-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Export 1080/24P with pulldown as 60i to tape in Vegas? (https://www.dvinfo.net/forum/what-happens-vegas/85159-export-1080-24p-pulldown-60i-tape-vegas.html)
John McManimie January 29th, 2007 08:29 PM
Please forgive me if this has already been posted somewhere; I didn't see it.
In Vegas, is there any way to add 2:3:3:2 pulldown to 1080/24P (or some other method to create 1080 PsF) and write it back to tape as 1080/60i?
David Jimerson January 30th, 2007 08:54 AM
Writing to which camera?
John McManimie January 30th, 2007 02:03 PM
I’ll rephrase the question: Can Vegas convert a 1080/24P CFHD file to a 1080/60i m2t file that preserves all of the 24P frames within 60i, so that it can then be written to tape as 60i on a camcorder that records at 60i?
I would like to use the tape as an archive that can be ingested as 60i footage from the tape and then converted back to 24P after using the proper pulldown removal (or by whatever method is needed) such as how CineForm HDLink removes 3-2 pulldown from Sony CineFrame 24 to create a 24P CFHD file.
Maybe this can be accomplished with other tools (and maybe not) but can it be done with Vegas?
The camera is a Sony HDR-HC1, though I don’t think that it matters… and I could very well be wrong. :-)
I did find a setting in Vegas for 2-3 pulldown with HDV MPEG-2 files (but no 2-3-3-2 pulldown option):
Render As… ->
Save as type: MainConcept MPEG-2 (*.mpg)
Template: HDV 1080-60i (Custom -> Video -> Frame rate: 23.976 + 2-3 pulldown)
David Jimerson January 30th, 2007 02:12 PM
No, I don't think so.
What you're seeing in that option is what's used to make 24p DVDs -- the "+ 2:3 pulldown" is actually the insertion of pulldown FLAGS used by a DVD player in order to insert pulldown when playing a 24p DVD on a standard NTSC TV. No actual fields are added, only information as to where to add them, so I don't think this will work for you.
I don't think you're going to able to do this. You should be able to record to tape as 60i and preserve the 24p aesthetic, and you might be able to remove pulldown MANUALLY later, but I don't think you're going to able to go to tape at 60i and preserve pulldown info for automatic removal.
BUT, there's a chance I'm wrong about this, considering Vegas's new support for the V1U's 24p, which uses 2:3 pulldown in a 60i stream. I haven't worked with any of that footage, so I'm not 100% sure. I tend to doubt it.
But even if it does work, I'd bet you'd only be able to use 2:3 pulldown and not 2:3:3:2.
John McManimie January 30th, 2007 02:23 PM
It appears that DVFilm might be able to do it:
"It also can convert 24P Quicktime back to NTSC with a non-recompressed 2:3:3:2 pulldown, for archive to tape, and can then re-convert that tape back to 24P, without recompression-- a feature which is missing from many editing programs that support the DVX100 and XL-2."
I just don't know if this applies to HDV/CFHD footage as well.
David Jimerson January 30th, 2007 05:06 PM
Well, if you want to go outside Vegas (and with DV Film products), Raylight might have a function or two you'll be interested in:
http://www.dvfilm.com/raylight/raylightTutorial7.htm
John McManimie January 30th, 2007 08:01 PM
I recently switched to Vegas and I have been quickly trying to stop using other applications as much as possible when I can accomplish the same task in Vegas. It has really streamlined things for me. It already uses CineForm’s codec (which is excellent), the deinterlacing and frame rate conversion functions are superb, and editing overall is very quick. I would dump Premiere Pro (v1.5, I do not have v2) completely if I didn't have some plugins that are specific to it (actually many of them work in After Effects --- v6.5, I did not go to v7).
I would prefer to stick with the CFHD intermediate for editing and back up the final 24P video as a 60i m2t to tape as a cheap archive (I realize that many people have chosen to render CFHD archives to hard drives and stick them on the shelf).
I may see if AVISynth can do it or I’ll keep digging and figure something out. :-)
Who knows? Maybe a future version of Vegas or CineForm HDLink will add the option to output 24P HDV with pulldown for archiving to tape as 60i.
Thanks very much for your feedback, by the way.
