-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   DV + HD help fast!! Please (https://www.dvinfo.net/forum/what-happens-vegas/240091-dv-hd-help-fast-please.html)
Dale Guthormsen July 31st, 2009 05:11 PM
1 Attachment(s)
I need to do this tonight.
I have 90 % hd and I have a short dv clip at the beginning and the end, I can't get the dv to scale up.
Wherre is match aspect ratio, is that how you do it in vegas??
thanks
I found match aspect ratio but it does nothing!!
Perrone Ford July 31st, 2009 05:16 PM
Easiest way is probably to drop the SD clip into an empty timeline, and render it with setting to match your HD clips. Then just place that newly rendered video on the timeline with the other HD clips.
Dale Guthormsen July 31st, 2009 05:33 PM
Perrone,
I tried that, placed the two clips on a new project timeline, crreated a region, went to render as and processed it as 1080i it made no difference.
am I missing something??
Paul Kellett July 31st, 2009 05:39 PM
Pan and crop button, select 16:9 from the drop down list.
Paul.
Don Bloom July 31st, 2009 09:24 PM
you can RIGHT click on the clip go to the bottom and go into PROPERTIES. UNcheck 'keep aspect ratio' or whatever it says towrds the top of that list and click OK. BUT your text MIGHT be slightly misshapen. Might be.
Oh yeah make sure the clip and project properties are set correctly for the entire project then change the properties for the clip(s)
Dale Guthormsen August 1st, 2009 10:07 PM
Thank you gentlemen,
I did get it don as don had mentioned.
