how to make the whites 'glow' at DVinfo.net
Old June 12th, 2007, 07:52 AM   #1
Its a very very common effect in wedding videos, but I don't know how its done.
It seems to make the whites glow a heavenly non-offensive glow, especially so in direct sunlight and shots of the bride in her white dress. How is it accomplished in post?
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old June 12th, 2007, 08:32 AM   #2
I use a free one. You can do a Google search for TOO BIG TOO SOON.
I think that's the name. I am capturing at the moment and I can't check.
Douglas Villalba - director/cinematographer/editor
Miami, Florida, USA - www.DVtvPRODUCTIONS.com
Douglas Villalba is offline   Reply With Quote
Old June 12th, 2007, 08:34 AM   #3
is that a plugin? For what program if it is?
Cinematography Site
Old June 12th, 2007, 09:01 AM   #4
For Final Cut Pro
Old June 12th, 2007, 09:08 AM   #5
You can do it in After Effects also.The program has already glow effects in it.
Another trick for glowing/soft focus effect, is the following.
Make two layers with the same footage.
Blur the lower layer by whatever percentage you like.
Lower the top layer's opacity by whatever percentage you like.
Voila !!!
John Kokkinakis is offline   Reply With Quote
Old June 12th, 2007, 09:11 AM   #6
I may have to try after effects...I use all adobe stuff. Someone mentioned bumping up the whites in another thread...is that with levels?
Also is there a way to make a title (text) glow in Premiere? I have a complex set up already to reveal the text so I don`t want to rebuild it in AE. I want it to reveal and glow
Cinematography Site
Old June 12th, 2007, 09:19 AM   #7
You can do that, but i'm not sure it's the effect you want.
Just by bumping up the whites does not give you the soft glow i understand you are looking for.
However you can try that, in combination whith the method i mentioned in my previous post.
Old June 12th, 2007, 09:30 AM   #8
i`m getting it slowly...is there a way i can use 'alpha glow' to my advantage? It doesn't seem to do anything when applied...but its setup screen looks good....
Cinematography Site
Old June 12th, 2007, 09:42 AM   #9
The Alpha Glow effect adds color around the edges of a masked alpha channel.
this is not what you want.
IMO, 'Glow Effect' in AE is fantastic (for colours, or for whites, you make the choice), and also the 'white diffusion' aspect of Magic Bullet (or another free plugin if you don't have that)
p.s. looking forward to P.J.'s usual dig at people who use effects like this.. u have been warned :)
Richard Wakefield is offline   Reply With Quote
Old June 12th, 2007, 10:24 AM   #10
Who? You mean Peter? Come on...he's a pussycat, hehe...
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old June 12th, 2007, 01:04 PM   #11
There is a nice plug in called "Luce" that sends out light beams from text. Works with Adobe Premiere and Premiere Elements. And it's free! It's available at the following link.
http://amicoperry.altervista.org/luce/main.html
Neil Fitchett is offline   Reply With Quote
Old June 14th, 2007, 08:09 AM   #12
Glowing Text in Premiere
One method I tried is have two layers of the text (duplicate the first one if it's animated, etc.). On the lower layer text just add a simple gaussian blur to it and adjust as needed.
-Michael
May the best days of your past be the worst day of your future.
Michael W. Niece is offline   Reply With Quote
Old June 14th, 2007, 09:11 AM   #13
go grab a Trapcode plugin called Shine.. its for AE
55mm is also a good one.. i use it for Photoshop, but its also AE compatible..
its better than Vegas glow (even though Vegas glow is one of the best on the planet) and any other glow filter out there, but u CAN also do this without any special filters.. using the compositing method explained in the above post, BUT mess with opacities and liminance levels while ur at it..
Im fine with Glow filters Richard, its the "soft focus" filters which piss me off.. sorry couldnt resist..
Peter Jefferson is offline   Reply With Quote
Old June 14th, 2007, 10:13 PM   #14
Anybody know of a plug in like this for Vegas?
Dawn Brennan is offline   Reply With Quote
Old June 14th, 2007, 10:14 PM   #15
CHV plugin
I think the Final Cut plugins Douglas meant to refer to were "Too Much Too Soon". You can get them at http://mattias.nu/plugins/
The Final Cut plugin I've used for something similar to the "white glow" effect is Silk & Fog available for free at http://www.chv-plugins.com/ (click on the downloads link, and then scroll down through the FxScript plugins section). That Silk & Fog filter in Silk mode does something very similar to what I think you're wanting. It won't help in Premiere but at least we have a point of reference for how to do this ;-)
Hope this helps,
-- Elliot
Elliot Lee is offline   Reply
