-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Copying Keyframes in v9 - is it possible? (https://www.dvinfo.net/forum/what-happens-vegas/488972-copying-keyframes-v9-possible.html)
Herm Stork December 15th, 2010 02:32 PM
Using keyframes in Track motion and I need to repeat the same series of keyframes...is it possible to copy and paste the existing keyframes? Using v9. Thanks in advance.
Edward Troxel December 15th, 2010 02:34 PM
Yes. You first need to select them. Then just do a CTRL-C.
Now select the destination track and put the cursor where you want them and press CTRL-V.
Herm Stork December 15th, 2010 06:37 PM
Ed - thanks for the quick response.
Graham Bernard December 15th, 2010 11:06 PM
Or: Hold down Ctrl scrub over the kfs you want and drag your selection to the point you want. I find this more intuitive. There are other keystroke and scrubbing controls you can use in conjunction with this timeline that make life easier.
Grazie
Ian Stark December 16th, 2010 03:26 AM
Where do you do the scrubbing, Grazie, in the track timeline or the keyframe timeline? Couldn't get this to work (selecting yes, dragging no).
Ian Stark December 16th, 2010 03:30 AM
Ah, unless you're talking about dragging within the same track. I was thinking of dragging to a different track.
