24p dslr export suggestions
Hola Guys;
I ve shot 24p stuff with dslrs Now i Wanna export this footage in the best way to be' viewed on the web and on DVD. On every single clip in time line i've desabled resample! The footage shot o. The steadicam looks ghosty! How come? What settings and format Would you suggest me to use? Many Thanks |
Re: 24p dslr export suggestions
Hmm, it's hard to understand, but are you talking about field separation? Are you using Sony Vegas? Because that's the only thing I can think of when you're talking about "ghosty" image. It has that autoresample thing.
You just have to put your 24 progressive frames per second footage in a 24p project and render it at 24p. There will be no problem whatsoever. |
The reality is that, most of the time, the true frame rate is 23.976 which Vegas can handle easily. This time format can be edited natively and uploaded to the web and made into a DVD with few additional steps. Let's start with knowing what the make and model of your camera is and we'll go from there. |
Hallo Thanks 4 helping me!
The camera is a nikon d5100 that shots 23,976 fps. Thx a lot |
Even the tilt moves of the camera suffers of this strange effect
You can't escape that. It's native to the camera's sensor. Pan less and slower. Use tripods all the time. After Effects I believe has a solution to this but it removes a small part of the problem. That is the rule with DSLRs and almost all CMOS sensors. Don't move the camera. Use tripods. Use steadicams.
Best 24p output render settings to export the video in DVD?
Could you drive me Please? Many Thx P.s: i m using Dvdarchitect |
Ok mike, i'm previewing the video After that i set back Smart resample. The moves are always unnatural... I matched the project properties as the source d5100 file.
Now what are the best choices to export in: Hd to be played from my wdtv box in my plasma? DVD for a simple disc Web Thx Guys but i think that this unnatural movements are due to something i' m Missing! Many thx |
| All times are GMT -6. The time now is 11:11 AM. |
