Flash Compression Settings at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old January 28th, 2008, 11:43 AM   #1
Hi folks, I am using Premiere Pro CS3 to create my flash files. I've used several default settings - 256, 512 and 1024 and custom ones. My problem is the clarity versus the file size. Mine appear to be very large.
Is there a better way to compress the files and maintain quality than using Premiere Pro? What are folks using for Flash on the web?
thanks
Janice DeMille is offline   Reply With Quote
Old January 28th, 2008, 11:20 PM   #2
Sorenson Squeeze for Flash:
http://www.sorensonmedia.com/products/?pageID=1#ppc2
The same physics apply to any compressor. The more data you allow per second, the better looking an the larger your file will be. The differences is in the quality of the compressor. The better compressors can make better results in the same amount of data. Here's an example done with Sorenson tools at around 384kbits per second data rate.
http://www.journeyfortheheart.com/si...ifeofjames.php
Old January 29th, 2008, 12:14 PM   #3
thanks for the response Ernest. What size is your file? Did you do the video?
Old January 29th, 2008, 05:50 PM   #4
It's 10m 11s. 28.9MB. No.
Old January 29th, 2008, 06:23 PM   #5
I also use Sorenson Squeeze but its mainly to get batch features and such. Technically you should be able to get good results if you customize the presets and save it once you find one you like. How big in terms of Resolution do you want it? Ill see if I can give you a starting point.
Simple Thought Productions - Life @ 30,000 Words per second
Josh Chesarek is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
