mov not ssen in Vegas 11
I have been given some mov files- heaps of them in fact to use on a production I have. I dont know what they were shot on, if that says anything about variations in mov codec, but botton line is they arent visible on the Vegas 11 timeline.
How can I get them to be seen and work on them. Do I need a converter or is there something within Vegas I magically press and all is well. thx |
Re: mov not ssen in Vegas 11
Dowloand MediaInfo: MediaInfo
This will give you all the information about the video and audio of the .mov files. You may need to install a codec, MediaInfo will tell you the coced used. If that doesn't work, tell us the info that the program gives you to see what may be wrong. |
Re: mov not seen in Vegas 11
Thx Iker
Got the info from one mov file below. Forgot to mention I'm on Win 7 32bit. Another question...am I right in assuming Vegas has trouble converting some mov types. From what I have read, it seems there are some variants (Nikon or other) that Vegas has trouble reading. If I do need to convert, does this mean I have to convert EVERY file to a Vegas readable file? Such as mp4. If so I have a LOT of work to do. The skf files, do they need to be converted as well. In the past I have dropped Sony EX3 MXF files onto the timeline no worries. I am surprised I am having so much trouble getting the mov's to work. Can you tell me more pls. Thx in advance.... File info below - General Complete name : H:\mov footage\Dan\Shoot 1\clip-2011-11-21 19;54;35.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 480 MiB Duration : 24s 0ms Overall bit rate mode : Variable Overall bit rate : 168 Mbps Encoded date : UTC 2011-11-24 23:37:21 Tagged date : UTC 2011-11-24 23:37:21 Writing library : Apple QuickTime Video ID : 1 Format : Intermediate Codec Codec ID : icod Codec ID/Hint : Apple Duration : 24s 0ms Bit rate mode : Variable Bit rate : 166 Mbps Width : 1 416 pixels Original width : 1 440 pixels Height : 1 062 pixels Original height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 4.421 Stream size : 476 MiB (99%) Language : English Encoded date : UTC 2011-11-24 23:37:21 Tagged date : UTC 2011-11-24 23:37:21 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 24s 0ms Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 4.39 MiB (1%) Language : English Encoded date : UTC 2011-11-24 23:37:21 Tagged date : UTC 2011-11-24 23:37:21 Menu ID : 3 Duration : 24s 0ms Language : English Encoded date : UTC 2011-11-24 23:37:21 Tagged date : UTC 2011-11-24 23:37:21 |
Geoff, can you upload a short clip to a site like Dropbox and let us try and see if any of us can get it to load on our systems?
If you don't have Dropbox (you get 2 GB. of space for free), use the following link and each of us gets an extra 500 MB. http://db.tt/rYE74u2 |
This is HDV or AVCHD footage that was transcoded to Apple Intermediate Codec.
If you have access to the original tape, capture it in Vegas as a M2T if it was HDV. If you have the MTS files, use them directly in the timeline or rename MTS to M2TS. If you don't have access, you need access to a Mac and Compressor to convert that to ProRes HQ. There is no way in Windows to properly read and transcode this footage. |
Hey Geoff
Now you have to find some nice person in Perth that has a MAC and will convert your files to Prores as you cannot do it on your computer and neither can I!!!! Anyone in Perth, Western Australia run a MAC who can help Geoff out??? Chris |
Hi folks
Thx for all the replies. I would have replied earlier but had problems with dropbox...but now on track. Below is a link to a 3 second/40mb file from the mov series. I am very interested to see if you guys can open it cos I've spent hours n hours on this. https://dl.dropbox.com/u/107141324/c...%3B05%3B15.mov Otherwise I'll be on the lookout thx to Chris in Perth..thx Chris. Looking forward to the results. cheers |
Hey Geoff
Doh!!! the link doesn't work ..did you check it??? 40mb for 3 secords ? That's one scary bitrate too!! Chris |
When I tried to load it, it said it was only 705 K in size.
It would not play in anything I had (Vegas, PPro, AE, Media Encoder) as it said the file was corrupt. Buba, as Jack mentioned, there are some mov files that Vegas will NOT open, no matter how hard you try :( I wish that Mac users would learn to give us PC users files in ProRes format only as those have always played on my Vegas timelines. Vegas Pro 12 is promising a lot more file format interchangeability so all we can do is hope that they deliver what they're promising. |
ProRes playback has been introduced for the PC, and it is a very good intermediate codec |
Guys.
I'm really sorry for the delay. I have sent the drive back to be installed with the ProRes HQ as suggested here. When I get it I'll let you know how it goes. I stupidly forgot to keep from the HD / file to send here for analysis. Really appreciate the support. Thx |
| All times are GMT -6. The time now is 01:11 PM. |
