-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Vegas Pro 9 available for download (https://www.dvinfo.net/forum/what-happens-vegas/235105-vegas-pro-9-available-download.html)
Mike Kujbida May 11th, 2009 07:25 AM
It's time to overload the server :-)
All links go directly to the exe files for the program downloads.
Pro 9 32 bit
Pro 9 64 bit
Production Assistant
edit 1: if none of these links work for you, try http://download.sonymediasoftware.com/current/ and go to (almost) the bottom of the page.
edit 2: none of these links seem to working right now so use the trial page link I posted further down in this thread.
Jeff Harper May 11th, 2009 08:40 AM
They shut it down.
Edit: it still works...
Paul Kellett May 11th, 2009 08:48 AM
I've got 9 on my pc now and something strange is happening during playback, the preview prefences keep changing, i usually have mine on "preview>full" but it keeps changing from preview>half to full> good to full >half and all sorts, not good i think.
Also i'm reloading some of my old projects and it's rebuilding new skf files, even though the old skf files are still there.
Paul.
Jeff Harper May 11th, 2009 08:50 AM
64 bit version works very well at first blush.
John Cline May 11th, 2009 09:01 AM
Vegas v9 has a new feature called "Smart Preview."
Vegas now uses 16-bit Peak files for greatly improved resolution, so it will rebuild any old 8-bit peak files.
Read the documentation.
Mike Kujbida May 11th, 2009 09:02 AM
Paul (and everyone else), do yourself a favour and download the manual (this is a direct link to the exe file)
The first page (What's new in version 9) covers all the "gotchas".
In this case, it says:
Vegas can now automatically adjust the video preview size and quality to optimize frame rate during preview.
Right-click the Video Preview window and select Adjust Size and Quality for Optimal Playback during preview. When the command is not selected, video quality is emphasized and the frame rate will be reduced if necessary.
edit: I see John explained why it's doing this.
Paul Kellett May 11th, 2009 09:25 AM
Oh yes, my bad, a definate case of rtfm.
Also, my custom render templates are still there, so that's good news, i thought i'd have to redo them all.
Paul.
Ian Planchon May 11th, 2009 09:32 AM
if I click the link, it asks for a password....any ideas?
Mike Kujbida May 11th, 2009 10:24 AM
Ian, it looks like SCS put an end to that route :-(
In that case, go to the Pro 9 trial page
Jeff Harper May 11th, 2009 10:43 AM
click on mirror
Edit: do as mike says it's easier.
Danny Fye May 11th, 2009 09:04 PM
Paul.
None of mine are! I literally have to re-do all of them! :(
Danny Fye
VidMus Video - Music Productions
Renton Maclachlan May 12th, 2009 02:14 AM
Pardon my ignorance but what's the deal between 32 bit and 64 bit?
I've used 32 bit - as far as I'm aware - until now with SD.
Should I change or not, and if so, why so?
Steve Renouf May 12th, 2009 04:54 AM
Well, I've downloaded the upgrade but haven't had time to install it as yet. Before I do though, I was just wondering if I open an existing project in 9 and do stuff,is there any issue moving the project back to 8 if problems are encountered? If anyone has sussed that yet, it would be useful to know.
I'm in the middle of editing the French Panto at the moment and it would be great to switch to 9 if it's going to make the rest of the job quicker and easier. However, I concerned about having any issues which might present problems forcing me back to 8 and then hitting compatibility issues.
On the main PC, it'd be 64 bit but on the laptop it's 32 bit.
John Estcourt May 12th, 2009 05:29 AM
Steve dont save the veg file in 9 because you will not be able to then open it in 8, it does warn you first though.
cheers john
Jeff Harper May 12th, 2009 06:42 AM
Renton I can say with certainty that I see a performance difference between 64 bit and 32 bit, and 64 bit is the winner.
Timeline performance is improved, preview playback is better, and rendering times are less by about 20-30%, at least that is what I've found.
If your editing SD I don't think you'll care much, but if you like having the fastest, I can say that from my day or so with it 64 bit seems to be working out great.
The original 64 bit Vegas (8.1) didn't work out for me, but this one is fine. Great product.
Steve Renouf May 12th, 2009 06:20 PM
cheers john
Thanks for the warning John. However, it's a moot point at the moment, as all my files are Cineform - which we all know now don't work in V9 anyway.
Yang Wen May 12th, 2009 09:07 PM
Will work, but not smooth playback right?
Jeff Harper May 12th, 2009 09:11 PM
won't work in Vegas 64 bit, but should in 32 bit. I have read Cineform is creating a fix for 64 bit though.
