them in the hands of untrained fightors.
Reid Bailey December 14th, 2005 09:07 AM
I echo what others, especially Richard, have said.
I used to do quite a bit of modern, historic, and theatrical fencing/swordsmanship. The preferred blade type at the time was the "schlager" blades, though I know I'm screwing the spelling.
They were high quality, had a high spring tension, and would stand up to most anything. They featured the wider tangs that Richard spoke of.
A lot of companies would use the double-wide epee or "musketeer" blades. I would strongly advise against this. They break quite easily when hit "wrong", though make a really cool sound when they do. Not cool enough to counter the danger involved with a foot long piece of jagged metal flying through the air though.
There may be better technologies out there. Always think safety. Try and find someone proficient in western swordsmanship, the oriental styles are just different.
Alex Jeffery December 14th, 2005 07:29 PM
http://www.knightsedge.com/stage-steel-swords.htm
(They also have rapiers that currently aren't posted on the website.)
George Ellis December 15th, 2005 12:42 PM
Yes, do what Richard says. I was a competition fencer and even competition weapons can kill with an equipment malfuntion (As a judge, it was also our job to halt the action when we saw it happen.)
And yes, competitive fencers make fun of the theaterical fencers. I could have taken Darth Vader in his first presentation of the blade with a cut to his arm. He left it SOOOOO open ;)
Oh, cannot rememeber the movie, but I do remember seeing some B-grade movie that used competition sabers.
Drew Meinecke December 15th, 2005 04:30 PM
With those latex swords from: http://www.latex-weaponry.com/index....FQo6GAodDE6nOw, do they look very realistic? I heard they are very thick, so do they look fake? Do they have a luster to them or do they look dull?
Richard Alvarez December 15th, 2005 04:58 PM
Drew,
They are suitable only for 'long shots' which is what I said in my post. They are pretty fair representations, especially the broadsword or medieval weapons. They ARE thick. They are designed for unchoreographed 'combat' without armor on. But they do look pretty good. The 'silver' is kind of shiny. Some of the broadswords go for about 70 dollars I think.
NO, they wouldn't look good in close up.
Drew. That's it. That's the information you are going to get. Real combat worthy swords are expensive. Cheap presentation swords are dangerous. Moderately priced 'foam' weapons will not hold up to a closeup on camera, but are very safe.
Find an experienced fight choreographer to help you. Stage combat is serious business.
K. Forman December 15th, 2005 06:24 PM
They had the sword from the Xena tv show on auction not long ago, and it was a plastic type sword. Looking at the still pics of it, it did look extremely phony. Watching the show though, it was hard to tell.
Richard Alvarez December 15th, 2005 07:00 PM
Keith,
I've worked with plastic doubles of real swords, and they look pretty good on camera. They will hold up moderately well to combat, if you spend time choreographing the moves, and pulling the punches. The pluss side is they weigh a lot less, and hence move much faster and cause less damage than real steel if they hit. They sound like crap though! (Cue the foley artists) They are also pretty expensive, because they are custom made to be replicas of the steel ones.
I'm afraid Drew isn't going to find a cheap - safe - realistic solution. Kinda like that quality triangle - "Cheap, Fast, Good" - you can have two of the three, but not all of them.
Drew Meinecke January 18th, 2006 07:59 PM
I found these swords which claim to be functional and useable for fighting. They are pretty cheap too. Does anyone know anything about these Stage Steel swords?
Richard Alvarez January 18th, 2006 09:23 PM
Drew,
They look to be a knock off of Starfire Swords http://www.starfireswords.com/web-pa...pages/home.php
I've used Starfire blades, and they're tough as nails. They also replace them if they ever break. Great deal.
Alex Jeffery January 22nd, 2006 05:35 PM
Yeah, Knight's Edge makes pretty darn good stage steel. I have two swords from them.
Barry Werger January 22nd, 2006 05:47 PM
Hmmm... in my experience, for combat, they are usually using PVC or wood wrapped in foam wrapped in duct tape! NOT realistic in looks! The better looking ones are just for show... (or non-SCA sanctioned activities).
Barry Werger January 22nd, 2006 05:51 PM
Also, I don't think anyone's mentioned it, but almost any Martial Arts supply place on the web (there are thousands) have weapons in "kata" (showy), practice, and combat categories - often much cheaper than stage weaponry. Again, they tend to be asian-style, but may be worth checking out. Talk to some schools in your area or on the web to find out which are sturdy enough and safe enough for your needs.
