-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Vegas 10 crashes (https://www.dvinfo.net/forum/what-happens-vegas/486136-vegas-10-crashes.html)
Marius Boruch October 14th, 2010 11:59 AM
Vegas 10 crashes
Vegas 10 crashes and here is error message:
Extra Information
File: C:\Users\mb\AppData\Local\Sony\Vegas Pro\10.0\dx_video_grovel_x64.log
File: C:\Users\mb\AppData\Local\Sony\Vegas Pro\10.0\svfx_video_grovel_x64.log
File: C:\Users\mb\AppData\Local\Sony\Vegas Pro\10.0\svfx_Ofx1_1_plugin_x64-'com.sonycreativesoftware_Filters.Stereoscopic3DAdjust' (0, Multiple Contexts).log
File: C:\Users\mb\AppData\Local\Sony\Vegas Pro\10.0\svfx_Ofx1_1_plugin_x64-'com.sonycreativesoftware_Filters.Stereoscopic3DAdjust' (0, Filter).log
File: C:\Users\mb\AppData\Local\Sony\Vegas Pro\10.0\dx_grovel_x64.log
File: H:\pri shri Sept5\11.veg
Problem Description
Application Name: Vegas Pro
Application Version: Version 10.0a (Build 388) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\vegas100k.dll
Fault Address: 0x00000001800174EE
Fault Offset: 0x00000000000174EE
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
Process Version: Version 10.0a (Build 388) 64-bit
Process Description: Vegas Pro
Process Image Date: 2010-10-05 (Tue Oct 05) 19:03:04
what is it?
Craig Longman October 14th, 2010 12:03 PM
0xc0000005 is the most basic of exceptions, a generic access violation. The app tried to read from or write to memory it didn't own.
Suggest you submit a bug report to Sony, and perhaps hang on to a copy of those log files referenced, in case they want to see them.
There are a few suggestions for v10 users sprinkled around in the recent messages, perhaps take a peek and see if any apply. Not knowing what you were doing or when the error occurred makes suggesting anything more impossible.
Marius Boruch October 14th, 2010 12:06 PM
I was working with regular HD mxf files from EX1 and Canon 5D; just regular editing - nothing extraordinary
Craig Longman October 14th, 2010 12:27 PM
Then all I can suggest is provide the trace info and description of what you were doing to Sony. Try and save those logs referenced, I presume they refer to actual files on your hard drive. They might be of some use to Sony also.
Marius Boruch October 14th, 2010 12:31 PM
I did sent it to Sony this time and many times in the past...as you can expect NO response at all...they are "to big to..." care
Prech Marton October 14th, 2010 12:45 PM
Hi
I have a HDV file, rendered with Procoder 2.0 to mpeg2 transport stream format.
I have no problem importing and playing back this with Vegas 8.0e, but with Vegas 10 Trial,
i cannot get picture, only hear the audio. The monitor is black.
Other format works.
Some bug?
Marius Boruch October 14th, 2010 06:25 PM
OK, there is something very wrong going on here with Vegas 10. I REINSTALLED WIN7 / formated drive C:/
everything from scratch...installed fresh vegas 10 etc. started editing HD project using Sony EX1 mxf's and after 15 minutes there is an ERROR;
Win7 was updated, RAM in Vegas was set to 2GB, all new drivers etc.
This is powerful i7 CPU running at 3.5MHZ with 12GB RAM
Extra Information
File: C:\Users\mb\AppData\Local\Sony\Vegas Pro\10.0\vst_grovel.log
Problem Description
what is it???? anybody?
Craig Longman October 14th, 2010 06:31 PM
Not that this really should be an issue on 64bit windows and 64bit Vegas, but I'm guessing this 2GB is your dynamic preview RAM, which has nothing to do with rendering. It is just the 'cache' that vegas uses to not have to re-execute each plugin while you're previewing.
Perhaps try lowering that anyway and see if it helps? Like 350MB or less. As I said, it shouldn't make a difference, but it's the only thing that stands out to me.
Marius Boruch October 14th, 2010 06:33 PM
Craig,
I am not rendering but simply editing. I will change it back to 350MB and see what happens.
Marius Boruch October 14th, 2010 08:15 PM
Nope...
