-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   New update 765 (https://www.dvinfo.net/forum/what-happens-vegas/520160-new-update-765-a.html)
Paul Fierlinger November 19th, 2013 05:18 PM
New update 765
2.0 What's New
Notable fixes/changes in version 12.0 (Build 765)
Added support for MOV files when exporting to Media Composer AAF format.
Added support for writing sidecar XML files when rendering XAVC and XAVC S video.
Added templates for rendering Sony XAVC / XAVC S video.
When rendering XAVC S files, audio is now rendered in LPCM format.
Fixed a bug that could cause a crash when rendering a project that contained an empty metadata command marker.
Fixed a bug that could cause a crash when using Tools > Multicamera > Create Multicamera Track with an empty track selected.
Fixed a bug that could cause a crash when importing 1440x1080 XAVC files.
Fixed a bug that could cause a crash when dragging a preset chain (filter package) from the Plug-In Manager to an event, track, media file, or the video output.
Fixed a bug that could cause a crash on some systems with NVIDIA graphics when reading 4:2:0 480p widescreen media.
Fixed a bug that could cause Vegas to freeze when adding some interlaced MP4 videos to the timeline.
Fixed a bug that could cause rendering to hang when rendering to XDCAM EX MP4 files with the Enable no-recompress long-GOP rendering check box (Preferences > General) selected.
Fixed a bug that could cause .aaf files imported from Media Composer to be read using an incorrect frame rate in Vegas Pro.
Fixed a bug that could cause .mov and .mp4 files imported from Media Composer to be read using incorrect timecode in Vegas Pro.
Fixed a bug that could cause a hang when rendering 4K XAVC S video on some computers.
Fixed a bug that could cause an error to be displayed when importing and MXF file from an Optical Disc Archive unit.
Fixed a bug that could cause Vegas Pro to hang when reading MP4 video from the GoPro Hero 3+.
Fixed a bug that added a green bar when reading 480p widescreen AVC files.
Fixed a bug that prevented Vegas Pro from updating the file size estimate when Render Loop Region Only was selected during Blu-ray Disc burning.
Fixed a bug that prevented Sony F5 cameras from playing XAVC HD 23.98p clips rendered in Vegas.
Fixed a bug that caused the Iris transition to reverse A- and B-roll video when GPU acceleration was turned off.
Fixed a bug that prevented Vegas from correctly reading SD MP4 clips that were shot in portrait mode.
Fixed a bug that prevented Vegas from persisting the View transform setting on the Video tab of the Project Properties dialog.
Juris Lielpeteris November 21st, 2013 12:58 AM
Re: New update 765
Update 765 removed. Why?
Roy Feldman November 21st, 2013 01:17 AM
Re: New update 765
Pulled because of a fault with main concept audio rendering
Jay Allen November 21st, 2013 08:15 AM
Re: New update 765
And they wonder why so many people are leaving vegas...
Paul Fierlinger November 21st, 2013 08:36 AM
Re: New update 765
I have worked on hundreds of commissioned jobs in my lifetime and I can't think of having ever delivered a single one that didn't need one or two further corrections. I also never met a client who gave up on me just for one or two goofs. It's clearly the nature of the beast in the age of communications. I admire the speed with which the faulty release was pulled and the way the developer conducted himself. That alone deserves tolerance on our part, in my view.
