new Pro 11 update
Notable fixes/changes in version 11.0 (Build 682/683)
Fixed a crash that could occur on some computers during playback if the Split Screen View was used in the Clipboard mode. Fixed a crash that could occur when right-clicking the Pan/Crop ruler. Fixed a crash that could occur opening certain FLAC files. Fixed a crash or hang that could occur when switching between Video FX and Compositors windows with certain OFX plug-ins. Fixed a hang that could occur with Spiral, Split, Squeeze, and Zoom transitions on certain NVIDIA GPUs. Fixed the ability render more than 4 channels of audio to Sony MXF format. Fixed an issue that could cause garbled audio in the rendered file if the last playback direction was reverse. Re-enabled GPU acceleration of Cookie Cutter (Video FX) and Page Loop (Transition) on AMD GPUs when running Catalyst 12.2 or newer. Fixed an error message that would appear when writing to theSony XDCAM Professional Media Station (XDS) internal drive from Vegas. Sony Creative Software - Download: Vegas Pro 11.0 |
Re: new Pro 11 update
hello there mike ;-)
i see no reference to media replacement bug? is this considered fixed? if so, having experienced it with 595, it's most definitely bye bye vegas.... very, very unhappy, but with two major projects looming i really can't afford to take any avoidable risks, and this replace media bug IS a show stopper which ever way you look at it.. addendum: dl'ed and installed. so far so good, but that's not saying much.... |
Fixed a crash that could occur.... hallelujah! I've had no issues issues with media replacing itself but my Vegas crashes constantly, every few minutes, I save after almost every tiny change I make. Strangely enough Vegas is rock solid on my Dell XPS notebook. Lets hope this this update works...
I've had random crashes using some transitions, very frustrating, hopefully this will fix it.
Nope still crashes all the time...
Hmmm...I had three crashes last night while using Boris RED as a plugin...just froze...
I really wonder if it's an NVidia conflict. What the heck else could it be. Does anyone having these crashes use Radeon gpus, I wonder?
Vegas has been as stable as for me - never had this...mind you I haven't had Boris Red either. This was on my new computer with 64 bit. For what it's worth I have a Nvidia gpu...EVGA Geforce GTX570 to be precise...
I've downloaded Excalibur to try it out and in my first play around with it, Vegas seized...(is not responding)...but only temporarily. However I closed out of that and open Boris RED as a plugin and Vegas seized immediately and did not respond again...
In Excalibur, to speed up the loading, each tab will only load what it needs once it is first activated. If a tab needs to read a list of renderers or effects or anything of that nature, it can take several seconds for that tab to load the first time. So that could account for a slight delay.
Render to new track Q:
When rendering a selection of a *.wav track I've always been using the Wave(Microsoft) (*.wav) default template, which gave me a perfect copy of the segment I needed to import into my other software. Not anymore; the volume of the copy is so low as to be rendered useless. After experimenting with options, I came upon the "Microsoft ADPCM option (instead of the default's PCM (uncompressed) and this one now works perfectly and actually plays better in my other software.
I am curious -- why the drop in volume of PCM uncompressed in Vegas and what's the difference between PCM and ADPCM ; would anyone here know this? |
Paul, I don't use Pro 11 yet but this sounds like a bug to me.
I often render out sections of a .wav file for use elsewhere in a project and would be very upset if the volume level changed on me. |
ADPCM is adaptive differential pulse-code modulation, where you do the same sampling but instead of storing the samples, you store the difference between the samples. You store the first sample as is, then the difference between the second and the first, then the difference between the third and the second, etc, and you use an algorithm to store fewer bits than the full sample would use. Typically, you repeat the process after so many samples, so you do not have to uncompress the entire file if you want to access whatever is at its end, or at any arbitrary time code position. ADPCM was developed for telephony to allow better quality sound to be transferred at a low bps speed. The quality of PCM and ADPCM should be exactly the same. The only difference is that PCM is uncompressed, ADPCM is compressed (in computer terms, not in the sense of the sound effect called compression). PCM takes more disk storage but the computer does not have to decompress it (and later recompress it), so less work for the computer. PCM takes less disk storage but the computer has more work to do when processing it. As for the sound itself, it should be identical with both, providing the original was sampled at the same frequency and to the same bit depth in both cases. Personally, I always use PCM. Sound waves are tiny compared to video frames, so the storage differential is negligible (IMHO), but it gives Vegas (or any other software) less work to do, so it processes it faster. The point here is that the volume should be the same. If it is not, there is a problem somewhere. My guess would be you have some new codec for processing PCM, a codec which is probably buggy. Either that, or the headers of your wav files are damaged and give the software some incorrect information. |
Thank you for your time, Adam; it helps me to understand the system better. So are you saying that the PCM export render in your Vegas 11 doesn't copy the wav file at a much lower volume? Because if that is the case, the problem is certainly elsewhere on my computer, but I couldn't even start guessing where.
I see what looks like a DVD Pro 5.2 update to build 135 (http://www.sonycreativesoftware.com/...vdarchitectpro) (from 133). However, the Release Notes (Sony Creative Software Inc. - DVD Architect Release Notes) don't mention any fixes. Anyone know what's going on there? I haven't downloaded it yet to see if it's really an update.
D |
Agree with Dennis - would be nice to have some knowledge of what has changed - or even notification from Sony that there has been a change, however minor. No further info available on the Sony forums either, other than a post saying that if you install 135 over 133 you will find two DVDAs in your Control Panel/Programs list (verified). Do not uninstall 133 as this will apparently trash 135, requiring an uninstall and a reinstall of 135 to get it to work (not verified). It also requires a re-registration. Bit naff, eh?
Well Nick, so much for that idea!
I've never seen any Vegas/ DVDA update that installs a second copy of itself like this and I've been using Vegas when it was still Sonic Foundry from 2003 if not earlier. Something sounds wrong here. Why should there be two versions especially when they aren't really separate? I'm standing pat with 133. There are no bugs that are affecting me with it and I don't feel like experimenting with this. D |
| All times are GMT -6. The time now is 08:23 AM. |
