Hi Edward,
The lenght of the timeline in the transition screen is the lenght of the FIRST transition not the second one on the event. This is what confused me in the first place. thx Phil |
I'm not seeing that. When I open the transition at either end of the event, the timeline is set for the length of THAT transition. (Yes, I'm testing in Vegas 4)
However, when you click on the timeline of the tail transition, it is positioning the cursor at that point in the head transition on the timeline. That just effects the preview, though, and not the actual functionality. |
You know what Edward, you are right .
I actually finally found a workaround. Put the zoom out on the event and where i want it to stop i took a screenshot of it. Put the screenshot on the timeline where the 2 meet and VOILA!! i have to repeat the same process 4 times so it will be a bit tedious but it will do the job. Also i can't capture the screenshot in "best" condition possible, had to settle for "preview". Got a better idea ??? :) Thank you very much for your time. Phil |
<<<-- Originally posted by Philippe Gosselin : Got a better idea ??? :) -->>>
Ummm..... upgrade to Vegas 5 and use Transition Envelopes????? |
I knew you would say that HIHIHIHIHIHI :)
i just upgraded and all my problems were solved, thx Edward for all your time
| All times are GMT -6. The time now is 08:27 AM. |