I changed it to 350MB it lasted for almost an hour and crashed again....same error.
hm....It wasn't happening this morning when I was working for the last time on Vegas 9 - it is so annoying that
I can't go back to Vegas 9 with projects created on V10.
Craig Longman October 14th, 2010 11:12 PM
Ah yes, sorry. I forgot you said that.
Well, in a program like Vegas, given all that's changed, it's near impossible to not have some issues at first. Especially given the broad range of media it has to deal with (as in sources as well as types).
Your log trace seems to indicate you've included the 3D adjust filter in your work? That filter, as well as the whole OFX thing is brand new, as I'm sure you're aware. If it is, in fact, on, perhaps try to remove it and see if you can work longer. Perhaps only applying it at the very end. Not sure, as you indicate going back to v9, where that filter doesn't exist I suspect. Just a thought anyway.
Edward Troxel October 15th, 2010 06:25 AM
Marius, you honestly need to contact Sony and give them full details on the project, your system, and anything else they may ask for.
Marius Boruch October 15th, 2010 09:17 AM
Craig,
How to eliminate that 3D filter; I am not using 3D at all. In my Project Properties, video tab stereo 3D is OFF; is this what you are referring to?
Gene Gajewski October 15th, 2010 05:15 PM
Flaky memory and/or drivers can cause access violations too. Interesting that decreasing the preview memory somehow helped. I wonder if testing the ram is in order.
Marius Boruch October 15th, 2010 05:33 PM
Nothing actually helped!!!
I switched back to Vegas 90e and IT WORKS GREAT!! with exactly same Win7 configuration.
Vegas 10 is screwed up big time;
I even removed those new 3D plugins - nothing help.
Here is what bothers me:
Plain and simple:
- fresh win7
- Sony EX1 files
- rock solid Asus P6X58D motherboard
what simpler configuration could be used for testing for crying out loud!!!!!!!!!!!!!!
I am working only with Sony files from Sony EX1 camcorder and it can't work together...with brand new installed win7 with newest drivers (yes, I checked it with previous versions of drivers too) - did Sony people tested this software before releasing it to the public??? if yes I am wondering how...
will they refund my money???
INFO 2010-10-15 15:49:57 =========================================================================
INFO 2010-10-15 15:49:57 **** Dumping video plug-in Information ****
INFO 2010-10-15 15:49:57 pPlugin Address = 0x0000000004ED3630
INFO 2010-10-15 15:49:57 pPlugin Memory Approx = 0x253c
INFO 2010-10-15 15:49:57 EffectType = Filter
INFO 2010-10-15 15:49:57 UniqueID = 'com.sonycreativesoftware:Filters.Stereoscopic3DAdjust'
INFO 2010-10-15 15:49:57 Label = 'Sony Stereoscopic 3D Adjust'
INFO 2010-10-15 15:49:57 Short Label = 'NULL'
INFO 2010-10-15 15:49:57 Long Label = 'NULL'
INFO 2010-10-15 15:49:57 Grouping = 'Sony'
INFO 2010-10-15 15:49:57 Description = 'Provides adjustments for Stereoscopic 3D media.'
INFO 2010-10-15 15:49:57 Plugin Path = 'C:\Program Files\Sony\Vegas Pro 10.0\OFX Video Plug-Ins\Filters.ofx.bundle\Contents\Win64\Filters.ofx'
INFO 2010-10-15 15:49:57 Version = 1.0
INFO 2010-10-15 15:49:57 Thread Safety = Fully Safe
INFO 2010-10-15 15:49:57 Supports MultiResolution = 1
INFO 2010-10-15 15:49:57 Supports Multiple Clip Depths = 0
INFO 2010-10-15 15:49:57 Supports Multiple Clip PARs = 0
INFO 2010-10-15 15:49:57 Supports Tiles = 0
INFO 2010-10-15 15:49:57 Temporal Clip Access = 0
