-   Under Water, Over Land (https://www.dvinfo.net/forum/under-water-over-land/)
-   -   Spider Timelapse (https://www.dvinfo.net/forum/under-water-over-land/511786-spider-timelapse.html)
David Elkins October 31st, 2012 08:29 AM
Spider Timelapse
For your Halloween pleasure. Posted this in "Show Your Work" but thought some over here may enjoy too.
Mike Sims October 31st, 2012 02:08 PM
Re: Spider Timelapse
Nice one, David. What did you shoot this one with?
Oren Arieli October 31st, 2012 06:15 PM
Nicely done...but I think my head is still spinning.
David Elkins November 1st, 2012 12:09 AM
Thanks, Mike. Shot it with a 5D with a 24-70mm and a 60D with a 70-200mm.
Mike Sims November 1st, 2012 07:38 AM
Thanks, I found the cameras and lenses on the Vimeo page but I’m really curious how you lit it. Is that camera flash, studio flash or continuous lighting? It looks very consistent from shot to shot.
David Elkins November 1st, 2012 11:38 AM
1 Attachment(s)
I used continuous lighting. 2 Lowell 250s, no diffusion, set low and at about 90 degrees from the cameras close to parallel with the web. The trick was getting her to build the web in a pre-set spot. I solved that by setting up a C-stand on the camera right side raised all the way up that would serve as the anchor point each night. I had to make sure that was the only possible spot for her to anchor to, otherwise she just lets the silk fly and whatever it happens to catch becomes the anchor. Here is a pic of the set-up.
Mike Sims November 1st, 2012 02:57 PM
Thanks! Pretty ingenious using “spider psychology”. I like the use of the black backdrop.
Kenneth Burgener November 11th, 2012 08:45 AM
Great film, but I would have put a close up of the spider at the end, so we could see the little guy.
Ken
Dale Guthormsen November 11th, 2012 12:48 PM
Pretty cool, well thought out and yes I too would like to have seen the spider up close.
Dale
