mpg files make FCP 5.1.3 crash at DVinfo.net
Final Cut Suite
Old February 16th, 2007, 08:23 PM   #1
I have these 2 .mpg files I'm trying to work with. In the timeline, if I so much as touch one, click on it, etc, FCP will crash.
I suppose I could export as .mov files but will I lose any quality?
thanks,
elmer
Elmer Lang is offline   Reply With Quote
Old February 17th, 2007, 01:55 PM   #2
I am exporting my .mpg files as .mov files, choosing
compression: none
frame rate: current
depth: thousands of colors
quality: best
Does that seem best? Maybe the depth should be 'millions of colors' or 'millions of colors+'?
thanks,
elmer
Old February 17th, 2007, 02:14 PM   #3
I exported as .mov file. When I tried importing into FCP I get an error message: "File error: 1 file(s) recognized, 0 access denied, 1 unknown."
That's odd. Any ideas?
thanks,
elmer
Old February 17th, 2007, 02:53 PM   #4
You need to convert the MPEG file to a .mov file, but one of the correct specs.
Since chances are the rest of your material is in DV, bring the MPEGs into a Compressor batch, and convert to one of the DV presets in Compressor.
My Work: nateweaver.net
Old February 17th, 2007, 04:31 PM   #5
Thanks, you're absolutely right, Compressor did it, and I imported into FCP no problem.
