Getting Started
Hi all:
This is my first post here on the DVI forum. I am extremely new to the videography arena, but a seasoned wedding photographer. We are looking to add video to our arsenal eventually, and I am in the initial stages of researching & planning our business. A few questions for you guys: 1) Software -- If we are going to be editing on a PC platform, what is the software system of choice? My assumption is that Adobe rules the video world the same way they rule the photography world. Any advice on software? 2) Camera -- We are Canon shooters...the XH-A1 seems to be the camera of choice for many of you. Is this the best all around choice? 3) Flying Gear -- there seems to be two choices for flying...the Glidecam 4000 and the Stedicam system. If budget was not an issue, which one would you choose? Thanks in advance! I'll have lots of questions for you guys! Thanks for allowing me to join your forum! ~ Charles |
Hi Charles - welcome!
Boy that's a big question you've got there <wink>! You'll find that there are lots of options, and pros and cons of each - probably not dissimilar to the different still cameras and post/editing options. Budget is a consideration, to some degree... but it looks like you've got a pretty healthy set of choices picked out already. I'll just toss out what I use... Sony Vegas 8 Pro for editing - PC based, works for me... it's a tool Also Sony cameras, work for me, but used Canons and Panasonics once in a while - Sony just works for me, but again, it's just a tool. Panasonic has a new cam coming out that looks pretty sweet too... Flying gear - I use an agglomeration of various cheap approaches to stabilizing my cameras for motion shots, including an older mini-steadicam copy that is pretty good with smaller cameras handheld (light enough to fly without an arm for short shots, and machined to really tight tolerances!). For a "real rig", I'd go Steadicam with a full vest and arm... if the budget was there... As far as "add"ing video, keep in mind it's a whole other level and will require some extra bodies running about for a shoot, bodies with some pretty specific skills no less - the tools are about 1/10th of the equation (OK, MAYBE a bit more than that?). |
I'll 2nd Dave. While everything we use is simply a 'tool' it becomes a personal preference.
I too use Vegas, have since version 2 but I've used just about every other NLE out there. I just happen to like Vegas. As for cameras, I've used 'em all. Pannys,JVC Canon but I'm a Sony kinda guy. Just my preference. As for flying, frankly if you are going to do that, I would go with something like a real Steadicam. Pilot should do you fine. The GC is a handheld unit and can be very tiresome physically after a while however there is a rather large difference in cost. Also it's a specialty tool that is generally not used for an entire event although I do know people that use them for the entire reception. Good luck Don |
Thanks for the welcome Dave!
Yeah -- I realized this was a fairly open ended question, but I figured I had to start somewhere! :-) Thanks for the recommend on the Sony Vegas 8 Pro software. That is a new one I haven't come across yet. Here is a short list of PC based applications I had uncovered: Adobe Premiere Pro CS3 Adobe After Effects CS3 Avid Xpress Pro/Media Composer So adding Sony Vegas Pro 8 to that list...here is a spinoff question: If you could start over right now with an unlimited budget for hardware & software...would you still be editing on a PC, or would you go the Mac route and use Final Cut Pro? ~ Charles |
Thanks Don! I appreciate the feedback!
WOW -- yes, there is quite a cost differential! I guess that's why the Merlin & GC systems are far more popular. Have you ever had a chance to use the Pilot system before? Do you know how much of a quality differential there is between something like the GC and the Pilot? ~ Charles Quote:
Charles, I would download some trials of editing software and see what feels best for you. Only if you want to use FCP the only thing that's left is to buy a mac. Every editing suite has it pro and cons but most professional ones handle the job these days. I use adobe's collection and what I like most about it is how every program interacts with the other. Especially the Encore and Photoshop interaction gives you a lot of designing possibilities to create great dvd menus'.
About camera, actually any HD camera in the prosumer class will do but for each camera you have to consider how your workflow will be and make sure you NLE supports it. Also build or buy your pc after you decided which editing software you choose and follow the specs that are given by the editing software manufacturer. In the SD time it was real easy but now you have so many different formats and each requires a different approach. The xh-a1 does deliver the best bang for buck but expect a steep learning curve, it's not a toy camera. It does have some semi to full auto modes but each with stupid limitations so you have to learn how to operate it manually to get the best from it. As for flying gear, since your new to it, first walk, then fly. I'd suggest get all the bare essentials like camera, backup camera, pc or mac, editing software, good tripod, good mic for your camera and wireless mic's and get to know your equipment. Once you master all that, then think about flying gear, 35mm adapters or whatever will add value to your image. For starters they do not matter, it's the man/woman behind the camera that will make the difference. |
However again it is costly, takes lots of practice and is not necessarily something that would be on the must have list. As Noa said walk before you fly unless it's 100% necessary. Cameras, audio gear (don't skimp here it's be with you longer than the cameras), software and computer (build it bigger) camera lighting..invest wisely and with care but remember they are only tools. I came from deck to deck lineal editing and frankly have never been a Mac guy. Nothing wrong with it but I'm far more comfortable on a PC. If you use a PC now for Photoshop work on your stills I would stay with it if you use a Mac now stay with it. ALL of the NLEs today will pretty much do what you need to produce a quality porduct. It's a matter of which one are you most comfortable with. Don |
Only thing I would add to the excellent advice already put forth. Tripod and head. Don't scrimp in this department. Coming from the stills side, you might get sticker shock but believe me, like audio gear, a good counterbalanced, fluid head and sticks will get you through several cameras. Buttery smooth camera moves don't come from cheap heads.
