Is there a way to get m2v files?
Hi, I have to provide some footage that is rendered out to :
"MPEG2-DVD which is an M2V File" Which settings would I use for this? |
Rendering as Blu-Ray outputs to M2V files.
Thank you. I will try that. I thought I saw m2v files somewhere else too though...can't remember where.
Would I just rename the extension?
As far as I know if you select a template for DVD architect and then choose the custom tab. Click on the system tab and select the check box beside " Save as seperate elementary streams" which will then create an M2V file and an MPA file for the audio.
The reason is a M2V file is supposed to be a MPEG2 video ONLY file, no embedded audio whatsoever. |
Hence the name... M(peg) 2 V(ideo)
Ben |
Also know as program stream or mpeg split file with Video.m2v or Audio.m2a. Premiere CS3 media encoder can be done.
| All times are GMT -6. The time now is 07:21 AM. |
