Recording Speeches
Hi,
I am trying to find the best solution to record speeches; a microphone will be passed to several family members on the day so I can't set them all up with a Mic. I currently use a Zoom H1 on a Mini Tripod but it captures way too much background noise. The family members will each walk onto the stage and take over the microphone. I am recording using my rode microphone but that is not clear enough for me as again that captures too much background noise. Can anybody suggest any good tips? Thank You. |
Re: Recording Speeches
Why not do a line from the soundboard into your digital recorder?
The venue uses a Mic synched up to a hifi and I am not sure on how old it is. I would hate to get there and find out there is an issue. I would like to be prepared myself just in case.
I was going to post a similair question. The venue's microphone is hooked up to an old system, that's hard wired to the house speakers, and no other output...
Therefore, and correct me if i'm wrong, i'm thinking of duct taping a Lav mic to the houses mic, via Sennheiser wireless. Fortunately, the transmitter will be at the podium. In your case, since the mic is being passed around, you'd have to duct tape both lav and transmitter to the houses microphone.. Another option (and i've done this before), is to set a mic at the speaker with a mic stand, and capture the speakers' audio.. |
if the mic is hard wired you can get an xlr splitter, send one end of the split where it currently connects and the other lead to your recorder. i have done this and it works well IF the speakers remember to turn on the mic and keep it near to them when speaking.
i also have taken a small recorder like an iriver with a lav mic plugged in. gaff tape the lavaliere element near the top of the house microphone, place the recorder in a small black pouch and gaff tape it near the base of the microphone. |
I believe in redundancy... if it's a wireless, there's gotta be a receiver somewhere. Usually the receiver has an unbalanced out. I've had good luck with that. I would also clip a lapel.Mic to the speaker grill running into the recorder. And maybe an ambient backup to that. :)
Dont trust the venue set up, that route is fraught with problems. Your need complete control over the audio, and the only way to get that is to use your own, tried and tested audio equipment. Easiest method would be to tape a radio mic to the house mic, and control the levels on your camera. Other than that get your Zoom right in there with the speakers, dont be afraid to get in there and move it in front of each of the speakers, they will understand , and if you have a couple of cameras running, just cut to the B cam when you move the mic. Not a lot you can do about the ambient background noise, thats all a part of weddings.
I always do much the same thing...with the house mic but also try to force them (nicely) to do all the speeches from one position...if there is a lectern, then place a mic stand there and simply tape your lav mic and transmitter to the mic holder and you will get consistent audio. The only problem taping a lav mic to the house mic IF it's going to be handheld is that some people will talk close and some will hold it far away! On a mic stand it's usually a better bet. If there is a lectern involved I will often just tape the mic to the top of the lectern.
Your other option of course is to use a boundary mic...they work very well on hard surfaces but just make sure they are not too close to the speaker so notes, papers and such can't be placed on top of them!! Chris |
I usually go visit the venue one day before to check where to get an output for my sennheiser RF transmitter/H1.
1. If a wireless mic is used then tune in to the same freq. 2. If hardwired mic is used I would check for an output either from the house PA or use loop out from the speaker if an active speaker is use. 3. You can also use a small mixer as a xlr splitter and run the mic cable in and output to the PA and you. 4. Last option is placing your mic/H1 near a speaker. A bag full of different kind of adaptors and cables is a must to have. I prefer to use my sennheiser rf transmitter because then I can constantly monitor the audio and optimize the level. |
I normally get in touch with the DJ or venue a few days or weeks before the wedding to get all the info I need for my audio setup. I also let my couple know what my requirements are beforehand so they'd normally arrange things to help me do my job properly.
I try as much as possible to avoid having to show up on the day of the wedding and start figuring things out at the last minute. It leaves room for all sorts of unexpected surprises that could easily be avoided by simply making a bit of effort and doing my homework. I go with the mentality that my clients pay me a fair amount for my service and expect me to do a good job. I can't let a crappy audio setup ruin the quality of my work and then having to explain it to my couple later on. By talking to the DJ, venue, church, etc. before the event, if I find out that there's something that will not work out too well, I can address it right away. Not only does it allow me to do my job properly on the day of, my couples also appreciate the fact that I am very involved in the planning process and it makes them feel safe to know that they are in good hands because everything is already taken care of so they don't need to worry about all the technical problems that could happen. Obviously, this doesn't mean there won't be any surprises at all. But it sure helps lower the risks. |
Hi Long
I have never yet trusted a DJ!! They don't seem to be very technical when it comes to providing feeds PLUS they have control of your feed so if they hit the wrong slider to bring in the music you have no audio! It's fine if they provide a decent feed (I still trust theatre sound techs!!) but wedding DJ's are a little unreliable!! I would still rather have my own lav and transmitter on the lectern or table and if a feed is available then run it into your other XLR channel....BTW: DJ's are highly unlikely to have XLR cables so make sure you have your own 1/8" and 1/4" and XLR plug to grab the feed back into your cam XLR's Chris |
For social events I never plug into the board. Even with DJs that I've worked with for years, I use my tried and true system of a Sennheiser E604 drum mic and my wireless plugin transmitter going back to my camera as well as my Blueline hypercaroid. This way I get 2 channels and IF the person speaking holds the mic out to one side or another or at their belt line I still have the hyper to help the sound along. While that might not be as good as the 2 channel it will get the job done.
