16x9 with rendering
First I am confused. I shot a video in 16x9. I have about 8 tracks. I had to do some splits screens. But when I render the splits are all off.
EX: Lets say you have a quad screen with a clip in each. They are not even connected in the middle. When I am working and looking at it on the LCD TV and preview screen it looks right. But when I render it (16x9 widescreen) the main track looks good and normal I think but the rest is all screwed up. Also I think when I burned it that it had those black lines on the top and bottom. Why is that. Am I just confused on how 16x9 is suppose to work? Pleas help and thanks again. Jason |
Jason,
Put a "check" in the "stretch video to fill output frame size (do not letterbox)" option in the "Render As" window. This may be your problem. It also may depend on your Vegas version whether this option is available. I started with Vegas Studio Platinum, and found this problem, but Platinum did not offer it. I shortly thereafter upgraded to Vegas + DVD. Jamie |
Thank You very much. It's amazing how something so simple could give me a huge headache and hours of trying to figure it out.
I got another problem now. When I am rendering my video does not fill the screen. It either has black bars on the sides or at the top. I have tried rendering in so many different ways.
I shot in 16x9. In properties it is widescreen and when I set it to mpg render I have changed it to 4:3 and 16:9. Both don't give a full screen. I need some help. |
Jason,
Are you looking at the preview window when rendering, or the finished product? If the preview window, ignore and review finished movie. If finished movie, again, make sure you have the box checked in post #2 above. You also may need to check that your display device is configured correctly...or your disk player, if that is the case. Please provide more info if this doesn't fix it. Jamie |
Well I have edited it and I preview it just by playing it on vegas and it looks fine.
But when I render it and open it up DVDA it is chopped off on the top or the bottom. I have tried all kinds of settings. I am previewing this stuff through my camcorder and on to my 20" lcd 16x9. I am now just doing test on test rendering a small section to see what it looks like. Where have I gone wrong? Thanks, Jason |
Have you set the DVDA project properties settings to 720X480 widescreen?
Ha, I tried em all. I didn't render or anything just chose the 720x480 and then hit preview. I am needing to burn this to a dvd but right now I am crunched to time and I need to get the mpg right because it is being downloaded via ftp and waiting to be burned but they can't burn it cause it is not right.
My properties in vegas are NTSC DV (720x480, 29.970 fps) Then I choose render as and mpg 2. Then I choose custom. Then choose 16:9 because it is 4:3 by default I guess and when I did the 4:3 it was 4:3 and was squised on the screen. |
Again, did you place a check in the "do not letterbox" option in "Render As"?
Yes, I did that. That fixed the problems with my split screens. I just rendered it as mpg and left the 4:3 in the custom and it looks squished on my lcd tv. So, I chose 16x9 on my tv and it stretched it out and it looks normal. But I need it to do that by itself or something.
After all the help I am still stuck. This video is clearly in 16x9. I checked the raw footage that I captured. Then the properties are set right on the project. But when it is rendered it is not in full 16x9 but instead comes out to 4x3. Now even though it is 4:3 you can tell it needs to be stretched out so I just change my tv to 16x9 and it looks fine. But I need it to be full screen when you put it in and that is where I am lost.
My client expressed this again this morning that it has to be fixed and I look pretty stupid saying I have no idea but it is clearly the truth. Even someone is willing to call me please do. 214-347-4320. |
In Vegas (assuming original project is cut with Properties set to NTSC DV Widescreen):
File > Render As... - Save as type: MainConcept MPEG-2 (*.mpeg) Template: DVD NTSC Check "Stretch Video To Fill Output Frame Size" box Click "Custom" Select "Video" tab Set "Aspect Ratio" to 16:9 Display Click "Okay" Name your file and save In DVD Architect: File > Properties - In "Video Format" select NTSC Widescreen (720x480) There may be better templates to use in Vegas, but this way ensures that what comes out is a 16:9 encoded mpeg. And I hope you don't think I'm treating you like a simpleton, but I wanted to cover all bases. Follow these steps and you WILL have a 16:9 DVD. (I hope) Cheers Pat |
Well I want to give a big Thanks to Guy Bruner. Yesterday I was in a jam and he took time out of his day to help me get it right. I really appreciate that.
I think I narrowed down my problem. PJ Gallagher everything that you mentioned is what I had done. Only when it got over to DVDA I was previewing it through my camcorder onto the screen and it had the bars on the top and bottom. But when I burned it they were not there. Thank you all for you help and a big ups to Guy Bruner once again for taking time out to help yesterday. |
I'm glad I could help, Jason. I hope your project finishes up smoothly.
I will find out this morning. :)
"Are you looking at the preview window when rendering, or the finished product?
If the preview window, ignore and review finished movie." I guess you missed or did not read my posts #5 and #7. Jamie |
| All times are GMT -6. The time now is 11:14 AM. |
