-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Getting rid of audio buzz help (https://www.dvinfo.net/forum/what-happens-vegas/509788-getting-rid-audio-buzz-help.html)
Herm Stork August 4th, 2012 04:19 PM
1 Attachment(s)
Using Vegas 10...I'm trying to reduce a buzz in the audio track. I have attached a sample. Thanks in advance for any suggestions.
Don Bloom August 4th, 2012 08:11 PM
Re: Getting rid of audio buzz help
Kinda sounds like a ground loop. 60mhz. Try the 20 band graphic eq, pull the sliders on either side of the closest to 60 and see what that does. Do it at clip level so you can hear it then once you find it, you can set it at track level or the Vegas mixer.
Chris Harding August 4th, 2012 09:43 PM
Herm
That is definately mains hum and it sounds pretty constant too so it should be easy to kill on the audio plugin. As Don says, the GE should pull it out ...Just open the audio track FX and in the equalizer select Low Shelf tab and set the frequency to say 100hz and then take the gain (next slider) right down to about -12db or more .... you might have to take the frequency a tiny bit higher as there could also be harmonics from the 60hz signal that repeat at 120hz so maybe go to 150 to cover it???
The same advice works brilliantly for wind noise too!! I set the frequency to 400hz and it kills 99% of mic wind noise...useful to know
Chris
Seth Bloombaum August 5th, 2012 09:19 AM
Yes, the noise produced when different systems are connected together that don't share a common ground. Any stray electricity will seek to ground, commonly called "ground-loop hum". If recognized at the time of recording, it can usually be completely fixed by using an isolation transformer (The Sescom IL-19 is very popular for this), or, using an xlr barrel adapter that lifts the ground.
It's not a simple tone (sine wave) at 60Hz. Meaning, that it has multiple frequencies that are based on the fundamental tone of 60Hz.
So, use the narrowest filter you can, and dip at 60, 120, 180, 240Hz etc. Multiple filters may be required, depending how loud the noise is relative to content.
Ron Cooper August 7th, 2012 06:55 AM
Herm, I' ve just come across this and as it is a constant even noise it should be quite easy to remove.
There is a freebie sound editing program called "Audacity". Download it & open your track in Audacity & make sure there is some clean noise only, - (like the file you sent). then select a few seconds of the noise only, by dragging the hand from left to right, and under the Effect tab select "noise removal" /get noise profile. Then go back & select the whole track or a sample portion of it to try, and then under the effect tab/noise removal (if needed), drag the slider towards "More" - about 80%, and then click "remove noise"
This should do the trick, but you may need to experiment a bit for optimum results. - ie. The amount of noise removal on the slider, as while it is quite effective it can produce artifacts in the overall sound if you go too far.
Hope this helps,
RonC.
Magnus Helander August 7th, 2012 02:37 PM
On thing that WILL take care of your buzz is Izotope RX
iZotope RX - Complete Audio Restoration: Declipping, Declicker, Hum Removal, Denoiser, Spectral Repair, Restore, Remaster, Download
There are two versions - not sure which one you will need for the "Remove Hum" and "Spectral Repair".
This plug is outstanding and I use it all the time to clean up audio from office environments with airconditioning and other background noise.
/m
Gints Klimanis August 7th, 2012 02:57 PM
The methods mentioned before will work. Slightly more manual labor will help eliminate the guesswork.
Take a spectrogram (reasonable resolution, such as 2048 pts or more) of preferably at least a second of silence + hum. If you have a low frequency hum, look for a peak at 60 Hz (50 Hz in countries with that A/C frequency) and multiples of that : 120, 180, 240 300 Hz. Use a Notch or a parametric filter set to 60 Hz with a very high Q (20 or higher) (Q is sometimes expressed as Bandwidth, so specify a very small bandwidth) and BOOST by 10 dB. If the hum is twice as loud, you have identified the correct frequency. Then, cut by 10-20 dB or more. Repeat procedure for 120, 180 , etc. Hz, though the amount of cut will be less. Judge by the spectrogram.
If you don't have a spectrogram, you can hunt for the frequency with a boosting parametric filter. Just boost by 20 dB and a lower Q/high bandwidth and sweep it around in frequency. This is a hunt or miss procedure and much harder than using a spectrogram. When you find the offender, raise the Q/lower the bandwidth to avoid affecting adjacent frequencies. Finally, replace the boost with a cut.
Herm Stork August 8th, 2012 10:50 AM
Hope this helps,
RonC.
Ron and others,
Thanks for all of the suggestions. I played around in Vegas and couldn't get it sounding the way I wanted, so I downloaded "Audacity" and that did the trick!
Regards,
Herm
Ron Cooper August 8th, 2012 06:43 PM
Thanks for letting me know Herm. Yes, Audacity is a little gem.
One thing, - can you please tell me how to do the "Quote" in replying in this forum. I have never been able to work out how you do it !!
RonC.
Edward Troxel August 9th, 2012 07:43 AM
RonC.
If you're quoting the "last" post, you have to click on the "Multi-Quote" button and then reply. The multi-quote button is the farthest one to the right beside the "reply" button.
If you're quoting older posts, you can just click on the "Quote" button.
Ron Cooper August 18th, 2012 12:37 AM
Many thanks Edward. I'll know next time. - Sorry for the late reply - I went skiing last week.
RonC.
