-   The View: Video Display Hardware and Software (https://www.dvinfo.net/forum/view-video-display-hardware-software/)
-   -   Defective LCD or User Error? (https://www.dvinfo.net/forum/view-video-display-hardware-software/60718-defective-lcd-user-error.html)
Frank Pietrantoni February 14th, 2006 08:34 PM
Hey all,
I just ordered/recieved a new Delvcam 5.6 LCD. I hooked it up to my PD170 using an RCA to mini cable, and then set the cam's display to V-OUT/LCD.
I powered up the Delvcam, but there is no display at all...not even any shadowing when cranking up/down brightness and contrast controls.
I also noticed that the screen flashes and then goes dark, but the power LED stays on.
I think this may be a dumb question but...do you think this is a defective unit, or is my cable configuration at fault? Any thoughts are appreciated. Thanks.
Frank Pietrantoni February 15th, 2006 12:25 AM
I think I found the problem...I found that if I pull the plug about half way out of the camera, the monitor works fine. Apparently, the cord I purchased is an audio cable (albeit with mono plug) and I need to get a cable intended for video signal.
