Rendering takes too long for short clips...please advise.
Hello guys,
I am trying to add my videos which I have created on youtube. clips are around 12-14 minutes in length and I was able to add one of the clips last week which took about 3-4 hours to upload onto youtube. The one I rendered yesterday which is a 13 minute clip and once rendered the size was 1.5 GB which seems a lot for the length of the clip. I used the mpeg2 concept settings and made eveything in customs to best settings. It takes close to 3 hours to render in vegas I am just wondering if thats how long it takes for most people for such short clips too? My computer is the following: Interl core duo 2450 2gb ram ocz plat rev b 7800GTX cant remember mobo will check when i get home Overall I am trying to shave some rendering time and find out what settings people use for DVD and uploading onto websites such as youtube or Vimeo. Thank you for any input you can provide. Cheers, Karim. |
you don't need BEST settings especially for You-Tube. they crush it down anyway. Set the bit rates (for those lengths of clips 8, 6 and 2 should work) and set to GOOD. that should work fine. Otherwise your render times will be very long as you have discovered. Good and Best are actually quite close in quality but much faster in render times.
Don |
Since this is for YouTube, why are you rendering to MPEG-2?
Most folks I know render to WMV or MP4 (using the iPod template). |
Thank you so much guys i figured it out. I started using wmv and it is much better now. I also use the mov format (quicktime) which makes rendering incredibly faster than wmv.
Thank you once again. |
| All times are GMT -6. The time now is 08:01 AM. |
