No file transfer on battery power? at DVinfo.net
AVCHD Format Discussion
Old July 3rd, 2008, 06:53 PM   #1
Just got HF10, did some test shots, wanted to transfer to my laptop, that thing tells me plug in power adapter; is there really no file transfer on battery power, or this is just a "user problem",
thanks guys!
Old July 4th, 2008, 05:47 AM   #2
thanks guys!
Yes,no file transfer on battery power,but you can copy from internal memory to sdhc card on battery power and use card reader than ,much faster.
Thats why I shoot straight to 16gb SDHC card and leave internal 16GB as a reserve.
Sinisa Jovanovic is offline   Reply With Quote
Old July 4th, 2008, 02:06 PM   #3
Wow , how couldn't I get to this on my own, perfect,
but I have an excuse, I just got my HF10 and didn't get any SDHC yet, which one should I buy to be ok for XP (17 mb/s) mode. I believe class 6 is too slow, x133 is also only up to 13,5, then what specs should be on the card,
Many many thanks!
Old July 4th, 2008, 11:01 PM   #4
class 6 is fine, in fact I have seen class 4 kingston work.
I am using class 6 kingston and sandisc extreme both work flawlessly on highest settings
Stephen Eastwood
http://www.StephenEastwood.com
Stephen Eastwood is offline   Reply With Quote
Old July 5th, 2008, 03:13 PM   #5
I have the same on my HG10 (hard drive based). I was pretty surprised that it needed to be plugged into the AC adapter. I'm even more surprised that they haven't fixed this on the flash-based camcorders. Still, the card reader approach is a good one.
David Sayed is offline   Reply With Quote
Old July 8th, 2008, 04:22 PM   #6
I wonder if that's just a safety precaution to make sure the battery doesn't die in the middle of a read/write, resulting in the flash becoming corrupted. Many gadgets, like the Sony PSP, require the unit to be plugged in during a firmware upgrade as a precaution.
Robert Loncaric is offline   Reply
