-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   Vinten Vision 3 head (https://www.dvinfo.net/forum/tripod-sticks-heads/43131-vinten-vision-3-head.html)
Vence Vida April 17th, 2005 10:50 PM
I'm considering investing in a serious head for my XL2. My Manfrotto 501 just isn't cutting it. I'm researching the possibilities and I have a question about the Vinten Vision 3:
The counter-balance spring designated by the Vinten website for the Canon XL cameras is the #2 spring. It appears, however, that spring is for cameras around 2 or 3 pounds. The XL2 is almost 8 pounds, and that's without the wide angle adaptor and the 2.5 pound ankle weight counter balance I wrap around the accessory shoe to level things out. (Works great, by the way)
Now, I realize Vinten isn't expecting an ankle weight to be attached to the camera, but why do they designate the #2 spring, even for a standard set-up of a 7.4 pound XL2? Is there something I don't' understand about the weight ratings? What size spring should I use if the actual weight is more like 10 pounds? It looks like that would be spring #5, but I'm not sure I am reading the chart correctly.
Thoughts?
K. Clark April 18th, 2005 07:11 PM
I use the Vision 6 which has an infinately variable counterbalance dial over the range of the heads capacity (9.9-22lbs). So I can always be spot on the exact needed counter balance.
The Vision 3 uses a range of interchangable springs in lieu of the more costly dial approach. I'm not sure if you are able to tweak the springs tension with a set screw or not. It would make since however.
As to the weight issue, imagine for a moment that you have zero drag and zero counterbalance on your head then you place the camera on the stage and you move it front to back until it is perfectly balanced on it's center of gravity. Now if you were to move the camera on the stage forward like 1/2" it would obviously fall forward. Now add weight to the rear of the camera in order to get it balanced in this position. Even though the camera weighs 8 lbs you will find that adding only a small amount of weight (i.e. 1/2 lb) will counterbalance it in the level position. So to answer your question, it sounds like the #2 spring is just about right.
The thing about counterbalancing is that the further your camera is off center (tilt) the more counter weight you need. Hence the spring. The more you squeez them the more resistence you get.
It is common for some camera people to try and correct improperly balanced systems by applying more tilt drag to dampen the effect of bad balance - which is not really good practice. In a perfect world you should be able to let go of your camera in any position and have it stay there - all that and still be able to point it in any direction with very little effort. Hope this helps.
Andrew Petrie April 18th, 2005 08:33 PM
I use a #4 spring in my Vision 3 for my XL1S, I added a plate for my sound devices pre-amp so it added some weight.
A bare-bones XL1 will work fine with the #2 spring, but I would probably opt for Spring #3 for most common XL1-based configurations. A 4 or higher would only be necessary if you started adding mic equipment, a mattebox, mini35 ;), etc...
K. Clark April 18th, 2005 09:56 PM
There you have it Vince.
Andrew, for my own knowledge, on the Vision 3 can the spring be adjusted in any way over a small range? Or is it just a set it and leave it kind of thing?
Vence Vida April 19th, 2005 10:06 AM
Kevin, thanks for the explanation. That makes sense. I understand what the weight rating means, now.
Andrew, excellent info. It sounds like I might need more than one spring if my set-up will vary greatly from use to use.
Rachel Oliver April 19th, 2005 01:12 PM
Hi;
I use the 5 spring with my vision 3, due to my rather heavy XL2 set up and the fact that I also use it with a heavy Bolex set up for S16mm work. It's a really lovely tripod, I smile when I use it....
Olly
Mark Sasahara April 21st, 2005 01:43 PM
The Vinten spring number refers to the camera weight in Kilograms. I have an XL2, 16x manual lens, with matte box, follow focus and I use the #6 spring. When it's stripped down, I use the #5. Depending on how your camera is configured, you'll want to have a few springs. I also got smaller springs in case I am using something like a DVX on my Vinten.
