-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   flash import and export in vegas? (https://www.dvinfo.net/forum/what-happens-vegas/106708-flash-import-export-vegas.html)
Stephen Eastwood October 28th, 2007 11:14 AM
What is the best way to go from vegas to flash? and also I have a few flash sequences I had created that I would like to import or turn into an importable format like an avi or wmv to use as scenes in a movie, what is teh best way to do that?
Thanks.
Michael Daul October 30th, 2007 08:19 PM
I'm not aware of a 1-step process to go from Vegas to FLV. I usually export from vegas as an mpg2 (progressive) and then use the Flash Video Encoder to convert to on2vp6 FLV. There are several other FLV encoding software options out there if you don't have Flash 8 or above. Also, with Flash Player 9 you can wrap an h.264/mp4 inside an FLV: http://labs.adobe.com/wiki/index.php...9:Update:H.264
To go from Flash to some video format, I find I get the best results by exporting as an image sequence (go to export > export movie, and then choose the sequence type under "save as type". Make sure you match your FLA's FPS to your video project.
