-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Vegas Noob, Preview in Event/Crop Window (https://www.dvinfo.net/forum/what-happens-vegas/115811-vegas-noob-preview-event-crop-window.html)
Kevin Janisch February 26th, 2008 04:47 PM
Hi guys, long time Premiere user giving Vegas a fair shake. When using the Event Crop/Pan to animate stills, how can I preview the animation in the Event Pan/Crop window (not the Preview window) so I can see my animation along with keyframess in real time? I can drag the playback head but can't seem to get it to play. Thanks.
Kevin Janisch February 26th, 2008 06:50 PM
Well, let me rephrase that, how do I get the playback head in the Event Pan/Crop Window to just play so I can reference my keyframes with the preview.
Edward Troxel February 26th, 2008 08:14 PM
You don't. You can play back the timeline and see it animated - I'd set up a loop area around it first so it can auto repeat until you stop it. If you turn on "sync Cursor", when you stop the playback the cursor on the Pan/Crop timeline will match the cursor on the main timeline.
Kevin Janisch February 26th, 2008 09:52 PM
Bummer, thanks for the response though.
Seth Bloombaum February 27th, 2008 11:36 AM
Kevin, I don't know exactly what Premiere behavior you're used to, but there are some good workflows for this in Vegas - maybe they'll be good for you, maybe not.
First, once you've turned on sync cursor, you can drag the playback head in the event pan/crop (or track motion) window and the timeline cursor will follow and you'll see preview. You can also use the keyframe navigation controls to directly advance from keyframe to next/previous keyframe, and again, with sync cursor on, the timeline and preview will track.
For finer control, I frequently press alt-0 to bring focus to the timeline, then use j-k-l scrubbing to look at keyframe behavior in slomo (hold down k and press l once, twice for faster, etc.).
These behaviours are consistent through all filters & etc. that use keyframes. I suspect this is a little different than what you're used to, but it seems very capable to me.
And of course, as Edward suggested, looping a section of the timeline is a very powerful technique as well. This can also be used with j-k-l to slowmo through a tough section, it'll just keep running while you move keyframes, change keyframe type, etc. Usually, you'd turn sync cursor back off for this, so that you could edit a keyframe during playback and see it on the next looped pass.
Kevin Janisch February 27th, 2008 04:02 PM
Thanks Seth!