Douglas Spotted Eagle January 30th, 2007 08:10 PM
Originally Posted by John McManimie
I
Who knows? Maybe a future version of Vegas or CineForm HDLink will add the option to output 24P with pulldown for archiving to tape as 60i.
Vegas already does offer this. I'm not sure what you're looking for? You can remove, insert, pulldown in Vegas already.
File/Render As/24p w/2:3:3:2...or just 2:3.
John McManimie January 30th, 2007 08:16 PM
Forgive my ignorance as I am new to this application, but aren't those presets limited to DV (720x480)? I do not see the option for 1440x1080 video (as MPEG-2 or HDV intermediate) with pulldown.
Douglas Spotted Eagle January 30th, 2007 08:40 PM
Look at the BluPrint 24p options and you should see the pulldown options. I'm not on a machine that has Vegas installed, so I'm going entirely by memory here (this means I might be remembering something that doesn't exist). I'm pretty sure that you'll find a pulldown insert option.
Marcus van Bavel January 30th, 2007 09:58 PM
Yes, Maker will add either 3:2 or 2:3:3:2 pulldown to HD and uses the correct field dominance (upper field first). You would then have to encode to HDV using Vegas for recording back to tape.
Marcus van Bavel January 30th, 2007 10:01 PM
I recently switched to Vegas and I have been quickly trying to stop using other applications...
By the way the 60i to 24P conversion in Maker is MUCH better than Vegas or CineForm. Here is a comparison page from our website:
http://dvfilm.com/maker/MakerVegas.htm
John McManimie January 31st, 2007 12:07 AM
Thanks, I'll check that out.
Yes, I have no doubt that DVFilm Maker produces excellent 24P conversions. I think that Vegas does an excellent job "for an NLE". I will have to check out the latest version of DVFilm Maker now that I know it can produce pulldown for archiving in addition to the other features it offers.
David Jimerson January 31st, 2007 11:26 AM
I don't see any pulldown options under Blu-Print, only straight 23.976 or the legacy "+ 2:3 Pulldown" for DVD. I don't have a Sony HDV camera on hand to test it with, but my bet is that you can't print to tape with pulldown info intact -- meaning, you won't be able to remove pulldown automatically later. It's probably the same as taking 24p DV and printing to tape as NTSC (no pulldown) -- it still retains all of its 24p aesthetic, but no pulldown info is recorded.
But if someone has success doing so, I'd sure be interested in hearing about it. I may grab the shop FX1 and give it a whirl sometime later this week.
John McManimie January 31st, 2007 09:09 PM
Well, I did find this on CineForm's page on CineFrame (http://www.cineform.com/products/Tec.../CineFrame.htm):
"Once you have completed your 24p production, some may wish to archive back to HDV tape. The CineForm M2T export with Aspect HD and Prospect HD will support 24p encoding into a 60i stream, by simply adding the 3:2 pulldown back. "
So it does, in fact, appear that this functionality already exists in their products. I guess I should pay better attention! :-)
(I do still wish it was available directly from Vegas, though).
David Jimerson February 1st, 2007 09:04 AM
It might add the pulldown (it'll have to to get to the necessary 60i), but it might not include the pulldown INFO in the stream -- meaning, you won't be able to remove it automatically later.
Any VHS movie you have has 2:3 pulldown in it, but if you were to capture it over an A/DV box, Vegas wouldn't recognize it as 24p, because there's no pulldown info.
John McManimie February 1st, 2007 02:16 PM
Even if the pulldown stream info isn't there, the 3:2 pulldown can be removed with HDLink (just a check box), which would treat it the same as CineFrame24. I don't know how you would remove this using Vegas, however.
David Jimerson February 1st, 2007 02:20 PM
You could potentially right-click on the clip in the Media Pool, choose "file format properties," and then "manually remove pulldown." You'd probably have to tinker with it some to get it right, if you can do it.
The "file format properties" item isn't always available, though.
John McManimie February 1st, 2007 02:36 PM
I was able to export a CFHD 24P file as a 24P/3:2 60i m2t from Premiere Pro using CineForm M2T export. Unfortunately, this is only available in Aspect HD (and Prospect HD), thus the reason I used Premiere Pro. Connect HD / Vegas do not offer the option (...yet? *fingers crossed*).