INFO 2010-10-15 15:49:57 Field Render Twice Always = 0
INFO 2010-10-15 15:49:57 Host Frame Threading = 0
INFO 2010-10-15 15:49:57 Single Instance = 0
INFO 2010-10-15 15:49:57 BitDepth Available : RGBA Byte
INFO 2010-10-15 15:49:57 pHWndInteract Address = 0x0000000000000000
INFO 2010-10-15 15:49:57 **** 2 Clips defined ****
INFO 2010-10-15 15:49:57 Clip 0
INFO 2010-10-15 15:49:57 Name = 'Source'
INFO 2010-10-15 15:49:57 Label = 'NULL'
INFO 2010-10-15 15:49:57 Temporal Access = 0
INFO 2010-10-15 15:49:57 Optional = 0
INFO 2010-10-15 15:49:57 Is Mask = 0
INFO 2010-10-15 15:49:57 Supported Component : RGBA
INFO 2010-10-15 15:49:57 Supported Component : Alpha
INFO 2010-10-15 15:49:57 Field Extraction = Both
INFO 2010-10-15 15:49:57 Clip 1
INFO 2010-10-15 15:49:57 Name = 'Output'
INFO 2010-10-15 15:49:57 **** Dumping video plug-in Parameters ****
INFO 2010-10-15 15:49:57 == Plug-In Parameter 0 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004ED0C60
INFO 2010-10-15 15:49:57 Name = 'Horizontal'
INFO 2010-10-15 15:49:57 Definition = 'NULL'
INFO 2010-10-15 15:49:57 Label = 'Horizontal Offset'
INFO 2010-10-15 15:49:57 Hint = 'NULL'
INFO 2010-10-15 15:49:57 Script Name = 'NULL'
INFO 2010-10-15 15:49:57 Parent = '***NONE***'
INFO 2010-10-15 15:49:57 Slaved = NO
INFO 2010-10-15 15:49:57 Enabled = YES
INFO 2010-10-15 15:49:57 Secret = NO
INFO 2010-10-15 15:49:57 Can Animate = YES
INFO 2010-10-15 15:49:57 Persist = YES
INFO 2010-10-15 15:49:57 Evaluate On Change = YES
INFO 2010-10-15 15:49:57 --SVFXPLUGIN_PARAMTYPE_DOUBLE
INFO 2010-10-15 15:49:57 fPlain = 0
INFO 2010-10-15 15:49:57 fAngle = 0
INFO 2010-10-15 15:49:57 fScale = 0
INFO 2010-10-15 15:49:57 fTime = 0
INFO 2010-10-15 15:49:57 fAbsoluteTime = 0
INFO 2010-10-15 15:49:57 fNormalizedX = 1
INFO 2010-10-15 15:49:57 fNormalizedXAbsolute = 0
INFO 2010-10-15 15:49:57 fNormalizedY = 0
INFO 2010-10-15 15:49:57 fNormalizedYAbsolute = 0
INFO 2010-10-15 15:49:57 dDefault = 0.000000
INFO 2010-10-15 15:49:57 dValue = 0.000000
INFO 2010-10-15 15:49:57 dMin = -0.500000
INFO 2010-10-15 15:49:57 dMax = 0.500000
INFO 2010-10-15 15:49:57 dDisplayMin = -0.100000
INFO 2010-10-15 15:49:57 dDisplayMax = 0.100000
INFO 2010-10-15 15:49:57 dIncrement = 0.000100
INFO 2010-10-15 15:49:57 nDigits = 4
INFO 2010-10-15 15:49:57 == Plug-In Parameter 1 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004E9DF60
INFO 2010-10-15 15:49:57 Name = 'AdjustmentsGroup'
INFO 2010-10-15 15:49:57 Label = 'Corrections'
INFO 2010-10-15 15:49:57 --SVFXPLUGIN_PARAMTYPE_GROUP
INFO 2010-10-15 15:49:57 nGroup = 0
INFO 2010-10-15 15:49:57 == Plug-In Parameter 2 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EDF020
INFO 2010-10-15 15:49:57 Name = 'Vertical'
INFO 2010-10-15 15:49:57 Label = 'Vertical Offset'
INFO 2010-10-15 15:49:57 Parent = 'AdjustmentsGroup'
INFO 2010-10-15 15:49:57 == Plug-In Parameter 3 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EDF140
INFO 2010-10-15 15:49:57 Name = 'Zoom'
INFO 2010-10-15 15:49:57 Label = 'Zoom'
INFO 2010-10-15 15:49:57 == Plug-In Parameter 4 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EDF260
INFO 2010-10-15 15:49:57 Name = 'Keystone'
INFO 2010-10-15 15:49:57 Label = 'Keystone'
INFO 2010-10-15 15:49:57 dMin = -0.150000
INFO 2010-10-15 15:49:57 dMax = 0.150000
Marius Boruch October 15th, 2010 05:44 PM
INFO 2010-10-15 15:49:57 == Plug-In Parameter 5 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE4420
INFO 2010-10-15 15:49:57 Name = 'Rotation'
