empty space at beginning of project
I have about 10 seconds of empty space at the beginning of my project. Is there a way to move the entire project in one action, rather than moving each clip one at a time - in order to get rid of the space?
Oh, Vegas 8 Pro. |
ctrl-a (select all), drag
Double-click the empty space to highlight it.
Press the DEL key followed by pressing Ctrl+Shift+Del (Post Edit Ripple). |
Thanks. This helps.
OR double click in empty area on 1 of the tracks. Control X then F will post ripple all tracks to the left. empty space begone! ;-)
Don |
FYI - the first suggestion worked, then second one wouldn't. I haven't tried the third next - I will the next time I need to do this.
check the tool bar. You may have all of the or at least some of the ripple edit turned off.
All of those methods should work. Don |
| All times are GMT -6. The time now is 08:42 AM. |
