-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Mask in Vegas - how to select single point? (https://www.dvinfo.net/forum/what-happens-vegas/470173-mask-vegas-how-select-single-point.html)
David Delaney December 29th, 2009 04:31 PM
This has always driven me crazy. Once I create a mask in Vegas, how can I
-Select a single point and move it (not the tangents)
-select the entire mask and move it
Mike Kujbida December 29th, 2009 10:16 PM
What I've discovered is that the trick is to click the "Normal Edit" tool after you've created your mask.
Doing this avoids the creation of more points unless you want/need them.
Once you've done this, right-click and choose "Deselect > All".
Click anywhere on the mask to reveal your points.
Click the desired point and move it as desired.
To select and move the entire mask, right-click and choose "Select > All".
Position the cursor on top of any point (must be on a point, not a line) and you should see everything light up.
Move as desired.
Let me know if this doesn't make sense.
David Delaney December 30th, 2009 09:29 AM
yes it does. I really wish there was a hotkey for this though, like using the CNTRL or even double clicking on certain points that would do the trick. I did figure it out in time, but at least this solidifies the way of doing it . Thanks so much.
