The groom accidentally unplugged his mic during the vows
[Edit: Title should read: "The groom accidentally unplugged his mic *before* the vows"]
We've been editing more wedding videos, and tonight I just noticed that the audio from a groom's lapel mic ends while he's hugging someone just before the ceremony starts... He must have accidentally unplugged the mic when he hugged whomever he was hugging. *sigh* We were in a very strict church and didn't have any other mics within range for the vows. Has anyone else had something like this happen? How did you explain it to the couple? Before our next wedding I'm going to make sure we have several mics within range of the vows. |
It's good to wear headphones while recording. Then if that happens, just interupt the ceremony with a smile .. make a joke out of it and reconnect the lav.
Look into the possibility of getting the groom to do some ADR .. you'd need some church tone. Even if he gets close, edit it and slide into place on the timeline. HTH Cheers.
Support your local movie theatre, they need it. |
we put two mics on the groom. one is wireless and the other is olympus recorder. very happy and secured.
If a picture is worth a thousand words, what about motion picture? website: www.papercranes.com.au | blog: www.weddingvideosydney.net |
Susanta, that's a very good idea. I think I'll do that from now on. We've got recorders to spare, might as well have them on "just in case".
Allan, I'll definitely propose that to him. He's on the opposite side of the country, but I could always send him one of our digital recorders to use. If he did a couple takes while watching the video from the vows, it'd probably get close enough that I could sync it. Thanks |
#5 |
was this connection a mini pin type? If it is, you could try a little gaffers tape to hold the connection in place. One more reason I don't like non XLR connections. At the very least it would be nice if it was a locking pin, the kind that has a cap and screws onto the post.
What do I know? I'm just a video-O-grafer. Don |
#6 |
Hi Kevin
You are certainly having undeserved problems!! Yes the plug can easily come out!! What I do is cut off the mic jack plug and solder the mic lead directly inside my transmitter. I know it's a drastic move but after the groom had signed the register, he sat on the transmitter and ripped the plug out so I had no audio from it when the couple were presented to the guests. However I use a Rode Videomic on the camera which saved my bacon!!! As Allan says monitor your audio !! I shoot on my own with two cams but I use a Bluetooth headphone setup on the main camera so I can keep track of audio whilst shooting cutaways!!! The golden rule for weddings is always have two of everything and if you can, a backup for the backup!! John in Perth here had to do a "vows redo" last month when he accidentally didn't turn the DVR on !! I would talk to the couple and ask really nicely if they would mind repeating the vows. With some reallly nice sweet talk, you might even get the priest to do a dummy vows one evening at the venue???? I have actually asked for a ceremony to be halted once (civil one) and the couple were more than happy to "do it again for the video". Our problem was a terrible amount of flies in the gazebo...we did it all again in the garden and they had an awesome video!!! Chris |
#7 |
hey chris are you saying you stopped the ceremony and asked if they would move locations to the garden or you stopped them and asked them to repeat the vows in the garden afterwards?
#8 |
Hi David
They did the entire ceremony to comply with legal requirements (together with the 32 million unwanted guests...the flies!!!) and then we actually moved the B&G (and the guests too!!!) outside into the garden and did the whole thing again!!! Just for the video!! Remember our civil ceremonies are a mere 15 minutes so everyone was more than happy to do it twice... not just repeating of vows but everything except the signing of documents (which was moved outside after the first ceremony anyway) The actual initial shoot had no technical problems at all apart from thousands of unwanted critters buzzing around (and even inside my lens hoods!!) I still have both ceremonies on my drive too!!! Our civil ceremonies are pretty laid back here so (although it's never happened) if you noticed loss of audio I'm sure you could sneak up to the groom and just plug the mic cable back in before the vows anyway and then do some creative editing to get yourself out of the shot. Obviously you do need to make sure audio IS OK prior to the start!!! ... and at a formal Church service it would have been totally impossible. It was just a unique situation and a very understanding officiant, bride and groom who wanted the best video ever!! In Kevin's case his only real option is to do a repeat of the vows (ideally with the priest/officiant too!!) Chris |
#9 |
Like Don, I wouldn''t use a transmitter that didn't have locking connectors - ours use Lemos - our Boundary layer mics are miniature XLRs.
Chris, the only problem with cutting the mic cable is that with many - Sennheiser MKE2-4 for instance the cable length is critical for impedance matching (so my guru at Granada TV tells me) so cut with caution - or a least as little waste as possible. It was a situation I came across when I bought an MKE2.-4 without a connector rather than one fitted with a Lemo. Finally, regardless of what solution we use the important thing is to get the sound right. Not many of us has Chris's hudspah. |
#10 |
My experience
I had a similar horrible experience recently. I was shooting a Jewish wedding and 10 seconds after the ceremony started, the rabbi adjusted the lav microphone clipped to her lapel (she was moving it down on her lapel because she was singing). 10 seconds after that it feel and she stepped on it!!!
#11 |
Ouch. There was no reason for her to move it except her own need to feel like it had to be done. How badly did she damage the mic and did you bill her for it.
When I mic an officiant I emphasize to them that once I place it please do not touch it as it's set where it needs to be. I say it with a smile on my face but with that parental voice to make them understand "don't touch it".
#12 |
luckily wasn't my problem
Normally I mic the officiant with my equipment, but for this reason the DJ was doing all the audio because they needed 4 of them set up for the speaker system (lav for the rabbi, lav for groom, hand held for a singer that was moving around, and hand held for the readers with no podium).
I spoke with the family about this beforehand and we all agreed that I was going to tap into the DJs system. I did just that and everything was great, until the mic fell and got stepped on! So not only did my audio suffer, but no one in the audience could hear anything. The family knew what happened and they were very understanding. I think the mic was destroyed and the DJ billed the family. |
#13 |
I had a similar experience recently, except my recorder was plugged into the DJ sound board, and he forgot to hit some sort of pass-through record button until half way through the ceremony. I had my DSLR audio which is absolutely horrible, and then I ran across a problem where I had to start/stop the camera and missed the bride saying "I Will" from all my audio tracks.
I also had another wedding where the officiant kept resting his bible on top of the microphone stand. Which doesn't sound to good when it hits. Next time i'm going to attach an h4n to my camera rig i believe, and then probably have another 1 or two h1's zip tied near the action to make sure I have redundant audio. |
#14 |
Pauls post is a perfect example of why in all my years I DO NOT plug into the DJs board. The DJ forgot to press a button. Hmmm OK he apologizes to us but it doen't negate the fact that a certain amount of the ceremony was missed, as well as part of the vows. So now when we go to the B&G and try to explain to them why it was missed they think to themselves if not say out loud "oh so you're trying to blame someone else". If you run you own audio, whether it's wireless or stand alone recorders or a combination of both, if there is a screw up then you've got no one to blame but yourself and then you stand up to the B&G and say "I screwed up-not the DJ or the officiant or anyone else but ME" and believe me we've all done it and if you haven't then you will or you're lying. EVERYONE screws up, no one tries to but it happens. Sometimes it no harm no foul sometimes it's a killer but it happens.
Anyway that's why I don't plug into any sound board except when I'm doing a seminar. At weddings and other live events it's a non starter for me. I trust my wireless implicately and while I won't say I've never had a problem I will say it's never been a major problem at a critical time.
#15 |
