35mm lens adpators for 2/3" cameras w/o flip image at DVinfo.net
Alternative Imaging Methods
Old May 13th, 2009, 12:52 PM   #1
Telecam Films
Hi,
More and more 2/3" cameras (HDW-900R, HDX-500, PDW-800,...) now come with a built-in digital image flip feature which I assume should make 35mm lens adaptor rigs simpler, lighter and less expensive. Is anyone offering 35mm lens adaptors with B4 mounts (for 2/3" camera) and without a bulky optical image flip module?
Thierry.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old May 13th, 2009, 08:11 PM   #2
Dont forget the JVC GY-HD200U/250
They both have image flip also.
Cameron Frittz is offline   Reply With Quote
Old May 16th, 2009, 10:16 AM   #3
Thierry,
Letus and Cinevate have developed b4 relays for 2/3 chip cameras. I read somewhere in this forum or the other that they might work for adapters without the integrated flip.
Also, brevis is a modular adapter, so I think you can use the relay straight to the brevis without the flip module.
Subject to the maufacturer's confirmation, or from someone's experience I think you may be able to use letus or cinevate relay's on the g35, the sgpro or redrock sans flip.
Hope that helps.
Ted
P.S. I too use the jvchd200 + adapter w/o flip as mentioned by Cameron but these are 1/3 inch sensor cams.
Old May 24th, 2009, 08:03 AM   #4
That's correct. The Brevis can be used in non-flip mode on these cameras. For most, our 72mm spacer is required between the unit and our 72mm non-flip achromat.
Cheers,
Dennis Wood
www.cinevate.com
Dennis Wood is offline   Reply With Quote
Old June 28th, 2009, 08:19 AM   #5
This is a straight set up with Varicam and Brevis with my relay
35mm lens adpators for 2/3"  cameras w/o flip image-steadycloseup.jpg
Evangelos Achillopoulos, Elec. eng./DIT/DI supervisor
MotionFX, Athens, Greece. www.motionfx.gr
Evangelos Achillopoulos is offline   Reply
