-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   Anyone using the Bogen 503 or 505 head? (https://www.dvinfo.net/forum/tripod-sticks-heads/30833-anyone-using-bogen-503-505-head.html)
Bruce S. Yarock August 22nd, 2004 11:51 AM
I posted on another thread ,that I'm planning to get the Bogen 532art sticks, and wanted to get a real fluid head with it. the 519 looks very interesting but isn't available yet. The salesman at BH tried to talk me into the 503, which is available ( and cheaper). But someone here mentioned that the 503 isn't a "true fluid head", and would have " stiction" problems.The 505 is apparantly a real fluid head, but doesn't have the features ( choice of springs, etc.) like the new 519.
Unfortunatly, I can't try any of this stuff in South Fla., so I'm hoping someone can help me out.
Thanks again.
Bruce S. Yarock
Pat Chaney August 22nd, 2004 12:47 PM
According to the Manfrotto site the 505 head "comes complete with 4 interchangeable balance springs for 2.2, 4.4, 11, or 17 lb cameras". It is considerably more expensive than the 503 though.
A Manfrotto advert in a current UK magazine lists the 501 head as having "friction drag" and the 503 head as having "fluid drag". So there must be something wet in there somewhere :-)
Bruce S. Yarock August 22nd, 2004 02:18 PM
Pat,
Do you know what the difference is between the 505 and the 519?
Bruce yarock
Pat Chaney August 23rd, 2004 02:20 AM
It appears that the 519 is a heavier-duty version. You can check out the differences at www.bogenimaging.us
Robert J. Wolff August 23rd, 2004 01:24 PM
Bruce.
Unless you are going to be using multible different weight cameras, the 519 head won't be of much use to you, with the additonal springs. That's what the springs are for: different weights.
Also, according to Manfrotto, the 519, does not have a quick release plate! (Kind of important in a shoot & scoot).
I use the 516, which will hold up to 22 Lbs, same as the 519. Plus it has 2 pan handles. The 519 has only one.
I also purchased the LPlate with my Arts TP & 516 head. This allows me to counter-weight the head over a longer distance than the regular plate, which allows for the quick addition/subtraction of accessories, lens', etc., among other needs to reweight the system.
BIG price dif between the pricey 519 & the more "modest" 516.
The other heads 501, 503, are all modified friction heads.
As they use to say in the coustume movies of several decades ago:
"Choose your weapons"!
Bruce S. Yarock August 23rd, 2004 02:02 PM
Robert,
thanks for the info. Do you know anything about the 505?
Bruce yarock
Bruce S. Yarock August 24th, 2004 02:09 AM
I've narrowed my choice down to either the 505 or the 516. they both have quick release plates. The 516 has two pan handles, but never having used one with two , I don't understand the benefit. The 505 is $110 more.
Right now I'm using a Canon GL1 with a bunch of accessories, but am planning to move up to the XL2 or the DVX100A.
Any final thoughts from you guys would be really helpfull.
Bruce Yarock
Robert J. Wolff August 25th, 2004 01:47 PM
Bruce,
As far as I can determine, the 505 might be considered "516 LITE". It does have a quick release. The only differents that I can determine, is the fact that it has, again, like some of the others, multible springs. If you need them to go to a lighter cam, fine. If you are going to change from light to heavy cameras, fine. I think the springs are the reason that the 505 is listed by you as $110 heavier in price.
Two pan handles:
You can control your cam with two hands.
I can place my EZ controller, and, "I NEED It NOW" stuff, on my handles, in any configuration that I decide, with out sacrificing smooth pan/tilt control.
Basicly, like any accessory, you have more control.
You do not mention, Bruce, if you are contemplating getting the head with a bowl??
I woud strongly suggest that you do NOT buy a TP without one. Whether you are in the studio, remote, etc., you will find that they are an absolute necessary item, just as the camera is.
Sorry for the delay in responding to you; but, it is bird migration time up here, and I am traveling from 3am onward to……?
Bruce S. Yarock August 25th, 2004 09:30 PM
<You do not mention, Bruce, if you are contemplating getting the head with a bowl??
I woud strongly suggest that you do NOT buy a TP without one. Whether you are in the studio, remote, etc., you will find that they are an absolute necessary item, just as the camera is.>
Robert,
I ordered the 505, and will get it tommorrow.two questions-
1- I was under the impression that this head has a bowl...Is that correct?
2-What is a "TP"?
thanks again
Bruce Yarock
Mike Rehmus August 25th, 2004 09:41 PM
<<<-- Originally posted by Bruce S. Yarock : I've narrowed my choice down to either the 505 or the 516. they both have quick release plates. The 516 has two pan handles, but never having used one with two , I don't understand the benefit. The 505 is $110 more.
Bruce Yarock -->>>
If you use the head in a studio setup, you need two handles on which to place the lens controls. Right handle for zoom, left handle for focus.
Robert J. Wolff August 26th, 2004 01:40 AM
TP: Tripod.
