Why does my Media Go Offline?
I am doing my ending credits for my movie, but when I am in the middle of doing them, it says that my Media has gone off line. What could be the cause of this? I have very little ram, by the way. Thanks.
Mine will say that if Vegas does not have the focus (i.e. I open up another program). When Vegas loses focus, it releases the files it has open. As soon as I return to Vegas, the "offline" message goes away.
I pretty much think that is what's going on. I have an insanely low amount of ram, and as my project gets bigger and bigger, Vegas has a harder time handling all of the information. The problem is fixed once I restart the program, though. This is totally due to my lack of ram, I can see that now.
Grazie |
I do have separate drives for Video and Audio and I am running a Core 2 Duo @ 2.67 ghz. |
Should you do "all" these things? Up to you chum! But it would appear, you have done most of it already?
I would like to here from somebody that adding more RAM to your DUO will make for a better HD experience. It might be something other? Regards, Grazie |
You know what, I can't help any further. So, finish your project. Excellent idea. Get that out of the way and make small incremental improvements to your system when and only when you are ready to do so. For me this meant doing research and spending time reading and asking more questions. When I'm come up against a knowledge block, I ask questions. You've asked questions during a period that you aren't wishing to make changes. Fine, I hear you. Then DON'T!! Do it when you are ready. Regards Grazie |
Its got nothing to do with ram or anything like that
Because Vegas uses live updates (ie timeline updates as required), any changes made to files within Vegas (running) are allowed (through the registry) in turn, you can have Vegas open with media "offline" and then cut or tweak them in another instance, or for stills, use CS3 while tweaking the SAME image that's sitting in your vegas timeline. Its a media management feature which IMO works great BUT, if you're running firewire drives, be aware that the MBR of the drives in which your media lives is constantly written each time the media goes offline. Reason I mention firewire is becuase Vegas comms with Windows sometimes flakes out. IDE/Sata & USB drives shouldn't have a problem. This could be more of a Windows issue... Also as this purely relies on Windows registry for permission to overwrite files in use, you gotta make sure your registry is clean of junk. Now with Vegas offline, and lets say you tweak a JPG... once you save that jpg, it will automatically update to the new saves image, i.e., you don't have to re-import. As Vegas is a free format app, having this ability requries constant refreshing. I like it. |
| All times are GMT -6. The time now is 03:07 AM. |
