Wide Angle Adapters at DVinfo.net
Old May 23rd, 2008, 08:36 PM   #1
Wide Angle Adapters
I know theres a whole thread on it but its getting a bit confusing. 2 questions. Does anybody have this? Is it clean? How much image do you gain? o.k. 3 questions.
http://www.bhphotovideo.com/c/produc...ough_Wide.html
Randy Johnson is offline   Reply With Quote
Old May 24th, 2008, 05:56 AM   #2
Wcv82sc
Hi Randy
As one of those responsible for confusing the thread, some simple answers:
1: Yes, I have this convertor it. I never take it off my lens.
2: Yes, it is clean - certainly better than you would expect for 500 bucks worth of glass.
3: The simple answer; It will give you almost 20% (18%, to be precise) more width in your picture.
This is the JVC sheet on the standard lens:
http://www.jvc-pro.net/docs/pdf/prohdlense.pdf
According to that, the angular field of view of the standard lens at it's widest setting is 51 degrees. With the JVC WCV82SC adaptor you will go out to an angular field of view of 62.2 degrees (51 degrees divided by 0.82).
Robert Adams is offline   Reply With Quote
Old May 24th, 2008, 10:36 AM   #3
Wow! Robert Thank you thats just what I wanted to know!
