-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Trying out Vegas 5.0 demo - Where are the track FX? (https://www.dvinfo.net/forum/what-happens-vegas/35725-trying-out-vegas-5-0-demo-where-track-fx.html)
Edward Troxel January 19th, 2005 03:23 PM
Try disconnecting the Mackie Controller.
Ray Sigmond January 19th, 2005 07:04 PM
<<<-- Originally posted by Edward Troxel : Try disconnecting the Mackie Controller. -->>>
It worked Edward !!
I removed the Mackie Control in the MIDI section and the FX Buttons work fine.
Are you aware of any issues with the Mackie Control and Vegas? I am using operating system 2.1.2 of the Mackie Control which is the latest.
Ray
Edward Troxel January 19th, 2005 08:52 PM
I am not aware of any specific issues with the Mackie controller. In fact, it is one that is specifically supported. The reason I suggested that was your error message was referencing the the mackie controller as causing the error. Perhaps DSE would have more advice as he has actually used a mackie controller.
Ray Sigmond January 19th, 2005 08:56 PM
Edward:
Do you think I should try experimenting with the Mackie Control assigned on different MIDI channels? I ahd it assigned to MIDI Channel 3 when the error happened.
Ray
Edward Troxel January 19th, 2005 09:06 PM
I'm really unsure as I've never used one. Sure wouldn't hurt to try, though.
Jeff Toogood January 24th, 2005 11:30 AM
Well I ended up re-formatting my computer (it needed it anyways) and everything works fine now.
Thanks guys for all your help & suggestions.
