-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   Good wide angle lens for reception? (https://www.dvinfo.net/forum/wedding-event-videography-techniques/497567-good-wide-angle-lens-reception.html)
Michael Clark June 23rd, 2011 10:58 AM
I've made the switch to shooting DSLR for weddings (still using Canon HV40 as C-cam, but mainly using two 60d bodies). I'm slowing trying to build my lenses up, as I can afford to do so. Right now I've got the two kit 18-55mm 3.5 lenses that I don't hardly ever use, a Canon 50mm 1.4, and a Sigma 70-200 2.8. At receptions when the lights are typically low, I try to use the 1.4 and the 2.8 as much as possible without using an external light. I need a wide angle lens (30mm or below), but am having a hard time. I see a Sigma 17-70 2.8 that I'm interested in, and a Sigma 20 1.8, which is $180 more. Is the 1.8 really that much more worth it? I think I'm more interested in the 17-70 to have the zoom (gets so frustrating to navigate around my 50 1.4 on a tripod!), but want to stay sensitive to the low light issue. My kit lenses are 3.5 and the 17-70 are 2.8 - does the 0.7 really make that much of a difference? I realize I'm already shooting the 70-200 2.8, but wasn't sure if it was comparable in low light since it's a larger zoom. Sorry for all the questions, but I'd appreciate any feedback!
Art Varga June 23rd, 2011 11:53 AM
Re: Good wide angle lens for reception?
Michael - I just recently acquired a 24 1.4 L. It is now my go-to lens for receptions. Even with some lighting I find I have to stay below 2.8 to get decent exposure. So this lens coupled with my old Nikon 50 1.4 and 85 1.8 seem to get the job done when I'm dealing with a dark venue.
Art
Michael Clark June 23rd, 2011 12:25 PM
Thanks for the quick response! I'd definitely love to have one of those. I'm looking for something under $800 if possible though.
Bill Engeler June 23rd, 2011 01:39 PM
Save up. The 24 f1.4 is worth it. Beautiful images, great color when there is no light.
Jeff Harper June 23rd, 2011 01:42 PM
Sigma zoom would be a logical choice. F/2.8 is decent. Canon equivalent costs around, what, $1500 or so? So the Sigma's really are a good value. That Sigma will also be useful for general purposes outdoors as well. I would run the 50mm and the Sigma zoom at receptions and for the most part you'd be covered.
Not as wide, but a decent lens and good value would be a Tamron 28-75mm F/2.8. Not as nice as the Sigma, and not the wide you're looking for, but costs significantly less than the Sigma equivalent. I have a Sigma 18-50 and the Tamron as well, both have their uses with F/2.8 all the way through.
The Tamron is good for first dances, you get a bit tighter with it than with the Sigma, but I suppose you have that covered with your present zoom.
Mark Von Lanken June 23rd, 2011 02:01 PM
We shoot our receptions with fast primes on 60Ds. The only exception is the Tokina 11-16 2.8, but when it's really dark, that lens gets limited use. Zooms are more convenient, but generally are limited to 2.8. Unless you are shooting with a 5D MkII or GH2, ISO limitations really hurt 2.8 lenses at dark receptions.
The Canon 24mm 1.4 is awesome, but it better be at $1700. There are a few lower cost alternatives, for fast and wide, especially for video. Sigma 20mm 1.8 which can be found on eBay for as little as $350-400. Sigma also has a 24mm and 30mm that are fast, but I do not have any experience with either lens.
Another option is going the Vintage glass route. A Nikon 24mm 2.0, which runs between $300-500. Vivitar also makes a 24mm 2.0 in a Nikon mount and Pentax mount and can be found for much less than the Nikon brand. With either of these lenses you just add a Nikon or Pentax K to EOS adapter. Speaking of adapters, you can also get the Sigma 20mm 1.8 in a Nikon mount and it has a physical aperture ring, so you just need to add the Nikon to EOS adapter. I did this so I had options if I chose to shoot with a Panny GH2.
Jeff Harper June 23rd, 2011 02:17 PM
Mark, Michael, I can vouch for the Sigma 30mm F/1.4. I've had both the Canon mount, and now the Oympus mount for my GH2/GH1s, and it's a fine lens. It matches well with the Panasonic 20mm F/1.7 ($399). Unfortunately for my GH2 it's effectively 60mm, a slightly odd angle, but nevertheless is quite effective in many situations.
I've taken to putting 2-3 LEDs up high on stands, so while the F/2.8 zoom lenses aren't as great as the primes with sufficient light the F/2.8 ends up working fine at least for dancing. I'm running all GH1s and GH2s, no conventional video cameras, so I'm running so many cameras it's plain stupid. As I get better with them I will be able to ditch a couple and stick with two or three.
