Creating a PS3 playable HD data DVD at DVinfo.net
Final Cut Suite
Old June 29th, 2007, 07:22 AM   #1
I understand that the Playstation 3 can play m2t files on a regular DVD5 disc. I have a 5-minute 1080i60 HDV project on my FCP timeline, and I'd like to export this as an m2t file that I could put on a DVD so that it is playable on the Playstation 3's blu-ray player.
What is the best way to do this with FCP on a Mac?
Can I just Export to a self-contained Quicktime Movie, changing the setting to HDV - 1080i60; and then insert a DVD into my Superdrive, drag the quicktime movie to the DVD icon, click burn disc, and thereby produce the data disc?
(Normally I'd just test this myself, but since I don't have a PS3 and will have to travel quite a ways to get to one, I'd like to get it right the first time ;))
I'm using FCP 5.1.4 on a Macbook Pro.
Dave Lammey is offline   Reply With Quote
Old June 29th, 2007, 08:19 AM   #2
well, i've been screwing around half the night running between Mac & PS3 to verify all this for own interest.
I can now confirm Compressor "multiplex" option does create M2T file that DO PLAY fine in ps3, they just weren't initially recognised by my PS3 browsing directly to my Mac movies folder (using EyeConnect UPnP server software). WHen I walked the compressor m2t file over on a USB stick..voila played fine after choosing View all in the XMB options.
Mark Joseph is offline   Reply With Quote
Old June 29th, 2007, 08:40 AM   #3
An MPEG2 transport stream is need for PS3 playback, exporting QT - HDV 1080i won't suffice, but the following steps will get you to your objective - confirmed because I network a PS3 to a Mac to view my work on a Sony Bravia 1080p LCD.
Export to Compressor using "HD-DVD MPEG-2" (video format defaults to HDV 1080i)
Multiplex the MPEG2 and AIFF files into a transport stream i.e. use MPEGStreamClip export to TS with MP2 audio. (this take almost no time, as is simply multiplexing the audio/video together)
Play on P3!
Old June 29th, 2007, 10:08 AM   #4
Many thanks for that response, Mark. Couple of questions: I can't find the "multiplex" option in compressor, where is it?
Old June 29th, 2007, 07:56 PM   #5
In Compressor's Inspector window, choose the "Encoder" view (1 of the 6 icons near the top), then choose the Extras tab from the 4 below that, on that screen the 3rd one down is what you need "Multiplexed MPEG-1/ Layer 2 Audio"