INFO 2010-10-15 15:49:57 Label = 'Rotation'
INFO 2010-10-15 15:49:57 fAngle = 1
INFO 2010-10-15 15:49:57 fNormalizedX = 0
INFO 2010-10-15 15:49:57 dMin = -44.999000
INFO 2010-10-15 15:49:57 dMax = 44.999000
INFO 2010-10-15 15:49:57 dDisplayMin = -15.000000
INFO 2010-10-15 15:49:57 dDisplayMax = 15.000000
INFO 2010-10-15 15:49:57 dIncrement = 0.001000
INFO 2010-10-15 15:49:57 nDigits = 3
INFO 2010-10-15 15:49:57 == Plug-In Parameter 6 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE4540
INFO 2010-10-15 15:49:57 Name = 'AutoAlignButton'
INFO 2010-10-15 15:49:57 Label = 'Auto Correct'
INFO 2010-10-15 15:49:57 Persist = NO
INFO 2010-10-15 15:49:57 --SVFXPLUGIN_PARAMTYPE_PUSHBUTTON
INFO 2010-10-15 15:49:57 == Plug-In Parameter 7 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE4660
INFO 2010-10-15 15:49:57 Name = 'FlipHorizontal'
INFO 2010-10-15 15:49:57 Label = 'Flip Horizontal'
INFO 2010-10-15 15:49:57 --SVFXPLUGIN_PARAMTYPE_CHOICE
INFO 2010-10-15 15:49:57 nDefault = 0
INFO 2010-10-15 15:49:57 Choice 0
INFO 2010-10-15 15:49:57 pParent = 0x0000000004EE4660 (Name='FlipHorizontal')
INFO 2010-10-15 15:49:57 nIndex = 0
INFO 2010-10-15 15:49:57 pszChoice = 'Off'
INFO 2010-10-15 15:49:57 Choice 1
INFO 2010-10-15 15:49:57 nIndex = 1
INFO 2010-10-15 15:49:57 pszChoice = 'Left'
INFO 2010-10-15 15:49:57 Choice 2
INFO 2010-10-15 15:49:57 nIndex = 2
INFO 2010-10-15 15:49:57 pszChoice = 'Right'
INFO 2010-10-15 15:49:57 Choice 3
INFO 2010-10-15 15:49:57 nIndex = 3
INFO 2010-10-15 15:49:57 pszChoice = 'Both'
INFO 2010-10-15 15:49:57 == Plug-In Parameter 8 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE4780
INFO 2010-10-15 15:49:57 Name = 'FlipVertical'
INFO 2010-10-15 15:49:57 Label = 'Flip Vertical'
INFO 2010-10-15 15:49:57 pParent = 0x0000000004EE4780 (Name='FlipVertical')
INFO 2010-10-15 15:49:57 == Plug-In Parameter 9 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE48A0
INFO 2010-10-15 15:49:57 Name = 'AutoCrop'
INFO 2010-10-15 15:49:57 Label = 'Automatic Crop'
INFO 2010-10-15 15:49:57 --SVFXPLUGIN_PARAMTYPE_BOOLEAN
INFO 2010-10-15 15:49:57 fDefault = 1
INFO 2010-10-15 15:49:57 fValue = 0
INFO 2010-10-15 15:49:57 == Plug-In Parameter 10 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE49C0
INFO 2010-10-15 15:49:57 Name = 'Crop'
INFO 2010-10-15 15:49:57 Label = 'Crop'
INFO 2010-10-15 15:49:57 dMin = 0.000000
INFO 2010-10-15 15:49:57 dDisplayMin = 0.000000
INFO 2010-10-15 15:49:57 dDisplayMax = 0.500000
INFO 2010-10-15 15:49:57 == Plug-In Parameter 11 ==
INFO 2010-10-15 15:49:57 pParam Address = 0x0000000004EE4AE0
INFO 2010-10-15 15:49:57 Name = 'Controls'
INFO 2010-10-15 15:49:57 --SVFXPLUGIN_PARAMTYPE_PAGE
INFO 2010-10-15 15:49:57 Child 0
INFO 2010-10-15 15:49:57 pParent = 0x0000000004EE4AE0 (Name='Controls')
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004ED0C60 (Name='Horizontal')
INFO 2010-10-15 15:49:57 Child 1
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EDF020 (Name='Vertical')
INFO 2010-10-15 15:49:57 Child 2
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EDF140 (Name='Zoom')
INFO 2010-10-15 15:49:57 Child 3
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EDF260 (Name='Keystone')
INFO 2010-10-15 15:49:57 Child 4
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EE4420 (Name='Rotation')
INFO 2010-10-15 15:49:57 Child 5
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EE4540 (Name='AutoAlignButton')
INFO 2010-10-15 15:49:57 Child 6
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EE4660 (Name='FlipHorizontal')