Sigmund Reboquio June 23rd, 2011 02:22 PM
you also might want to get a 5D, which is good in low light than 60d.
and a 16-35mm wide is good for all purpose
John Wiley June 23rd, 2011 05:49 PM
The Sigma 17-70 is not a constant aperture lens. It will only be at f/2.8 when used at the widest zoom setting, and will stop down to f/4 if you zoom in. The Sigma 24-70 f/2.8 is constant aperture, but much more expensive and less wide.
A much better choice would be somthing like the Tarmon 17-50 f/2.8 or the Sigma 18-50 f/2.8. You could pair either one of these with something like the Sigma 20mm f/1.8, or 30mm f/1.4 and then for a total outlay of around $800 you have the abilty to zoom in dark receptions or go to the faster prime when it really gets dark.
Jim Snow June 23rd, 2011 07:39 PM
I agree with Mark. Fast primes are the way to go for receptions. In my opinion, f2.8 isn't fast enough for dim reception lighting in many cases. With small cameras, it's much easier to move around so the need to zoom is much less.
Johannes Soetandi June 23rd, 2011 10:58 PM
Originally Posted by Jim Snow (Post 1661215)
Fast primes are the way to go for receptions. In my opinion, f2.8 isn't fast enough for dim ceremony lighting in many cases.
+1 on that. I very rarely use f2.8 on reception unless its on a 5D where I can crank the ISO to 2400. But with the 7D, I need atleast f2.0 to stay within ISO1250.
Philip Howells June 24th, 2011 01:06 AM
Michael, to help with your original question you need to understand the relationship between f stops. These lists might help:
Typical one-half-stop f-number scale
f/# 1.0 1.2 1.4 1.7 2 2.4 2.8 3.3 4 4.8 5.6 6.7 8 9.5 11 13 16 19 22
Typical one-third-stop f-number scale
f/# 1.0 1.1 1.2 1.4 1.6 1.8 2 2.2 2.5 2.8 3.2 3.5 4 4.5 5.0 5.6 6.3 7.1 8 9 10 11 13 14 16 18 20 22
Since a full stop variation will double or halve the exposure you can see what the choices you have will offer in simple performance terms.
So when you ask " .... a Sigma 17-70 2.8 that I'm interested in, and a Sigma 20 1.8, which is $180 more. Is the 1.8 really that much more worth it?" you can see that in terms of simple exposure performance the 1.8 will allow you an extra 1 and 1/3 times as much exposure.
However, there are many other factors you need to consider that anyone who's worked in still photography will tell you. The performance of lenses at full aperture is not best; the typical optimum is a couple of stops lower. Performance in that case means focus, spherical and chromatic abberation etc and especially at the edges.
Finally, although there's no disputing Mark's claim regarding the price of "vintage" lenses you should remember that lens and especially glass technology has come a huge way. I collect metal Minolta cameras and consequently have a heap of old Minolta glass. I loved Minolta lenses, they were sharp but not clinically so and great for portraiture. But, take any collection of old glass and you'll see that the actual diameter of the glass reduced for the same speed lens once modern multi-coatings came along. And that was with top-name branded glass. I wouldn't give you tuppence for old Vivitar, Sigma, Tamron etc lenses and anyone who worked with the stuff in those days will know why.
In general, there's a very good reason why branded glass costs more; it's better.
Jeff Harper June 24th, 2011 02:51 AM
I don't know about discounting vintage lenses wholesale, Phillip. My Canon FD mounts are quite good, and Mark had specifically mentioned Nikons, and they are quite good also. My 30 year old Canon FD 50mm F/1.4 is by far the sharpest lens in my kit, and at $125 the best value. The Canon FD 85mm F/1.2L which I recently sold was amazing. You specifically named third party lenses, but let's be clear the old Canon's and Nikons are fine lenses and excellent values by any measure.
At F/2.8, the GH2 performs well, I don't know about the other cameras. Jim, you used to like the 14-140 F/3.5-5.0 (or whatever it was) for wedding work and wondered why I was buying fast lenses. You have clearly had a change of heart. I'm surprised to hear you now say F/2.8 is too slow. The GH2 is good up to at least what, 1600 ISO? Many, including you, say even higher. My F/2.8 can't hold a candle to a F/1.4 lens, but with a modest amount of light F/2.8 is quite good. At least it gives me a zoom. Without it I'd be stuck with all primes, which is no fun during a first dance.
Philip Howells June 24th, 2011 03:01 AM
Jeff, my comments were relative, not absolute. In general, modern multi-coatings give a relatively better lens. Mark's point, with which I don't fundamentally disagree, is that older lens aren't expensive and as you attest, are often excellent buys, but I'm speaking in relative terms.
Michael Clark June 24th, 2011 06:22 AM
Thanks to everyone for the valuable insight. This is really helpful! I wasn't sure about Tamron's reputation, but it sounds like they are generally accepted, although obviously not the same quality standards as canon's lenses.
