December 8th, 2020, 05:47 PM | #31 | |
also known as Ryan Wray
Re: Does anyone know how to do this video map effect?
December 9th, 2020, 02:45 AM | #32 |
By laying blank paper on top, you can trace a source map and so create your own map without any writing over it, You can do this physically and scan it into you computer. You can then use your NLE to keyframe moves.
Alternately. if you've got Photoshop and the copyright free map, you can alter it so that you get the look you want. It's a matter of playing around with Photoshop and exporting a suitably high resolution file, Paul gave you the max you can use in Premiere earlier. |
December 9th, 2020, 05:44 AM | #33 |
Let's be honest Ryan - the skills required to use photoshop are hardly as complex and tricky as many of the other things you do? You now have some really good map sources from people in this topic. Google earth pro - is free, and you can turn things off very easily. Alternatively you can find a million sources of maps, and very simply add texture to simulate terrain, as in the Indian Jones movie.
I'd forgotten it but I did a little local history photo thing years ago that has some map following - it's quite crude now, but hardly difficult, process wise. |
December 9th, 2020, 05:48 PM | #34 |
Oh okay, thanks. I've tried google Earth Pro, but I have to take freeze frames of it as I go, and have to erase all the google earth lables on the map and there are a lot mostly in the ocean areas. So I can use the clone stamp to get rid of them, but this takes some time to make it look good. But I am having trouble taking still frames of the land as I go because google Earth keeps changing it's angle and trajectory as I got, thereby leading to mismatches in trajectory from frame to frame, if that makes sense?
December 10th, 2020, 01:50 AM | #35 |
That method will have a certain animated "look" and you do need to practice the moves before you start capturing the frames, so that you get a feel for them.
If you want a smoother move try using the movie maker option in tools. |
December 20th, 2020, 06:38 PM | #36 |
Speaking of "video map effects"..... I am developing a GPS/Mapping app using a very cool API called "maptalks". It was originally developed by YUM Brands in China for in-house use, analyzing locations to place KFC and Pizza Hut restaurants! The company then turned it into an open source project at github.
Anyway, Played with its 3d animation capabilities today and am very impressed. Just added a few lines of code to the app I'm writing to get these effects. These are running in realtime using map data from the New Jersey state mapservers. Could get much better performance with local data. I will add some kind of basic capablities like these to my finished app. |
December 21st, 2020, 10:45 AM | #37 |
The second one has worked well.
January 12th, 2021, 11:37 AM | #38 |
Just found this while looking for something else. Pretty cool if you're serious about integrating maps into your video.
https://www.maptiler.com/news/2020/1...to-your-video/ |
January 12th, 2021, 11:44 AM | #39 |
I wonder how hard that is to manipulate? Looks great but I bet it's a steep learning curve!
January 12th, 2021, 02:25 PM | #40 |
Looks pretty straightforward to me, although I did not dig very deep. However, I've been immersed in writing map software for the past few years so my frame of reference is a bit different. :-) For me, After Effects would be the "steep curve", since I haven't used it before and learning Adobe software is one of my least favorite activities!