I have a tape mark on my Chrosziel bracket and a couple of marks on the top side of the tripod head. This way, I can slide the camera to the right mark and it's centered. I cut the tape so that it's a thin strip.
You can move the tripod plate around, until you find the best place for it on the camera and head. It takes a some trial and error, but once you set your marks, you can set up your camera quickly and accurately every time. I have a couple of digital photos on my Palm Pilot, so I can remember where to mount the plates and the brackets.
James Bremer April 21st, 2005 10:01 PM
Love that Vinten Spring system
I have two Vision 3's I carry six different springs in my tool box. For different Cams
But no matter what spring I use they still do not work as well as the Miller systems DS10 and DS 25.
Jimmy
Mark Sasahara April 22nd, 2005 06:39 PM
James, what weight are you loading on your Millers, what cams? Typically I've got 6Kg, or about 13Lbs.
James Bremer April 22nd, 2005 09:14 PM
Millers
Hi Mark,
I am mounting a Sony PD-170 wt.? on the DS-10
and a DSR 390L 15 lbs.& Sony 570 about 18lbs on the DS-25
I like the vision tripods also but the Carbon fiber just dose not seem as strong as the Millers. The Visions are still a good tripod for the dollar difference.
Jimmy
Vence Vida April 23rd, 2005 10:35 PM
James,
Specifically why do you prefer the Millers over the Vinten? You mention the legs seeming better on the Millers, and I've heard that in other threads here as well. I'm not sure what legs I might choose, but more often than not, the Vinten has been noted as the head of choice.
You say the Vinten is still not bad for the price difference, but the Miller DS10 is actually cheaper than the Vinten Vision 3, I believe. So if you prefer the DS10 over the Vision 3 than the price is actually a bonus for the Milller.
What do you like about the Miller? Do you feel it's smoother? How's the counter balance compare? I wish I was close to a dealer where I could compare for myself, but here in central Indiana, there is no place to try before I buy, so I am interested in commentary from those who have compared.
Vence
Paul Leung January 10th, 2007 09:31 AM
Perfect balance on Vinten Vision 3?
Hi,
This old thread touched on an issue I am interested. Can perfect balance be easily achieved on Vinten Vision 3 when it uses different springs? I am thinking to get this head for my DVX100A. I don't understand how a fixed rating spring can cover a range of loads.
Would Vision 3 owners share their experience please? Can your set up be balanced easily??
Thanks.
Mark Sasahara January 10th, 2007 12:42 PM
I'm not sure how the mechanics work for counter balance, but I believe that they use springs, just like the Vision3. I assume that they have multiple springs that can be engaged and disengaged as needed
Balance depends on the height of the camera as well as the weight. The DVX has a low weight and a very low center of gravity. Depending on what other stuff you mount on the camera, matte box, follow focus, monitor, HDD, you still have a pretty light weight, low camera. The spring's number corresponds to the weight, in Kilograms, of the camera. The #1 spring corresponds to a 1Kg (2.2 lbs) weight, all the way up to the #10 for 10 Kg weight.
Balance can be achieved by placement of the mounting plate on the camera bottom and then sliding the whole camera back and forth on the platform, with the tilt drag at 0. Lock the slide lock release, so the camera doesn't slide off the head and fall on the floor. when it doesn't move back, or forward, then it's balanced. Depending on whether or not the camera is front heavy, or back heavy, you might have to place the mount plate more forward, or rearward.
I have several springs that I use for different cameras and camera configurations on the Vision3 head. Larger heads have the counter balance adjustable by engaging multiple springs, to accommodate a wider range of camera weights. If you look at different manufacturers, you'll see what I'm talking about.
Paul Leung January 10th, 2007 06:15 PM
I mean I don't understand how it can hold when you tilt the camera in an angle and your hand just let go. For example if spring #2 can hold the DVX with a small battery in an angle perfectly, can it hold the DVX with a large battery in the same angle as well? I can understand a head with continuous spring load adjustment, such as the Vision 6, can hold anything in the specified range. However, in a simple counter balance system, it cannot imagine how it can be done. Do people dial up the drag setting in order to hold the additional weight?
