-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Pictures to extracy from HDV footage (https://www.dvinfo.net/forum/what-happens-vegas/174885-pictures-extracy-hdv-footage.html)
Marcus Martell April 8th, 2009 01:52 PM
Pictures to extract from HDV footage
Which are the best workflows-settings to extract a picture (from HDV footage)that i'd like to develope to my camera store?
thx
Edward Troxel April 9th, 2009 07:20 AM
Change the preview to Best (Full) and then take a snapshot. Even better - change it to deinterlaced as well.
The scripting options will make all these changes for you and then reset everything back after taking the snapshot.
Steve Renouf April 10th, 2009 06:30 AM
Do you not have the option to do it in-camera?
I love that function in the Z5 for quick and easy production stills.
For the best quality, you will need it de-interlaced too. Note that it will not work so well in high motion situations as you're effectively working at what would be a stills shutter speed of 1/25 sec (1 frame PAL) or 1/30 sec (1 frame NTSC). Also, your maximum image size is obviously limited to your original frame size unless you resize and interpolate.
Marcus Martell April 10th, 2009 06:34 AM
Ed sorry 4 my newness, where can i find the script on the tools slide?
How shoul i set to deinterlace,on the project settings?
thx a lot
Edward Troxel April 10th, 2009 06:50 AM
First of all, I should note that scripts only work in the Pro version so anyone with a "Movie Studio" version can't use scripts.
The script I use for this purpose is Excalibur which has a BUNCH of snapshot options. However, it isn't free. There are some free snapshot scripts, though. Here's one free script: Save Snapshot at Cursor
www.jetdv.com/scripts/SnapshotToFile.js
www.jetdv.com/scripts/SnapshotToFileV8.js
Marcus Martell April 10th, 2009 06:59 AM
Thank u ED!I can't wait to try it!
MM
Marcus Martell April 10th, 2009 07:05 AM
Steve,unfortunately the z1 doesn't have the Memorystick so i guess it's an impossible mission!
Marcus Martell April 10th, 2009 07:12 AM
Ed i've just tryed it, thanks a lot buddy.INow that i ve used the script,i shouldn't modify anything right?
I could develop the picture with the printer right?
thx
thx a lot
Edward Troxel April 10th, 2009 08:00 AM
Nothing to change. Just use the script to generate the snapshot and then print as desired.
