Historical picture in docs at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Documentary Techniques
-- Discuss issues facing documentary production.
Old July 6th, 2009, 03:15 AM   #1
Hi guys, i wanted to know your opinion on the moves Pan & tilt on the historical picture(of war for example).Any video example?The movement should start at hte beginning and finish at the end(keyframing) of the pic or should end a little bit early?
Thank a lot
MM
Old July 6th, 2009, 03:37 AM   #2
I think it all depends on the amount of pictures you will use in a sequence.
If every pictures is moving all the time and there are alot, I usually tend to get a little sea sick while watching it.
If you want to see a good way for incorporating stills into a documentary, may I suggest watching the Dogtown docu. Loved the way they made their stills dynamic.
Boudewijn de Kemp is offline   Reply With Quote
Old July 6th, 2009, 07:24 AM   #3
Check out Ken Burns "Civil War". In the US pan and scan of photos is referred to as "Burns effect". The basic convention with regard to frame movement, assuming you want an invisible cut: Match the movement/motion blur in the last frames of the outgoing clip and the first frames of the incoming.
Doug Bennett is offline   Reply With Quote
Old July 6th, 2009, 05:33 PM   #4
YouTube - Ken Burns Civil War 1864 (Part 20)
i was looking KEN BURNS stuff but i can't see the blur at the very beginning and at the end of the pics.What about his workflow?How many keyframe does he use on a single picture to obtain that strange NYPD BLUE effect on the pics?
thx a lot
Old July 6th, 2009, 08:36 PM   #5
Marcus, check the tutorial from Ken Stone's Final Cut Pro and click on Ken Burns redux. The last method is so easy (even I can do it), that it doesn't make any sense to avoid pans and zooms.
Robert Rogoz is offline   Reply With Quote
Old July 7th, 2009, 02:54 AM   #6
Unfortunately it doesn't open it!I wanted to check it so bad...
thx 4 da info
MM
Old July 8th, 2009, 12:08 AM   #7
It's the 4th one from the top. I don't know why would not open?
Old July 8th, 2009, 02:10 PM   #8
buffer issues.I did see it,nice tut but nohing compared to ken burns shaky effect.right?
Marcus Martell is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Documentary Techniques