To help me understand this, let me use my current lenses as an example. In other words, the 1.4 performs best at, say, 1.8 or 2.0, and the 2.8 performs best at 3.3 or 4.0? I wasn't sure if your saying the performance of lenses at full aperture is not best applied as a general rule for all lenses, or just the faster ones.
Philip Howells June 24th, 2011 07:27 AM
Michael, first, I actually wrote "typically" so I'm not making a an absolute statement for your specific lens, but it was a general rule for all lenses.
However, second, in your example the "typical" optimum performance in terms of all parameters will be that the f1.4 lens will optimise between f2.8 and f4, and the f2.8 between f5.6 or f8 - the difference between f1.4 and f.18 is only 2/3 of a stop. Have a look at the sequence I gave in my earlier post.
I recall an old hand pointing out to me that the huge difference in price for an f1.4 Rokkor and an f1.2 Rokkor - a difference of just half a stop - simply wasn't justified unless I was shooting in dimly lit jazz clubs.
The thing to remember is that photographers rarely use their lenses wide open because they know that the performance at that extreme will not be the best. It's a trend amongst video people turning to DSLRs which seems to have introduced this use of lenses wide open. I'd also observe that most photographers would balk at using equivalent speed in excess of 1200ASA. The fastest general use film was 400ASA and many film photographers preferred slower film with better resolution. Finally, I'd add that one of the sharpest lenses I ever had was a T-star f2.8 Tessar in a "snappy" Agfa camera. Super sharp even at the edges.
Jeff Harper June 24th, 2011 09:49 AM
Wait a minute folks, hold on here. We are talking video, not photography, yes? Yes lenses generally are sharper stopped down, this is true, and most of us know that.
So while what Phillip says about lense being sharper stopped down are correct, this is not as important of a reason for video, IMO. The main reason for using fast lenses for video, for most of us, is to be able to use them full open in a dimly lit envioronment, so that shutter speed doesn't have to be lowered, or that ISO doesn't have to be raised.
On the other hand there are some advantages to a F/2.8 zoom that makes it a necessity in my kit.
Outdoors the F/2.8 is advantageous for run and gun, as you need to stop down less for a nice image, and can get by a tad better without needing a ND filter (as much). I sold most of my ND filters and replaced them with circular rotating polarizers. For run and gun who needs to stark stacking filters or choosing between an ND or Polarizer? Not me. So my F/2.8 comes out for outdoor shoots, and I have a wide zoom that fits most situations. I put on a circular polarizer if needed and I need to stop down even less.
I like having the Sigma 18-50mm F/2.8 in my kit for that reason. It's great outdoors, it's a zoom, and works well on the GH2 even at a reception. It is more flexible. It is NOT as sharp a lens, not nearly as good in several ways as a prime, for sure. But it gives me the ability to run without a conventional video camera and works pretty darn well.
My F/2.8 zoom lenses are easy to focus and have greater depth of field, which I I like as well.
All in all, Michael, you can't go wrong listening to anyone's advice so far, but keep in mind even an F/2.8 Sigma will beat your HV40 anyway.
Jim Snow June 24th, 2011 11:50 AM
Now that I have used my GH2 on a number of weddings, I have a better handle on lighting conditions versus lens choices. I like the 14-140 kit lens for daytime outdoor and bright indoor lighting conditions. But some of the wedding receptions that I shoot are VERY dark. I am even thinking of buying the Voigtlander .95 lens for occasional use in the darkest situations. Shallow depth of field is more of a challenge when you are wide open but it also helps to be able to see the subject; so it's a tradeoff. I use a very small LCD light primarily to fill faces, not to provide overall lighting. I don't like the flat look that on-camera lighting gives but if it is used more to fill faces a bit, it works great. With the portability of a GH2 on a monopod, I generally don't miss zoom very much; I just move as needed. When you are close to a subject, you can push in and pull out with a monopod which gives a nice look to some shots.
Jeff Harper June 24th, 2011 11:57 AM
Well, you also have your EX1, so you've got a zoom already. Have you seen /heard about the Olympus 20 or 25mm F/1.4 that is coming out? I might have the numbers wrong, but it's something like that. At $599 or $699 (forget the price), I believe it would be a great value and F/1.4 is pretty darn fast, fast enough most the time, and it will be (I believe) fully functional with the GH2.
Jim Snow June 24th, 2011 12:18 PM
I find the EX1 along with the GH2 gives me an effective range of capability that covers most situations. What is you opinion of the Olympus 20 or 25mm F/1.4 if I already use the 20mm f1.7 lens? Even though it's small, it is a good lens.
