The reason I dont want a cable running is the safety issue and I have to tape about 200' of cord to the ground, too time consuming.
I don't know the Azden bodypack but the Sennheisers have a screwed 1/8 jack input and cables can be bought or made up to go to 1/4 TRS. Does your transmitter have a line/mic impedance switch or failing that, a gain control? If not, you may have problems with clipping or distortion when you connect a line input. You might even fry the bodypack if its a really hot signal from the board - not supposed to happen but it has been known. |
If possible, use the Azden, even if it doesn't produce the best results. The best audio will come from a CD of the music mixed during post production while using the Audio from the board as reference.
I once used the CD when I received a bad signal from the board. Since then, it is all I use. I don't even try to get a clean recording of the music, just a clear sync with the performers. |
| All times are GMT -6. The time now is 09:31 PM. |