INFO 2010-10-15 15:49:57 Child 7
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EE4780 (Name='FlipVertical')
INFO 2010-10-15 15:49:57 Child 8
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EE48A0 (Name='AutoCrop')
INFO 2010-10-15 15:49:57 Child 9
INFO 2010-10-15 15:49:57 pParameter = 0x0000000004EE49C0 (Name='Crop')
Marius Boruch October 15th, 2010 05:48 PM
INFO 2010-10-15 16:59:05 **** Grovelling DirectX video plug-ins in-proc ****
INFO 2010-10-15 16:59:05 Phase 1 - Enumerating non-shared dlls
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\colorcorrector.dll
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\PluginWrapper.dll
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\sfpagepeel.dll
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\sftrans1.dll
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\vfplugs.dll
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\vfx1.dll
INFO 2010-10-15 16:59:05 Loading C:\Program Files\Sony\Vegas Pro 10.0\Video Plug-Ins\vidpcore.dll
INFO 2010-10-15 16:59:05 Phase 1 - Complete
Edward Troxel October 16th, 2010 07:53 AM
Marius, fact is that it's running fine on hundreds of other machines. Your machine definitely has a conflict of some kind. I don't know what it is and, I'm guess no one else on this forum will be able to diagnose what is conflicting. The people that could really help you is Sony Technical Support. Have you tried contacting them?
Marius Boruch October 16th, 2010 08:12 AM
I will have no other choice;
do you know how to contact them directly - Sony Vegas support. What's best way phone or email?
btw...it show me this message once:
Problem Event Name: APPCRASH
Application Name: ErrorReportClient.exe
Application Version: 1.0.0.3796
Application Timestamp: 4beac2a8
Fault Module Name: MSVCR90.dll
Fault Module Version: 9.0.30729.4926
do you happen to know what that file msvcr90 is responsible for? (graphic drivers???)
Edward Troxel October 16th, 2010 08:40 AM
I know it's a Microsoft file but am unsure what causes it to get installed.
Just call the Customer Service number and I'm sure they can direct you to the right place.
Marius Boruch October 16th, 2010 09:46 PM
WHAT? THEY CHARGE FOR SUPPORT???
"phone support is available to U.S. customers by purchasing a Support Plan. We offer free, online support options from our Support Homepage.
Support Plans – Support Plan members receive person-to-person support via a toll-free telephone number and email support
Cost: Packages Range from $29.95 - $149.95
Hours: 8:00 a.m. to 6:00 p.m. CST, Monday through Friday
Enroll: Call 1.800.577.6642 or order through our online store to enroll in a Support Plan."
Edward Troxel October 17th, 2010 06:36 AM
My understanding is that the first x days/hours was free and it cost after that?
Travis Palmer January 5th, 2011 01:43 PM
How did you fix it
I've had the same error message, how did you finally fix it?
Kevin Janisch January 5th, 2011 03:15 PM
Yeah, I tried Vegas Pro 10 for half a day and crash city. Even with just Vegas Generated Media files, no video. It would crash on just trying to close the thing. I said back to Vegas 8.0c for me and I'll wait for Sony to fix it. Sony Vegas rarely, and I mean rarely crashes on me and that's with some heavy duty projects over 6-8 hours long, Magic Bullet, Velocity changes, lots of filters, etc. Version 10 crashed on me more times in 2 hours than Vegas 8 has in using it the past 2 years and I'm not exaggerating.
