24P stuttering, lets compare HG10 to HV20 - Page 2 at DVinfo.net
Old November 23rd, 2007, 12:44 PM   #16
So there is no difference
Just to cap off the subject, there is no difference in strobing or stuttering between the HG10 and HV20.
See the thread "hg10 vs hv20 vs xha1"
Another site is incorrect at slamming the HG10 in that respect, it turns out.
-Les
Les Dit is offline   Reply With Quote
Old November 24th, 2007, 08:25 AM   #17
thanks, Les,
you guys' review is the most important reason that I decided to order hg10 instead of hv20.
Michiael Iper is offline   Reply With Quote
Old November 24th, 2007, 11:58 AM   #18
I agree, I've been seriously considering upgrading from a Panasonic HDC-SD1 to an HG10 and spent a lot of time yesterday confirming that with the CoreAVC decoder installer and the latest version of Cineform HDLink that I was able to transcode absolutely smooth 24P content from the available samples posted, so I'll probably pick one up this weekend.
As stated previously, the key seems to be to have a h.264 video decoder that allows disabling of any decoder based deinterlacing, for the CoreAVC decoder, I set the deinterlace to force Weave (no deinterlacing) and disabled the "Aggressive deinterlacing" option. I also had to specifically uninstall PowerDVD, which was being used as the default h.264 renderer previously. When installing CoreAVC, when it runs the Haali Media Splitter installer, make sure to disable all default file format handling (AVI, TS, etc.) as this will cause the Haali Splitter to be brought into the filter graph as a standalone filter rather than as a combined file source and splitter.
Once you can drop your .MTS (I rename them .m2ts) files onto GraphEdit (part of the Microsoft DirectX SDK) and have the following filter graph generated, you'll probably be golden:
http://members.cox.net/eskin3/coreavc_filter_graph.jpg
Michael Eskin is offline   Reply
