Using a Flat Screen TV in Storefront Window
I couldn't find another section to post this thread so here I am.....hopefully I can get some good advice.
I want to mount a flat screen tv in a storefront window for advertising reasons(my girlfriend's storefront). There will be looping ads displayed. My question is: Will the direct sunlight cause damage to the TV? I'm not sure what type of TV we will get but it will be a flat screen-wall mountable type. My concern is direct sunlight on the tv. Any help is appreciated. Thanks- Joe |
I guess it depends on how hot the environment gets and how many hours of direct sunlight. Plasma screens are pretty visible in bright rooms. I had mine in an all-glass porch for two years with no problems. I know that extended periods of direct sun will age things like plastic, but I suspect it would take years before you have a problem. Of course high temperatures can damage electronics and warp plastic. Check the specs on your TV for the environmental operating temperature range, then put a thermometer in the store window and see if you will have a problem.
Your mileage may vary... |
| All times are GMT -6. The time now is 10:56 PM. |