I read many wonderfully stories about how great heads in this class can hold the tilt angle without applying the tilt lock.
Mark Sasahara January 10th, 2007 11:16 PM
Yes, increasing drag can help if the spring and the weight don't match. You can do that with any head, but it's best to balance it as best you can. I can usually operate and not need the locks, unless I'm walking away from the camera.
I have put marks on my head and camera plates with tape and a Sharpie, so I know where things should go, depending on the configuration of my camera rig. I also do this with rental gear too. Obviously, I'm not defacing the gear, I put tape on at the beginning of a shoot and then peel it off at wrap. This allows for faster set up and repeatablility. I will also take a digital pic and use that for reference too, if need be.
Because the DVX has a lower center of gravity (COG), I don't think it will make much of a difference. You will probably just have to slide the camera a little more one way, or another to take into account a heavier, or lighter battery.
It's when you get into taller, heavier cams that the COG becomes more critical. Accessories are heavier and there's more crap to put on the camera, so you have to be aware, especially when changing lenses, or battery types.
Jaron Berman February 9th, 2007 02:05 PM
FINALLY I picked up a Vision 3 and Miller Solo legs for myself. For those looking at this combo, here are my notes:
First, congrats. Both pieces are beyond compare in this price range.
Second, I got a Petrol PTB-1 bag, which seems like it was built for this combo, and it's one of the cheapest options in terms of padded bags. Very nice quality.
Third, between the carbon and aluminum legs, I personally found the AL legs to be stiffer. Yes, I added about a pound to my kit, but whatever. They ended up a couple hundred dollars less and with a long lens, they look stiffer. I'll try to keep them dry.
Fourth, about the head - it's fantastic. Absolutely fantastic. The only thing you gain by moving to a higher-priced head is more convenience and more weight capacity. But 22lbs is a LOT of weight. A loaded Varicam is close to 19. I'm a freelancer, and after being handed 3 sets of sticks in a row, all non-working... I got pissed and bought this combo for myself. So whether I'm on a DVX (this evening) or Varicam, I can have a perfect setup. Now that said, with larger cameras, I find that production usually has the budget to get good sticks, so it's a toss up. But for the majority of small dv/hdv/hd stuff, the Vision 3 is probably the only head I'll ever need. And even using Sachtler 18's and 25's... I have no envy. Love the Vinten!
Mark Sasahara February 9th, 2007 08:27 PM
Welcome to the Vinten family Jaron. :~)
I think you'll be very happy with the Vinten.
I've been getting Ronford legs for my Jib and I now have a set of baby legs and regular legs, O'Connor mounts. I also have a 150mm ball regular legs. I love ebay. Now I just need to drop $5000 for a decent head. Though I may inload the 150mm bowl legs.
John Cox February 21st, 2007 11:27 PM
spring confusion
I recently purchased a vision 3 head (and miller legs) for my new XH-A1 (2.3 kg with battery). Looking at Vinten's site, they recommend spring #2 for both the GL2 and the XL-H1 (and don't list the XH-A1). According to canon's site, the GL2 weighs 1.25 kg without battery. The XL-H1 weighs 3.75 kg with lens and battery. I'm confused why the GL2 doesn't call for a #1 and why the XL-H1 doesn't call for a #4. I followed their advice (I thought) and bought a #2 for my XH-A1 and it springs back up when you try to tilt it... springs with quite a bit of enthusiasm actually.
Please tell me I am missing something here... or is Vinten's info screwed up? I'm thinking I need to go back and order a #1 now. Silly me, I also bought a #3 when I got the #2 because I thought I might be pushing 3 kg when I loaded more gear on the camera and they rate their springs "up to" (spring #) kg. Maybe that was Vinten's strategy all along... to sell more $40 springs?