Leslie Wand January 5th, 2011 04:09 PM
another one here with the identical crash!
i get it by just choosing a genarts sapphire fx (s-dissolvedgerays) - and i'm on the last days of my genarts trial - so this is a real PITA.
screen goes black, then vegas whites out and then my nvidia card resets itself!
frankly i think the rush to 3d really screwed up some things....
btw. it worked ok in 10a?
Jeff Harper January 5th, 2011 05:48 PM
Unless it's changed, Vegas support is free for a period of time after your purchase.
Victor Wilcox January 5th, 2011 10:23 PM
MSVCR90.dll (Version: 9.0.30729.4926) is the Microsoft Visual C++ Runtime DLL. There are several versions available depending on you CPU type and 32 or 64-bit Windows.
There are know issues with that could be related to the issue:
FIX: Error message when you run an application that is configured to be built for the x64 platform by using the MSVCR90.dll file that calls the strncpy function: "An unhandled win32 exception occurred in 'application_name'"
You can download the Microsoft Visual C++ 2008 Redistributable Package (x86):
Download details: Microsoft Visual C++ 2008 Redistributable Package (x86)
and Microsoft Visual C++ 2008 Redistributable Package (x64):
Download details: Microsoft Visual C++ 2008 Redistributable Package (x64)
I don't know if this will fix your issue.
Buba Kastorski January 15th, 2011 01:47 PM
Thanks for the links Victor,
after installing Visual C I don't get MSVCR.dll errors any longer,
now it's vegas100k.dll;
I wonder if the cause of the problem is in the hardware/software incompatibility, lucky people who don't grt those IOsurrogates, are you guys using brand name machines only, or custom bulds also?
Seth Bloombaum January 15th, 2011 04:10 PM
Custom builds here, always intel processors/chipsets.
Lee Mullen January 15th, 2011 11:47 PM
IMO 10 is full of bugs. Sony are clueless. The latest error I get now is when I go to render, a box appears saying the filename is not acceptable or something. Unbelievable. Non of this junk on 9.
Leslie Wand January 16th, 2011 12:22 AM
well yes, 10c is buggy, and will crash with certain ofx plugins (usually with the same:
as reported elsewhere.)
that said, i roll my own, but always intel+gigabyte mb and so far have never had what i could describe as a 'hardware' bug.
as an aside, with the bug report above i notice a call on 'stereoscopic3dadjust'. none of the filters i'm calling upon, which guarantee a crash, have anything to do with 3d whatsoever.
it's my belief that 10 has been a desire for features over reliability, and for my part PROPER support for ofx plugins should have taken precedence over 3d since, i'm guessing here, most pro users of vegas are not, as yet, working 3d, but most certainly are trying to make a living editing with what WAS a very reliable nle...
Sean Seah January 16th, 2011 10:37 AM
I had a repeatable crash last week due to my source files being spread over 2 drives. After i shifted everything onto one drive it rendered successfully to mp4.
Jim Snow January 16th, 2011 10:47 AM
I am also experiencing frequent crashes with V10. I virtually never had a crash problem before V10. I have made no changes to my system other than simply installing V10 (now on Rev. C). I now save my project VERY frequently so I won't lose more than a few minutes work. It's also important to send the 'snapshot' to Sony when prompted to do so. I really hope someone at Sony is analyzing these and gets the problem(s) fixed soon.
Buba Kastorski January 16th, 2011 12:09 PM
My installation of Vegas crashes all the time during editing, when I use space bar for start\stop play,
so my Ctrl+S is like a reflex, after every move :),
but after I enabled F12/Space bar start\pause instead start\stop under options, i can't crash it; usually it takes just a few frequent start\stop space bar clicks, nown I've been trying to crash it for about 15 min and I can't, let's see if that helps.
Rochelle Morris January 17th, 2011 08:00 AM
Well I would have to say that after 6 yrs of using Vegas, Dean is tempted to switch to Edius.
Hopefully the problems get fixed because time is money. Going back to V9 would mean that we would have to use cineform for our clips...more time issues.
Buba Kastorski January 18th, 2011 07:24 AM
I've tried old fix for V9 and it looks like it still works with V10;
CineForm codec playback issues in Vegas Pro 9
Vegas still crashes, but there is a huge improvement in stability after swapping DLLs
Marius Boruch July 26th, 2011 03:31 PM
Re: Vegas 10 crashes
I noticed that when I disable (set) memory in Dynamic PAM preview to 0 it works OK; any thoughts?