Jeff Harper June 24th, 2011 12:45 PM
My opinion is if you have the money to spare, buy it! F/1.4 is nice, I have two F/1.4 lenses and it is very nice to have that ability at a reception. But the F/1.7 is really fast enough, at least for me. The more I use the F/1.7 the better I like it. It is the best lens value bar none, I think. I mean think about it. A GH1 for $400 new, and a $400 F/1.7, for $800 you have a phenomenal setup. The F/1.7 also matches other cameras quite nicely.
I can't see the Olympus for me, it's just not in my budget, but I would love to have it. I would consider buying it, and if I like it maybe selling the F/1.7, but I don't think it's even coming out for months anyway. As you and I both know with these Panasonic items, it will sell out almost overnight and be backordered for months. You could probably buy a dozen of them and resell them on Ebay for a $400 profit for each one. I hate when that happens, but it always seems to.
Philip Howells June 24th, 2011 03:56 PM
So while what Phillip says about lense being sharper stopped down are correct, this is not as important of a reason for video, IMO. snipped.
I find this a puzzling statement and attitude. Are you saying that image quality is less important in video? For years non-broadcast video people strove to improve and maintain image quality; I was unaware of a change.
I would have thought that because video uses the whole of the image area, the quality of the lens was more important not less.
Jeff Harper June 24th, 2011 05:36 PM
If you are puzzled I can't help you, I explained myself as best I could. Sorry.
Asvaldur Kristjansson June 24th, 2011 06:37 PM
I think that by meaning that good lenses have a certain resolving power needed for hi res photography, like 5188x3456 (18M), HD video is only 1920x1080 so to pay for extra sharpness will maybe not be noticable.
Jeff Harper June 24th, 2011 07:14 PM
Thank you Asvaldur. This point seemed obvious enough it didn't need explained, and I couldn't verbalize it, was growing too tired of the whole thing. Thanks for jumping in.
Warren Kawamoto June 24th, 2011 08:14 PM
Look carefully at the CORNERS of your videos. When shooting wide open, the difference will be obvious between a good lens and a cheap one.
Dustin Moore June 25th, 2011 07:10 AM
We want a quality lens to have minimal glare and chromatic abberations. We should feel free
to run it at f1.4 if we want to though since video "pixels" are much larger than still "pixels". Depth
of field is inversely proportional to pixel size so if the pixels are three times as big, the depth of
field is three times wider.
To some extent, the same applies to coma and the other abberations. If a still photographer does
not notice the abberation at f/2.0, a videographer might be able to get away with f/1.4 because
our pixels are just so much coarser.
It is not that image quality is less important, it is that as video people with fat pixels, we can get
away with a lot more. So yes, a still photographer will run the lens stopped down when he wants everything to be absolutely crisp but we don't need that kind of crispness.In fact we don't even
want that kind of crispness. Most DSLR's that have massive aliasing problems so we want a bit
of extra abberation blur to cut the aliasing in the infocus part of the image.
So guys feel free to run your expensive fast primes full open if they achieve the effect you want.
There is no reason to stop down just because the still photographer said so.
Just make sure you test beforehand so that you know how shallow your field really is and how
much abberation you have creeping in at the edges.
Dustin Moore June 25th, 2011 09:38 PM
If you are using fast primes so that you can get the exposure you want
at at reception you should be thinking about the kinds of artifacts
a non-multicoated lens will make.
One problem is flare. Imagine you have a bunch of the white mini-christmas
tree lights all over the place lighting the reception. You will probably get a
bunch of undesirable ghosts with an older but fast lens. I have a Nikon
nikkor F 35mm f/2.0 that is not really usable for night videography
because the coatings aren't all that good. A slightly later nikon f24mm f/2.0 is
just fine for video of street scenes at night.
At any rate, if you are going to buy a fast prime for video in receptions be aware that older
single-coated lenses may flare more and you may be walking into situations
that are basically flare test patterns.
I second the notion of having one really fast prime, modern multi-coated prime that
is faster than f/2.0. I don't do weddings but I do record outdoors at night a lot and
most of the time it is all about aperture.
Nigel Barker June 28th, 2011 02:27 AM
One irritating feature of the Tamron lenses is that the zoom & focus rings operate the wrong way on a Canon as they rotate the Nikon way. I recently bought a Canon 600D(T3I) with a Tamron 17-50mm F/2.8 IS but returned it & paid double the price for the Canon 17-55mm F/2.8 IS which is an all round better lens compared to the Tamron even aside from the back to front focusing issue. The Tamron IS is very noisy & AF slow plus to smoothly focus it manually you need to slide the switch on the lens from AF to MF or you are fighting the focus motor.
BTW some of the lenses quoted are not constant aperture e.g. the 18-55mm Canon kit lens is F/3.5 at the wide end but F/5.6 at the long end. Likewise the Sigma 17-70mm varies from F/2.8 to F/4.5. This makes an enormous difference when comparing lenses. These variable aperture lenses are really to be avoided if at all possible as it's a pain to be coping with.
