If you're going to be getting a new MOBO anyway I would get the Q9450. Better architecture, newer instruction sets, and a much cooler running CPU. The Q6600 is a very good chip but from my exprience the Q9450 accepts OC'ing a little better. If you're not going to upgrade your MOBO by all means go with the Q6600.
As far as DDR2 vs. DDR3, the real world tests have shown that DDR3 can't yet justify the added cost (even though it's coming down a lot). I'd rather get Vista 64bit and spend the extra cash and get 8GB of memory. That would be about the same cost as 4 BG of DDR3. Almost every hardware manufaturer has 64bit drivers out now so you might as well get the 64bit OS. Garrett |
http://www.microsoft.com/windows/win...s/default.aspx Essentially, Ultimate contains the business-related features (in Vista Business) that aren't in Home Premium. I don't know if 32- and 64-bit versions for Home Premium come on the same DVD - I suspect that they do. However, you can only install one (the same product key is used) so dual booting isn't allowed. Since I have an MSDN subscription, I don't encounter the retail limits etc so can't give any info about that. The only software that Vista 64 wouldn't support but Vista 32 would is ancient 16-bit software. Software written for Win3.x, Win9x etc that directly accesses hardware won't work on either (just as with all NT flavors of Windows). I'd go with Vista 64 and - as others suggest - put in a lot of RAM (8GB) to take advantage of Vista 64's larger address space. |
| All times are GMT -6. The time now is 09:19 AM. |
