Having Cineform problems in Pro 10?
This should help.
1) Neo 5.x, all versions. Vegas 10 doesn't offer and configuration control, but it is using the SDK. The developers at Sony just run out of time. Output is currently hardwired to 4:2:2, Filmscan2 -- lots of quality, but no 444 or 4444 and no lower data rates. Hoping it will be addressed the next point release. 2) NeoScene requires an update to support encoding. The beta 5.2 has just be patched for this, download here http://cineform.com/downloads/NeoSce...277-101008.zip David Newman CTO, CineForm P.S. Play speed should be nice and smooth, has been in my testing on 2D and 3D sources. |
I'm not sure I fully understand your message, but my AVI files rendered with neoscene aren't readable with Vegas 10.0.
If I re-render will this solve it or is it likely unrelated? |
Chris, I'm not a Cineform user.
I was just passing along David's response to similar questions on another forum. IMO, if you're having issues with it, you should be checking the Cineform forum on this site. |
| All times are GMT -6. The time now is 04:51 PM. |