When the DJ lines the bridal party up for introductions I go out there with him and explain to the people doing the toasts they have to hold the mic like an ice cream cone, about chin level. Normally around here it's the maid or matron of honor, the best man or men (sometimes there are 2) sometimes one or both of the fathers and once in a while the bride and groom. They hold the mic properly about 75% of the time. Oh well, I'm usually within about 10 feet of the people speaking so it works most of the time. The DJ gives the speaker a wireless mic going thru his system, we don't depend on the house system. They generally suck bad. the mics are a SM58 type so holding it close is vital and the DJs, for the most part, keep their finger on the slider just in case. I've been using this system for years and so far, it's been working well. |
I never rely on only one feed. But a good cooperation from the DJ is a must. Most DJ's I work with understand what I need so we make sure the sound check is done properly and once we have an optimal level, they don't go around changing anything after that. I would still monitor it once in a while but because I have more than 1 source, I'm usually safe for my edits. What I normally do: - XLR splitters to share the DJ's microphone input ports; I make his microphone feed my recorder and his board at the same time - Most DJ's use more than 1 microphone, I would do that for each of his MIC IN port. - DJ output (I get what comes out of his board) - Speaker output port - Lav mic taped to the podium's microphone |
I have spoken to the DJ, he said he has a phono out and my zoom h1 has a line in which the site says , this jack accepts stereo line-level inputs to be used in capturing audio from cassette decks, record players and other analog sources.
Would I be able to capture from his deck as I am not to familiar with audio and what connectors I would need? Thanks |
You should probably be OK with the a line-in to the Zoom H1. However you are then totally relying on that one feed. I always try & get a feed off the PA because if it works OK then it is lovely & clear although a bit flat & lacking in ambience & audience which need to be added back. You can never have too much backup audio so I clip a little Yamaha C24 somewhere near a loudspeaker. If there is a lectern I clip another C24 to that. With all speakers at a table just standing up from their chairs to deliver the speech I have used a wireless mic on the table & just moved the wireless mic along.
Undoubtedly the best sound is to use a wireless lav mic for each speaker but as I only have two this is but a bit too disruptive to have to leap up & down & swap over the mics. If there are not too many speakers then a C24 with a lav mic for each speaker set up & running before the speeches start might be the best compromise. |
You can get a pad cable from Pinknoise Systems. Needless to say the price has shot up since dSLRs made their appearance: Pinknoise -25db Curly Pad Cable | Pinknoise Systems | Location Sound & DSLR Equipment One end of the pad cable will connect direct to the H1. The other end needs to be connected to the deck. You'll probably need a 3.5mm to phone convertor of some description. Mine have two phono male plugs on one end - one red and the other white to go in the deck, the other end finishes in a single 3.5mm stereo male jack. If your pad cable has males on both ends you'll need a female to female connnector. Confused? If you visit your local Maplins they will have all the connectors and put you right - but they probably won't have pad cables. You will need a pad cable eventually even if not for this job because as soon as you connect many mini recorders direct to sound decks and play muisc they are overwhelmed even at very low Levels setting. As mentioned earlier the easy way out is to put the H1 on a lightstand a short distance from the speaker. The audio will then likely be as good as the audience is hearing (so long as you get the Levels right) plus you can get an appropriate amount of ambient sound without having to add it afterwards. Easy to monitor as well :- ) Pete |
H1 can be used to record line level signal going to the mic/line input. You have to select manual level and set the recording level to 8 (1-100). All you need is a sterio jack-phono cable.
Where I am, i couldn't depend on DJ's or venues own systems, way too many variables existing. So i expect to use my own stuff all the time, my current audio setup is a Sennheiser ew 135-p G3 wireless mic and a XLR ECM-XM1 shotgun mic on one cam and a ECM-PS1 Mic on another.
