DVX100A suitable for shooting weddings?
I'm shopping for an event camcorder; weddings and Bar Mitzvahs. Is the DVX100A a good tool for capturing weddings?
I'm concerned that the lens' zoom range is insufficient in a large church. Also, given the lack of exterior space on the camcorder, what's best place for a wireless receiver, camera light and battery? And finally, if the DVX100A isn't a good tool, what other camcorders are good for weddings? I've used the DVC200...a wonderful camcorder for weddings...but my budget isn't that generous. Any help would be appreciated. Thank you. Bob |
Since almost all the weddings I've done ended up in a dimly lit reception hall with the admonishment to not use much or any light, I'd have been in deep trouble without my PD-150. It always brings back good images in bad situations.
depends the way you are working.
shoulder camera is far superior in situation where you have to move. on the other hands you can buil a shoulder support for any camera, including advantages (wheigth, enhancements) not found in bigger model. While the pana is among (if not) the best camera, it gives its best in controlled environment, when you got some time to master the setting. As far as i know, weddings like all real life/real time event are not a place for "all manual " behavior unless you knows very well your camera. That is why a would suggest a PD150/170 , who provides better automatism, while keeping an excellent picture and offers excellent low light sensitivity. Add some wide angle (canon WD58) a wireless mic (the sony one -UWP... i do not remember the model) and let's go. If you need a better tool, the next step would be a sony 250 or 300 but the range of price is totally different. |
If your doing soley wedding videography there NOTHING better than the PD-170 and/or VX2100 in it's price range...period.
I occasionally shoot weddings with a fellow. He uses a DVX and I a PD170. His 24p gamma stuff in good light is so often stellar, it's hard not to swoon (with a little bit envy), but so too is he clearly happy to be working with me in those cavernous churches, and during those evening reception parties (even after he has switched to the more light sensitive 60i setting). So perhaps it can be said that in less than controllable lighting situations, the DVX will often give you exceptional images, while the PD170 will more often deliver very good images.
And then add on top of that a longer zoom, a more favored stabilization system, and an LCD screen that can be seen in daylight. |
<<<-- So perhaps it can be said that in less than controllable lighting situations, the DVX will often give you exceptional images, while the PD170 will more often deliver very good images.
-->>> The point that the PD-170 is much more sensitive to light is a fact. The point that, in controllable lighting situations, the DVX will give you "exeptiona"l images while the PD-170 will offer "good" images is an opinion. Before purchasing the 170 and VX21k I shot with a DVX100 and I firmly feel the 170 produces a more favorable image with more neutral color rendition...to my eye at least. The look of cinegamma is easily reproduced using color curves in post. Lastly in cinegamma there is a small amount of highlight compression. The really bright highlights seem to overexpose a bit early. Even though it IS opinion I'll post stills captured from my 170 footage to compare against stills from the DVX w/ cinegama any day of the week. That way others can make their subjective opinion. |
Well, I did mean "very good" and "exceptional" mostly with regard to light sensitivity, and that the DVX is much more tweakable than is the 170.
Also, opinions count too here, but thanks for your concern. |
My experience
I am shooting weddings with the DVX100a and have been very happy.
A few things which helped: - modified one of the 24p cinegamma scenes to 60i while keeping the cinegamma color settings. This gave me the best of both worlds - fast 60i autofocus and light sensitivity and the incredible colors of the cinegamma. - I am in Southern California and the built-in ND filter proved to be very valuable. - made sure to have the iris on manual to avoid it being confused by quick changes in light intensity (this is not specific to this camera, but important for events with lots of uncontrolled light). Regards, -- Andre |
PD170 stepped iris
To capture weddings, many of you suggested the PD170 yet I understand that the manual iris is controlled in steps. Is that correct?
Bob |
Every camera's iris is controlled in steps. However it is indeed visible if tweaking your iris while shooting. Less as much compared to the 150 though- they supposedly added twice the amount of steps for the iris dial on the 170 to help smooth the transitions when dialing the iris.
DVX100A stepped iris?
Does the DVX100A also have a stepped iris in manual mode?
Outside of controlled situations, I always ride the iris to manage the continuously changing light levels in weddings and other events. It would be my preference to shoot with a seamless iris control. Bob |
The manual iris on the DVX100A is about as seamless as it gets!
DVX100A, wireless receiver and camera light.
I'm considering a DVX100A to capture weddings. Can a wireless mic receiver be attached to that camcorder? And what are options for using a separate camera light with battery?
Thanks, Bob |
Bob, a wireless reciever can be attached to ANY camcorder really. Some of them offer a shoe-mount like my Sony UWP-C1 system and the new Senheisser system. If not they either velcro it to the side of the camera...an idea I've never been fond of...or buy a bracket that connects to the bottom of the camera and extends to the side for the mounting of the reciever.
If your sole use of this camera will be shooting weddings the PD-170 is a much better choice...and I doubt many will argue that fact. It's the most popular camera in event/wedding videography for a reason. I've shot with GL-1s, XL-1s's, DVC-80's, and DVX100's and the PD-170 is BY FAR the best suited for this genre bar none. |
****DVX100A suitable for shooting weddings?*****
Suitable yes, ideal, no. |
yes
i use 2 of the and have never had an issue |
In other words...YES, but there are better choices available.
its all about taste, opinion and what works for you.
with what i do weddings and corp events, i love the in-depth control i have of the cam on the fly. Smooth iris and aperture adjustments as oppsed to stepped as seen on teh sony and Canon equivalent. Image performance is incredible, in low light here in Pal land, the results are much cleaner than the PD/VX/DSR2xx and XL cams. I cant comment on the NTSC models. Progressive scan offers a nice rich imaging alternative to your norm interlaced flavoured video. Incredible audio control and recording cleanliness, great physical balance, nice wide angle lense which doesnt make it front heavy, huge monitor which displays EVERYTHING, fat viewfinder and plenty more features ... etc etc etc so yeah, as i said, i have two of them and have never had an issue cant wait for the Panny HDV unit.. hehehehe (ssssshhhhhhhhhh i cant talk about it!) |
<<<-- cant wait for the Panny HDV unit.. hehehehe (ssssshhhhhhhhhh i cant talk about it!) -->>>
Oh, c'mon now, you can't do that to us. Spill it! I just know it's going to be worth passing on the Sony (and all others) to wait for Panny's HD offering. Just as with the DVX, Panasonic will take the format to its limit. |
| All times are GMT -6. The time now is 02:28 AM. |
