Prospect HD and nanoFlash at DVinfo.net
CineForm Software Showcase
Old July 1st, 2009, 09:52 PM   #1
Does v4 of Prospect HD read/convert nanoFlash mxf files?
Alex Raskin is offline   Reply With Quote
Old July 1st, 2009, 10:10 PM   #2
CTO, CineForm Inc.
No, unfortunately it uses Sony encoder chip that produces bitstreams we require us to write a new MXF parser (and maybe more) for this one product only. The Sony directshow demux works, but they will not license it out (I don't know why.) We have no plans to reinvent this wheel, so no support until Sony makes the demux more available. I don't understand why camera company makes new bit-streams and puts up road blocks to prevent people using them. This is not Convergent Design's fault issue, they just feel into the trap of using the Sony encoder.
Old July 1st, 2009, 11:00 PM   #3
I see.
Is there a workaround to still convert nanoFlash's mxf into Cineform AVI on PC? Maybe via some intermediate step?
Thanks.
Old July 2nd, 2009, 06:32 AM   #4
Images: 10
Alex..
I'm facing this same issue. Here's a workaround:
There's a number of disembedder or demux software apps that will separate the video and audio tracks from the Sony MXF codec. I'm using Amberfin's MXFDesktop. FFMPEG is freeware that will also work. Once split out into m2v video file, Cineform's HDLINK will easily make the conversion to the DI.
Unfortunately, MXFDesktop outputs an .aes audio file. I have not been able to convert the .aes file into anything readable, like .wav. So, I need to read the C-D MXF with an NLE and export the audio files. Then import the Cineform DI, video file only, and overwrite the non-cineform m2v in my nle.
Does this help?
Old July 2nd, 2009, 09:26 AM   #5
Thanks Bill.
My NLE is PPro 2 (don't laugh...), and it does not accept mxf files at all, so I couldn't do sound separately in it as per your suggestion.
Any other third party applications that could be used?
Old July 2nd, 2009, 09:41 AM   #6
Images: 10
Originally Posted by Alex Raskin View Post
Thanks Bill.
I'm still looking for an app to do the audio conversion. FFMPEG will do the demux, but, FFMPEG won't do the audio right, either. The only PC based NLE converters that I know will work are Avid and Edius. Vegas won't read the audio files, but, will read the video. Procoder3 will read 50 and 100 Mbps mxf files, but, not 140 or 160 mbps. Haven't tried I-frame only.
Old July 2nd, 2009, 08:35 PM   #7
Images: 10
VOILA!!!
The aes codec can be transcoded to standard WAV by the Mainconcept Reference, available as a free DEMO download at MainConcept: MainConcept
While the free DEMO download adds a watermark to the video, an audio file can be output, free of encumbrances.
Old July 3rd, 2009, 02:27 AM   #8
I have the same problems with my 50mbps 422 sony mxfs. I bought a copy of Vegas as it supports the Sony XDCam system so well.
But I've been pondering ways of getting cineform back into the mix in a practical fashion so that so I can work with 10 bit files, first light and so on.
I found a batch converter script written by vaast called gear shift (c. $50). It plugs into Vegas 9 and will batch convert any file supported by Vegas (including 50mbps XDCam 422 sony mxf) files into cineform files. I have not yet tested exhaustively, so there may still be a pit fall in there somewhere.
If vegas supports the nanoflash 100mbps variant, then it should work also.
Alas, this is not a cheap solution if you don't already own Vegas 9.
Peter Beeh, Lighting Camera/DOP
www.peterbeeh.com.au
Peter Beeh is offline   Reply With Quote
Old July 3rd, 2009, 07:01 AM   #9
Images: 10
Peter...
At this point in time, Vegas does not support the audio demux in the Sony XDCAM422 codec.
Unfortunately, Vegas does not have a 10-bit pipeline. As I understand how it works, everything coming into Vegas is converted to 8-bit.
Old July 3rd, 2009, 08:02 AM   #10
All this makes one wish for the nanoFlash capturing directly to Cineform :/
Old July 3rd, 2009, 08:06 AM   #11
Oh, and I tried SUPER encoder and it was able to read and transcode 100mbs mxf files that I have downloaded fron nanoFlash examples page.
1. There was no sound - but then i don't know whether the original files had sound or not. C-D recommends Sony viewer which I have installed on my Win x64 system, but it does not initialize correctly when starting... so there's no independent way for me to view the original mxf files before transcoding
2. SUPER does not seem to have Cineform listed as output option. I had to transcode to M-JPEG avi, which seemed the highest quality SUPER offers. This kind of defeats the purpose since it is not Cineform... so yet another step is required...
Old July 3rd, 2009, 08:13 AM   #12
Images: 10
I tried the super encoder, as well. It demuxed the video tack but failed on the audio tracks.
Old July 3rd, 2009, 12:36 PM   #13
Originally Posted by Bill Ravens View Post
Peter...
Bill,
So Red, 12-bit linear, and DNxHD 220x and Cineform 4:2:2, 10-bit linear, are truncated/rounded to 8 bits? Even when processing effects and rendering? This isn't just a display limitation?
I'm just surprised. I realize that Vegas can handle just about any format and output in Cineon and DPX, but if it only works in 8-bits, then such an advantage has less appeal.
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old July 3rd, 2009, 01:21 PM   #14
Images: 10
Peter...
My understanding is that vegas has an 8-bit Input and 8-bit output pipeline, unless output is via the Sony 10-bit YUV codec, which, for me, doesn't interface with anything but Vegas. VfW(Video for Windows) is an 8-bit engine, I know that for sure. Vegas works only in VfW, and converts all YUV input to RGB on import. This is one of the biggest, if not the biggest drawback to vegas. In between the I/O there is higher than 8-bit processing, for example in color correction filters, but, many of the filters are only 8-bit. Perhaps Ed Troxel, or someone, can step in and be a little clearer than my comprehension.
Bill Ravens is offline   Reply