I usually tape the wireless mic to the venue's one,. this has worked out pretty much ok except for I got caught out recently when the priest moved to a lectern but left the mics behind which resulted in a terrible echo for that portion of the ceremony! So i've been looking into getting something like the H4N, is it overkill for what i want here? I've looked at the H1 as well which is a lot more cheaper (probably could get two or three of them for the price of the H4). Has anyone got any opinions on any of the digital recorders as shown on this website - Digital Voice Recorder Review 2012 | Best Voice Recorders | Handheld Digital Voice Recorders - TopTenREVIEWS the first two look to be real good, Philips LFH0655 and a Sony ICD-UX512 probably cost a lot more on this side of the ocean tho! |
I own a couple of H1s & they are great little recorders but I have also more recently bought a couple of Yamaha C24s which are half the size & match for quality. For use on the groom or other speakers with a cheap lav mic they are less bulky & easily fit into a pocket. |
thanks for that, I priced the H1's here in ireland and they were working out dearer than the Yamahas from Amazon, so i ordered two, pretty good price at £76.70 each, cheaper than on ebay.
They should work out fine for me. Rob |
Have done this in situations where getting proper sound from the venue sound system was not possible or to big of a risk and where the speaker where attached to the ceiling. Also because the microphone would be handed over from person to person I had no time to mic everyone with a lav. In this set up I lock the c24 so accidently pushing any buttons won't have any effect and just set the mic sensitivity on the c24 to low and switch the auto level controll on so very loud speakers don't clip the sound and the sound quality I get is very good. |
How about using a few cable ties to secure the Zoom H1 to the Microphone and another H1 hooked up to the DJs sound board?
I might get one of those Yamaha c24 units - look really nice. My iRiver's are getting pretty old now.
What lapel mic's are you using with the Yamaha? |
Too many times the DJ gave us crappy audio. The best solution to record the speeches is to buy some 1 inch black gaffer tape from Amazon.com and tape a H1 to DJ's mic. I set the level to 50 and I'm good. No matter where the mic goes it picks up the sound sooooo well. I don't have to bug the DJ to tap in and I'm good. I also drape a lav mic in front of the DJ's speaker, tape with the black gaffer tape and put the H1 on top of the speaker. I no longer need to bring the heavy H4n or my wireless G3's. I bring 3 H1's and 3 lapel mics and that's it for audio. You can plug your H4n in for backup too, but the H1 audio always sounds better.
Tape it their mic and be done with it. |
I find my zoom h1 is too thick to attach to a mike handle, my yamaha c24 is better suited for this as it's smaller in size. My zoom h4 however always gets connected to the dj's audio table when possible or often they have speakers with a xlr connection on the back, only problem is that its very difficult to set the correct levels so the audio doesn't clip, not sure if there is an auto gain on the h4 for that purpose.
Since i work alone I do test the levels first but once I"m filming I have no way checking if it's still ok, but I set it quite low so I can have a good back up if needed. |
Just a thought. I have two very cheap wireless lavs. You guys sound as if you have more expensive stuff.
But anyway why not use both. You can prepare them youself. Then offer one of the recievers to the DJ inplace of his mic. |
Noa, one trick I use is to split the RCA out from the DJ's mixer into two channels (or, if you like, simply use two RCA to XLR cables). You can then set one level a little high in case they speak softly, and the other a little low. And, yep, get the DJ to do a sound check beforehand, both for microphone and for music levels. I normally use a Tascam DR-100, which has an auto limiter. I'm giving thought to something like a Tascam 680 + multiple lav mics. When attaching a free-standing shotgun microphone on a stand to one of these sound recorders, though, you'll burn through the battery in less than an hour. I usually don't rely on internal batteries in a Tascam or Zoom; I'll have something like a Tekkeon battery or a modified laptop battery hooked up to the DC-in port so it can run all day. One more random thought: I hate the Zoom H4N. I don't own one personally; but the ones I've used seem to take a ridiculously long time to boot up. Half an hour once! I don't think they're very reliable for weddings... |
My zoom h4 (first gen) died on me, well, it still worked but decided to record anyting to card when it felt like it :) so I got a tascam dr40 and used it last Saterday connected to the DJ's mixer, I set it to rec mode: dual with the dual level set to -12db so it recorded 2 serparate files which I think is a great as I only had a cable for one xlr channel.
I was only not sure if it was better to set the level controll to "peakreduction" or just leave it on "limiter" with -12db reduction. I was still figuring out how to set the levels right, the signal I got from the mixer was quite hot, even when I turned the input level all the way down (with the knobs on the side) I still got a signal that was allmost clipping. The DJ was not able to reduce the level of what was goling out from his mixer so I had to deal with it. It did turn out great though but got me a bit worried. I also used it on a lightstand in church in front of a loudspeaker as backup and eventhough the output volume of that speaker was low it picked it up just great. What I do like most about it is that the record time on the display is nice and big while on my h4 it was tiny and even with my glasses on I had to look real carefull to see it was recording (I know that once the rec button did not flash it was recording but I always liked to have a second confirmation.) For my use it's great, just need to spend more time going through the options and test to see what it actually can do. |
| All times are GMT -6. The time now is 07:38 PM. |