Best of luck, -gb- |
this tripod could give you buttersmooth motion for sure. |
2) I've always used sony, cameras, starting from PD's and DSR's, I've tried A1 for some time, didn't work for me, went back to sony, I like :), even with that rolling shutter I still prefer sony. 3) it depends on the camera you wanna fly, for smaller cams like A1 hand held Merlin is just perfect, it's small, light and quick to setup, I wish that EX1 would be the size of PD150 so I can fly it on merlin, now I'm using Merlin arm and vest with the indicam sled on it, it's not too bad, but I'm upgrading to Pilot. it's the same rule - you're always get what you pay for; best of luck, |
Thanks Greg -- this is probably a lot different for you guys. We handhold for 99% of our shots, only using tripods in tricky nighttime situations, or in dismal dark churches when we absolutely have to.
That is a great tip! ~ Charles Quote:
Charles - alarm bells are ringing for me because you've said nothing at all about sound. Others here have mentioned it, but you've not yet picked up on it.
A major aspect to video, as you obviously will know! Clearly WAY higher priority than flying gear! |
LOL! You are so correct Martin! Flying is way cooler than sound! :-) Just kidding...
In all seriousness, I've heared that Sennheiser is a good choice all around for wireless mics. Any thoughts on that? ~ Charles Quote:
Senns are good as are Audio Technica and for a bigger price tag Lectros.
I use the AT 1800 series dual channle receiver mic the groom and the lectern and it's never failed me yet. Audio is 70% of what we see so work with whatever audio gear you decide on and get to know it inside and out before putting it into play. Great audio can help make average footage better but bad audio will take the best footage ever and make it bad. (pysiclogical thing) O|O \__/ Don |
As to the coolest place to spend your money - to rephrase what Don says: Good sound will go almost unnoticed (as clients expect it), and it will contribute to a great result. However, poor sound will instantly brand you as a beginner/amateur. |
We have one cam with a Sennheiser Shotgun mic and the other has the Wireless G2. I cant tell you how good it is to have 2 different sources and sometimes mix them both to give a much richer sound.
Sometimes the wireless lav mic picks up things far away the shotgun seems to have missed. Just dont do what I did and ensure the groom knows about the mute button. Suprise toilet trips can be weird. |
Another vote for Vegas Pro8.
And don't forget the Quad core machine for HDV editing power. And a CF recorder. Go with Lectrosonics 100 series for wireless. Don't forget weddings are a two camera shoot. As others said, you can't underestimate the need for a good tripod ($1,500+). |
That is a good point. Just like everyone starts out, we're going to have to start with one main camera, and a small backup.
But it does seem like the industry is moving towards teams for most parts of the day. ~ Charles Quote:
Excellent advice there! Thanks Martin!
In the photography world, we say the exact same thing about lenses. The bodies seem to change every 3 months, but we've been using the same lenses now for 4 years without any need to change whatsoever. ~ Charles Quote:
Two follow ups for you Jeff...
1) What is a CF recorder? 2) You prefer the Lectrosonics to the Sennheisers...any particular reason why? ~ Charles Quote:
Thanks Noa!
I actually had a chance to play with the XH-A1...is was kinda like riding a bicycle. Our knowledge of aperture, exposure, focal points, composition, shutter speed, and ISO (gain) all seem to transfer pretty naturally. Of course, I will definately put everything through its paces before taking any sort of paying gig, but I didn't feel uncomfortable at all! Are you an XH-A1 user? ~ Charles Quote:
2. The Lectrosonics sounds better, has better range and seems to reject any interference and drop outs better. The Sennheisers are certainly the best value there is, no doubt. Some things are better with the Senns like the controls. If you put a Tram mic on the Senn, it would probably sound much better, but then you would have spent what the LS 100 series costs. |
| All times are GMT -6. The time now is 02:00 AM. |
