3 stills from a Raynox 5050 and 4500 and question about WD43 at DVinfo.net
Old July 14th, 2007, 05:47 AM   #1
I'm in desperate need of a proper wide angle conversion lens to go with my HV20. Already tried two which turned out to be utterly useless.
Here is a still done with a Raynox HD-5050 37mm with 37>43mm conversion ring
http://miniurl.pl/32301
For obvious reasons, I decided to replace it with another lens, chose the Raynox HD-4500 (52-> 43mm) which was slightly more expensive and in many ways even worse:
http://miniurl.pl/32300
http://miniurl.pl/32299 (with slight zoom)
http://miniurl.pl/32298
Please could someone who uses the WD-43 post up some stills of how the image looks like with the lens on and without it? The Canon isn't much more expensive than the HD4500 and I can probably have it replaced at an extra charge.
I'm also concerned about the size of the WD-43. The Raynox is 78mm wide by 65mm deep an just about fits into my camera bag. Hope the Canon isn't any bigger?
Alex Zoltowski is offline   Reply With Quote
Old July 14th, 2007, 06:45 AM   #2
Hi Alex,
I see what you mean...
In the odd chance it's really the WD43 you're looking for (and not the WDH43), you're in luck, I posted some tests a while back in this thread:
http://www.dvinfo.net/conf/showthread.php?t=96219
The WD43 is 40mm deep and about 65mm in outer diameter.
Pieter
Pieter Jongerius is offline   Reply