Pete Bauer February 22nd, 2007 05:04 AM
I purchased a Vision 3 a little over a year ago (with which I'm very happy) and when the setup I wanted was on back order due to a manufacturing issue, the retailer (a DVinfo sponsor, of course) referred me directly to Vinten. They bent over backwards to help me out, even sending a loaner by FedEx until they could fill my order. I suspect it is more a matter of just not updating the info on their web site than a plot to sell more springs. They were obviously very concerned about customer service!
So that said, I'm a little disappointed to hear that they've not gotten around to updating their spring info. During the time I had their loaner, I had direct personal phone and email contact with a Vinten rep who happily sent me various springs (2, 3, 4) to try with the then brand-new XL H1. While I was at it I tested the XL2 as well, and reported my findings back to them by email. Too bad that info didn't make it to their web site.
Anyway, to the point. For stock cameras, the XL H1 should use the #4 spring. Of course, if you have attached other gear to your camera, you'll have to adjust accordingly. At minimum tilt tension, for me this only causes subtle drift back toward level if the camera is tilted more than about +/- 20 degrees. Not at all noticeable in normal use -- and I know I can turn away without the camera unceremoniously drooping down or pointing skyward! If I remember correctly, the stock XL2 would use a #3 spring. I haven't tried the XH-A1 on that tripod; guess I should do that.
If a vendor sold you an incorrect spring based on erroneous information, they should be willing to exchange it for the correct spring.
Mark Sasahara February 22nd, 2007 12:10 PM
Center of gravity (COG) plays a part in which spring you use. If your camera is low and has a low COG, then it may not need as strong a spring as you think.
With the drag set at zero, try the springs you have. Slide the tripod plate back and forth and see if that alleviates the problem. If not, then you may need the #1 spring. Be sure to lock the plate down when tillting.
John Cox February 22nd, 2007 05:16 PM
Raising the center of gravity certainly seems to make a big difference. My TA-100 adapter plate came today and with that added height and additional 1lb of weight I am able to balance the camera to stay put at any angle using the #2 spring and no drag.
Now the only problem I'm running into is the smoothness of the head when tilting. There is a definite sticky spot when tilting the lens down. It happens on the way down and back up at approximately 45 degrees. It is most noticable with no drag, and gets less noticable the more drag I add.
Can anyone tell me if this is:
1. a known behavior of the vision 3
2. a defect
3. me doing something wrong
Thanks again.
Pete Bauer February 22nd, 2007 07:30 PM
Nope, no sticky spots. If that's the case, I'd recommend having them check it out.
Jimmy Alioto February 25th, 2007 10:26 PM
Vision 3 Head
I am looking at the Vision 3 head and Miller Solo sticks and I am wondering is their anyone using this setup with the HVX 200? If so, which springs are you using? For now, I will only have the weight of my camera, battery, camera light, wireless receiver.
Thanks, Jimmy
Floris van Eck March 5th, 2007 03:07 PM
So for the Canon XL-H1, would I need a #3 or #4 spring? Vinten itself recommends a #2 spring but I cannot imagine that this will work. The camera weighs 3.75kg and I have a TA-100 tripod plate (not sure how much it weighs). But if the camera springs up with a #4, it means I need a #3 probably. But I cannot imagine it will work with a #2 (judging their own specificatons).
Floris van Eck March 5th, 2007 03:15 PM
With which legs is everyone using the Vinten Vision 3 head? How good are the Vinten pozi-loc 75mm legs supplied in the kits? I am thinking about a Miller/Gitzo 3-stage carbon fiber tripod (Gitzo 3540XLS or Miller 1505) as they can go anywhere from 200cm to 10cm in every imaginable situation. This is not possible with regular video tripods and for documentary (which I plan to do most) and wildlife/nature I think that is the way to go.