Some who are longing for days of yore, call them Sticks. Personally, I haven't used Sticks since the very eary '70's. They really were not the most stable support I have ever used.
I don't know if your new head comes with a bowl or not. I would check with your dealer, as to whether it is included with your order.
Good luck with your 505. If you need any questions answered, knock on my E-mail door.
Mike,
I will give you a very small disagreement on the pan handles. In the past I would agree with you. But, since I purchased an EZ rock controler this past spring, I find that rotating the left pan handle next to and forward of the eye piece, I can view the scene, and, at the same time, the EZ controls. Makes for less fumbling, especially with gloves on. And I do like all of my controls where I can see them.
Bruce S. Yarock August 29th, 2004 04:04 PM
Thanks for the info, guys. I got my 532art from B+H, and went with the 505 head from Adorama. What a beautifull set-up. The head is HUGE, and will handle many larger cameras ( I hope to upgrade to the xl2-lots of accessories). It's so smooth.
The tripod itself is really slick. It sets up in no time, and you can level with a button.
The only thing I wasn't ready for was the weight.Also, from the pics, I had no idea about the size of the head. i guess I won't be doing any back packing with this rig.Btw, anyone know of a good light weight rig? ( only kidding...this one tapped me out for now).
Bruce Yarock
Robert J. Wolff August 29th, 2004 04:37 PM
I back pack with mine several days a week, several miles round trip. You just learn to move a tad more slowly. Good luck with your purchase.
Matt Gettemeier August 29th, 2004 06:12 PM
Bruce... since you commented about a light rig... take a peek at the thread I've got right near this one... it's the one about the newest "cheap" Manfrotto head.
I've got a pretty high end pod, but I find myself in situations where I dread the weight and leave my tripod at home and take a monopod... just because I don't want to deal with it. Mine is 11 lbs and your's is 13.9 lbs unless you got the CF legs... I think the 532art is aluminum.
Anyway... for a "beater" pod I'm going to get one of the new 701rc2 heads and pop it on the 756b legs. Sure the head is fixed pan and tilt... but it's got fluid cartridges in it (according to Manfrotto) and a counterbalance spring... a sliding balance plate... and a quick-release plate. I'm flingin' flangin' intrigued!
For a total cost of UNDER $300 you get a pod that's SUPER light-weight (6.7 lbs TOTAL) complete with a leveler and compact folded size.
Okay if you're backpacking and you get the shot of a lifetime... like Bigfoot juggling 3 'possums by their tails... you'll wish you had your GOOD pod... but 99% of the time you'll be 2 miles up on that trail and you'll think, "hmm... the pod that's HALF this weight may have been good enough for today."
Sorry if this is OT... but you asked about a lightweight rig... and since you just tapped yourself out I thought you may appreciate the price. I'm definitely going to try one out.
Maybe in a few weeks you'll see a thread from me saying "Aaarrrghh... it's JUNK"... or maybe you'll see a thread from me saying "Aaaaah, the best $300 I ever spent"... stay tuned to find out.
Bruce S. Yarock August 29th, 2004 06:52 PM
matt,
Thanks for the info.I was joking about the "back packing"...down here in South Florida we just try to stay out of the heat. That does sound like a good deal though...Btw, my rig ( the 532 and the 505 head) weighs in at....17lbs.
later
Bruce yarock
Mike Rehmus August 29th, 2004 07:31 PM
<<<-- Originally posted by Robert J. Wolff : TP: Tripod.
Mike,
I will give you a very small disagreement on the pan handles. In the past I would agree with you. But, since I purchased an EZ rock controler this past spring, I find that rotating the left pan handle next to and forward of the eye piece, I can view the scene, and, at the same time, the EZ controls. Makes for less fumbling, especially with gloves on. And I do like all of my controls where I can see them. -->>>
Are you are doing this with a studio camera with a studio viewfinder? Or do you mean with a LOB camera?
Matt Gettemeier August 29th, 2004 09:01 PM
Bruce... 17 lbs? That thing must be solid as a rock!
I thought it was 13.9 lbs. because B&H lists the total weight of the 532art plus 505 head as only 13.9 lbs.
B&H specs listing for 532art and 505 head combo.
When I bought my tripod system I noticed that the weight wasn't listed the same everywhere I looked.
Manfrotto claims your tripod system is a total of 14.8 lbs.
532 ART legs listed as 9.7 lbs.
505 head listed as 5.1 lbs.
For a total of 14.8 lbs.
17 lbs. Wow... well the good news is you'll be built like a BSH in no time!
After only a few occasions where I had to lug around my relatively light (11 lbs... hah!) tripod... I'm gonna' get that cheap little 6.7 lbs. pod as a lightweight alternative for non-critical use in remote locations.
Robert J. Wolff August 30th, 2004 03:49 AM
Mike,
In the past with a studio/field configuration: view finder to the rear. These days, with the EZ, I am using the XL-1s in its normal "one eye" configuration.
Sorry. I should have been more specific.
