PL S16 Lenses to B4 mount adapter at DVinfo.net
Alternative Imaging Methods
Old June 25th, 2009, 01:21 AM   #1
I would have liked to use PL S16 lenses on a 2/3 camcorder. Since the size difference between these formats is negligible, I don't need a DOF conversion adapter like P+S pro35, but only a mount to compensate for the prism inherent in the 2/3 design. After some googgling I have found an Abacus adapter that enables B4 lenses to be used on PL S16 cameras but not the opposite. Does anybody know if an adapter like that exists?
Emmanuel Plakiotis is offline   Reply With Quote
Old June 25th, 2009, 10:58 AM   #2
You certainly can't make a simple mechanical adapter as there's no room for it, it would need optics. Then there is the theoretical problem that the S16 lens is designed for 1 plane (film) while the video lenses are designed for 3CCD cameras (focussing 3 different coloured lights). I get the feeling it might not be worth doing - even though, like you I suspect, I'd quite like to use nice S16 lenses instead of plasticky video ones!
Steve
Old June 25th, 2009, 03:51 PM   #3
Originally Posted by Steve Phillipps View Post
Then there is the theoretical problem that the S16 lens is designed for 1 plane (film) while the video lenses are designed for 3CCD cameras (focussing 3 different coloured lights)Steve
I don't think thats a problem because the lens is focused on the prism and the prism is responsible for splitting the light to the 3CCD's. Besides if there are adaptors for 35mm lenses to mount them in 1/2 inch and 1/3 3CCD cameras with the obligatory image magnification, I don't see a problem making one from S16 to 2/3 inch.
S16 lenses, when attached to 2/3 B4 mount, don't need a ground glass solution because there is no more than 12% difference in the format sizes. It will be a very economical alternative to digiprimes because there are plenty of S16 lenses around that nobody uses anymore and probably could be purchased for nothing.
Old June 25th, 2009, 11:55 PM   #4
Emmanual
You may find the S16 lenses okay but may also discover a chromatic abberation problem which 3xCCD purposed lenses are designed to minimise as much as is affordably possible.
Have a look at this unrelated post.
http://www.dvinfo.net/conf/let-us-di...extreme-3.html
Scroll through until you find some jpg images. One of a car on a street shows the CA effect you may get if you look closely along the top of the car roof. In this instance I was using a Nikon-mount 35mm stills format prime lens as a relay lens to a JVC 1/3" camera so the scale of the CA relative to the image may be less with a S16mm lens on a 2/3" camera.
Old June 26th, 2009, 05:08 AM   #5
Optex used to make a device to correct this issue, a Longitudinal Colour Corrector, they obviously thought it was an issue.
Steve
Old June 26th, 2009, 05:10 PM   #6
Steve
They basically adapted 2/3" lenses to film rather than the other way around. http://www.abakus.co.uk/Format_Converters.htm
There are other adapters as used for the JVC 1/3" cameras.
Super 16 lenses aren't cheap, because people still use them, but standard 16 lenses are cheaper. The demand will increase when the 2/3" Scarlet comes out, perhaps some people may be buying them now, before the price shoots up, which is what happened with the 35mm Cine lenses when the RED One came out.
Brian Drysdale is offline   Reply
